Question about QSC Audio Players & Recorders
I have a qsc 1300 and channel b wont switch on, its like the relay wont switch
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
It is not passing it's self test. check the usual suspects (shorted output transistors, blown mini fuse, and that annoying pcb mount fuse in the power supply (looks like a resistor with one stipe)) if they all check out, test the relay coil for continuity. if it is open then replace the relay, but if it reads below 200 ohms the relay is ok, and i'd bring it to the shop for more extensive testing and repair.
Posted on Mar 24, 2014
2 Suggested Answers
  • 166 Answers
SOURCE: qsc mx 2000a left channel go into protek mode
Does it do it with nothing connected to the inputs and outputs? If yes, something internal.. anything loose in there (is it moved alot and something could have fallen inside of it)
Posted on Mar 28, 2010
Qsc usa 1300
What is the impedence of the speakers on the unit?
May 13, 2013 | Audio Players & Recorders
Not putting out sound fan on light on
A common issue with the QSC RMX series amp is faulty volume pots, so i would recommend go this way first of all, let me know a bit more to improve help.
Feb 04, 2013 | QSC Audio Products QSC RMX 850 RMX850...
How do I bridge my QSC GX 3 amp to run one speaker cabinet?
For QSC amps the GX series are not bridgeable. You will have to run one speaker to each channel.
Mar 22, 2011 | QSC GX3 Amplifier
Qsc mx 2000a left channel go into protek mode
Mar 28, 2010 | QSC MX1500A 2-Channel Amplifier
My QSC GX3 has a red light that turned on (on the front panel). The channel is not working. Is this a fuse or something else?
You should check the speaker set, maybe it's short circuit.
Try remove the speaker set from the unit, than switch on the amplifier again, if the red light still on, surely the final drive is damages( Transistors or IC's).
Replace it with new ones.
Oct 18, 2009 | QSC MX1500A 2-Channel Amplifier
QSC ISA 280 Stereo Power Amp stopped working
This is a very precise questions as QSC amp are pretty rare and high end electronics equipment. There is no way getting an answer other than getting the amp at a sound shop for repair, wich might go for a visit at QSC anyway. From a sound shop repairman...
Sep 07, 2009 | QSC ISA 300Ti Amplifier
Peavey cs800x a channel drive board what goes bad?
A bit late, but I'll give it a try.
You can measure the outputsignal before the relay.
Often there's a coil, measure if you've got a DC level at that point.
If so, you're power amp is down.
Normally when the relay doesn't switch there's a DC level in your amp.
Cheers, Gerard
Sep 07, 2009 | QSC MX1500A 2-Channel Amplifier
QSC 2450 Power amplifier
i have a pyle pro 1000 watt max 2 channel mono and 2 channel stereo and when i get that thing loud the little red light cums on basically what i mean is that the amp on channel one is cooked i myself i wouldn't even use it y cause more damage
Apr 03, 2008 | QSC RMX-2450 Car Audio Amplifier
Long startup
There is a bad connection in the other channel or the speaker relay has a bad contact in it.
Sep 30, 2006 | QSC MX1500A 2-Channel Amplifier
109 people viewed this question
Top QSC Audio Players & Recorders Experts
 Grubhead
Grubhead
Rob Beech
Gil Shultz
Are you a QSC Audio Player and Recorder Expert? Answer questions, earn points and help others
