Question about EnGenius EOC-5610 802.11a/b/g Wireless Access Point
Can not access web interface
After upgrading my EOC-5610 wrongly(may be very stupidly) from version 1.2.4 to version 1.3.1 via web interface,I discovered that the version 1.3.1 was for EOC-5611P and not for my EOC-5610.Then I could not be able access web interface.Then I tried to re-flash it with the original firmware by using these tools(putty & tftp server).I did all the steps very carefully but the problem still that(cant load the file ..... operation timed out) in loading command. Please I want someone(professional one) who can help me. Thanks.
  • hassan aga
    hassan aga Mar 20, 2014
    Note: I am using windows 7 Ultimate N SP1
  • EnGenius Master
  • 3,320 Answers
I think you're out of luck. If you had posted this info with the 5 other posts you made you would have gotten this answer sooner.
You have over-written the PROM on the AP with garbage.
You could contact Engenius and see if they will flash the PROM with a working image otherwise you have a piece of junk.
Posted on Mar 20, 2014
Testimonial: "With your answer this,now I should cry hardly specially that this piece could not be found in iraq now."
  • 5 more comments
  •  Mike M
    Mike M Mar 20, 2014
    Sometimes people list these items in online auctions like ebay etc. The case or connectors could be damaged but the circuit board would be ok.
  • hassan aga
    Are you sure it is junk now? what is the alternate solution? really may i contact engenius and they may replay me or consider that i am crazy?
  •  Mike M
    Mike M Mar 20, 2014
    You can't be the only one with this issue. It never hurts to try. The worst they can do is say no.
  • hassan aga
    I had read user manual for EOC-5610 & EOC-5611P individually and saw them are same exactly,this may help me?
  • hassan aga
    hassan aga Mar 21, 2014
    can u visit this url to please? http://www.engenius-europe.com/index.php...
  • hassan aga
    take attention on the word "applies to EOC5611P (EOC5610)" what does that mean?
  •  Mike M
    Mike M Mar 21, 2014
    Time to stop the questions. The unit is bricked.
What Web-based Management Features Do Switches Excluding the S1700 Support?
Table 1 lists the web-based management features supported by S series switches.
Table 1 Web-based management features supported by switches Category
Function System management Upgrade, patch loading, PoE, DNS, stacking, viewing log files, and setting the system time, SNMP parameters, and EasyDeploy parameters
NOTE: Switches in V200R002 and later versions support SNMP and EasyDeploy parameter configuration. Interface management Viewing/configuring basic interface attributes and viewing statistics on an interface Service management VLAN, MAC address, STP, voice VLAN, DHCP, ARP, VRRP, and IGMP snooping ACL management Creating/modifying/deleting ACL rules and effective periods QoS Priority mapping, traffic policy, rate limit on an interface, traffic shaping, and congestion management Route management Viewing IPv4 routes, configuring static routes, and setting the preference of static routes Security management Port isolation, static user binding, AAA, 802.1x authentication, and MAC address authentication Tools Ping, Tracert, and VCT S2300 Switch Thunder link com
Feb 09, 2017 | The Computers & Internet
How to update firmware version
You haven't specified the router, so this is general advice.
Individual routers may vary in the way they check and update their firmware, so the best starting point is reading the manual.
First, see which firmware version is installed on your router. Then check the support section of your product's website for firmware updates. Some routers are able to perform a check for updates via their web interface.
If you download an update, make sure to use a LAN cable between PC and router to perform the upgrade. Don't use wi-fi! Backup your settings if you're cautious, but as a rule custom settings shouldn't change after the upgrade.
Here's a step-by-step guide.
Upgrade Your Routers Firmware
Feb 25, 2014 | Computers & Internet
Is WRT54G2V1 compatible with windows 7?
Nearly all new wireless routers are compatible. There is no installation required. They use a web interface to administrate.
Linksys WRT54G2
Login via web browser.
192.168.1.1
User: (none / blank)
Password: admin
Lost login credentials? Hold the reset button in the back till it reboots. This clears all custom settings.
1. Check the firmware version. http://homekb.cisco.com/Cisco2/ukp.aspx?vw=1&articleid=4046.
2. Download firmware upgrade file. You must choose based on version on step 1.
http://homesupport.cisco.com/en-us/support/routers/WRT54G2
3. Install
http://homekb.cisco.com/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4030
I hope it clear and the links work. GL!
Oct 10, 2012 | Linksys WRT54G2 Wireless Router
WHEN I WANT TO RUN MY GAMES IN NOKIA 5610;IT MESSAGES "INVALID APPLICATION.DELETE?" OR "SUPPORTIVE FILE.NOTHING TO DISPLAY." WHAT'S WRONG?
This is a well known bug of Nokia 5610.Nokia have resolved this issue.This bug will allow you to install .jar files mainly..But it will alow
.sis files which have correct certification.
Nokia 5610 has 8.0 to 10.0 firmware is available in the market.
You have to press +#0000# and check the firmware version
Even though your firmware is of 10.0 try to upgrade it again.Because of the corruption in the phone...
