Question about Xerox DocuColor 242-252-260 PS
Problem 07-909 Printer Hi my problem is a fault code 077 - 909 regarding the fuser unit but there is no paper jam
  • 208 Answers
SOURCE: Paper jam at fuser
1. Faulty/blocked fuser exit sensor or faulty/blocked POB sensor. The printer thinks paper is present at one of these sensors when there should not be paper present
Verify that the fuser exit sensor is not stuck
If both sensors are working correctly, the most likely cause is the POB sensor is being blocked by the transfer unit. This can happen if the sensor is out of position, or if the transfer unit's white plastic baffle is out of position. Try bending the POB sensor bracket outward slightly to clear the baffle and retest.
Posted on Dec 19, 2007
  • 208 Answers
SOURCE: Paper jam 2 fuser
1. Faulty/blocked fuser exit sensor or faulty/blocked POB sensor. The printer thinks paper is present at one of these sensors when there should not be paper present. Verify that the fuser exit sensor is not stuck Verify operation of the POB sensor If both sensors are working correctly, the most likely cause is the POB sensor is being blocked by the transfer unit. This can happen if the sensor is out of position, or if the transfer unit's white plastic baffle is out of position. Try bending the POB sensor bracket outward slightly to clear the baffle and retest
Posted on Dec 20, 2007
SOURCE: xerox phaser 6120 laser printer paper jam fuser
Fix, well i am a dentist in Marysville washington and just got this printer from a family member and same thing was going on.
I looks like paper stuck in the middle roller. I just got a small mirror and pair of dental tweezers and removed a lot of jammed paper. it works fine now but you need do go to the dental section in drug store, so you can see where the jam is at.
Posted on Oct 26, 2009
  • 87 Answers
SOURCE: I have Xerox Phaser that had a paper jam in the
The fuser exit sensor arm is a delicate piece of black plastic. It's possible you damaged it removing the paper jam. Remove the fuser and see if the sensor arm is still intact. It's in the middle of the machine.
There's more detail about the 7300 here:
http://michelsplace
Posted on Mar 02, 2011
SOURCE: fault code 077-312 is on the screen and wont start
Fault code 077-312 is on the screen and wont start up the printer, what can i do Regards
Posted on Dec 10, 2012
Colour Xerox Machine problem
its a problem with the fuser unit ,its overheating .two ways to solve it first check if the sticker paper is supported by your printer ,2nd you may need to replace the fuser unit
Oct 02, 2014 | Xerox DocuColor 242-252-260 PS
I have xerox dc 250 machine, it shows fault code 077-909, paper jam at tranfer module but i checked there is no paper in it??
Hello friend, you are not alone !!!!
From http://www.copytechnet.com/forums/xerox/28764-dc-250-fuser-problem-077-909-a.html
At the bottom of the page it says.......
'what sometimes happens is that the sensor flag/arm call it what you will, twists out of its holder and jams, hence the machine thinks that there is still paper. the flag/arm should pivot freely'
Sep 03, 2014 | upbright AC / DC Adapter For XEROX...
Code 077-106 in docucolor 252
Hi
This error code indicates a jam either in the fuser exit area or in the final exit area so I would check these areas for a small bit of paper that may be sticking on one of the jam sensors in this area
Cliff Cook
MCP
Aug 01, 2014 | Office Equipment & Supplies
Paper Jam Fuser 077-104
Most likely you will have to replace the fuser. Also I would inspect all pick up rollers and make sure they are all textured with no smooth or bald spots. Bad rollers are the #1 cause of jams. Also if you hear any clicking you may have a bad gear.
Jul 13, 2012 | Dell 3100cn Laser Printer
Nov 12, 2010 | Xerox DocuColor 12 Color Copier
I have a Dell 3010 that has error msg paper jam fuser 077-104. I cannot find a paper jam anywhere in the printer. I turned it off, unplugged, checked under drum, opened all doors and checked everywhere....
you need to check the fuser, sometimes a small piece of papaer or a label stick on he fuser in order to do this you need to open the back and top cover. or take the printer to service
Aug 21, 2010 | Dell 3010cn Laser Printer
Paper jammed at this time error message show on control panel 13.05.00-Jam in top cover area open front covers and Transfer unit. Fuser is hot transfer unit can be easily damaged. Check left side of...
This error comes when media doesn't come to fuser delivery sencor with in the specified time it may be due to improper paper picking or fault in registration ***...
clean the paper feed rooler & registration *** path ur problem will resolve defin...........
Jul 14, 2010 | HP LaserJet M4345 MultiFunction Printer
Xerox DocuColor 242 Fusor Error/ Paper Jam
Those coded normally are related to something not being seated properly in the paper transport in the fuser area.
Mar 02, 2010 | Xerox Office Equipment & Supplies
Open Questions:
See all Xerox DocuColor 242-252-260 PS Questions
Computers & Internet Logo
51 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
steve morris
steve morris
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