Steps how to upgrade it.
1)Connect Nokia with USB cable provided during the time of purchase of the phone.
2)Install nokia pc suite that is also given during the purchase of the phone in a CD.Pc suite can be downloaded in the internet in nokia official website for free.
3)Open Nokia Software Updater through PC Suite interface.
4)Your internet should be On.Nokia updater will download it automatically and upgrade your phone version.
5)Follow the step by step instruction of Nokia Software Updater.
Note:Do not disconnect the phone while its updating....
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Aug 01, 2010 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
SATA Hard Drive Type The Dell Optiplex GX280 Takes?
It makes no difference providing the computer motherboards support SATA interface.
SATA 1 and 2 drivers are in the BIOS. If all the computers have SATA 1 you can upgrade the BIOS to latest version via Dell's support website.
Regards.
Jul 08, 2010 | Dell OptiPlex GX280 PC Desktop
Restoring engenius EOC 8610 to factory default
Resetting the older beige Engenius radios requires a screwdriver and a USB-to-serial cable. You must unscrew the small plate at the bottom, which covers a serial connector. Plug the serial cable into it and then into your computer. Follow these instructions to perform the reset:
http://engeniustech.com/datacom/support/general-details.aspx?id=65
Mar 31, 2009 | EnGenius / EOC-8610 EXT / 54Mbps /...
192.168.1.1 unreachable
you can use the "ifconfig -a" to see the ip addresses of all network adapters. but i'm wondering what happened to the user interface that showed a list of options to choose from.
Mar 15, 2008 | EnGenius EOC-3220 (EOC3220)
SB5100 Docsis 2.0 Upgrade from Docsis 1.1
Technical Details
  • Model: SB5100
  • Type: External, platform-independent modem with HTML-based user interface for status troubleshooting
  • Standards: Integrated DOCSIS 2.0 A-TDMA and S-CDMA technology
  • PC interface: USB for Windows 98/2000/XP
  • Cable interface: F-Connector, female, 75 ohms
  • CPE network interface: USB, Ethernet 10/100BaseT (auto sensing)
  • LED indicators: Yes (front panel)
  • Users: Supports up to 32 users (1 via USB and up to 31 via Ethernet or 32 users on Ethernet)
  • Power: Internal power supply: 9 Watts (nominal)
  • Input power: 100-240 VAC, 50-60 Hz
  • Excite@Home Level 2 Approved: Yes
  • Bridging: Ethernet and USB connections are bridged allowing LAN traffic between USB device and Ethernet LAN
  • Networking: 10/100BaseT Ethernet (auto sensing)
  • Remote management: Yes (via SNMP)
  • Software upgradeable: Yes (over the network)
  • Top-mounted stand-by button: Yes (enhances network security to end-user)
  • Troubleshooting: HTML-based diagnostic user interface
  • Global safety approval and certificates: CB scheme (EN60950/IEC950), CE-Evaluation test report (EN55022/EN55024), FCC Part 15, UL 1950
  • Downstream demodulation: 64 or 256 QAM
  • Downstream maximum data rate: 38 Mbps
  • Downstream bandwidth: 6 MHz
  • Downstream symbol rate: 64 QAM 5.069 Msym/s
  • Downstream symbol rate: 256 QAM 5.361 Msym/s
  • Downstream operating level range: -15 to +15 dBmV
  • Downstream input impedance: 75 ohms (nominal)
  • Downstream frequency range: 88 to 860 MHz
  • Upstream modulation: 8, 16, 32, 64, 128 QAM or QPSK (with A-TDMA or S-CDMA enabled CMTS)
  • Upstream maximum data rate: Up to 30 Mbps
  • Upstream bandwidth: 200 kHz, 400 kHz, 800 kHz, 1.6 MHz, 3.2 MHz, 6.4 MHz (with A-TDMA or S-CDMA enabled CMTS)
  • Upstream symbol rates: 160, 320, 640, 1280, 2560 and 5120 ksym/s (with A-TDMA or S-CDMA enabled CMTS)
  • Upstream operating level range: A-TDMA: +8 to+54 dBmV (32QAM, 64QAM), +8 to+55 dBmV (8QAM, 16QAM), +8 to+58 dBmV (QPSK), S-CDMA: +8 to+53 dBmV (all modulations)
  • Upstream output impedance: 75 ohms (nominal)
  • Upstream frequency range: 5 to 42 MHz (edge to edge)
  • Data protocol: TCP/IP
  • Operating temperature: 0 degrees to 40 degrees C
  • Storage temperature: -30 degrees to 80 degrees C
  • Operating humidity: 0 to 95 percent R.H. non-condensing
  • System requirements: Windows 95/98/2000/NT/Millennium, Macintosh, UNIX
  • Width: 2.3 inches
  • Height: 6.2 inches
  • Depth: 6 inches
  • Warranty, parts: 1 year
  • Warranty, labor: 1 1year
Nov 25, 2007 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
EnGenius EOC-5610 802.11a/b/g Wireless Access Point Logo
155 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
