Question about Linksys Wireless-G WRT54G Router
My linksys is not working. Is there a program that will troubleshoot and fix the problem? pls help
    Sergeant:
  • 322 Answers
Try upgrading its firmware. It may solve your problem.
Posted on Jun 16, 2009
Wireless freezing problem
There are many documented cases of this router being ****. How old is it? If you can return it do that. If not, get yourself a linksys. I know they are bit more expensive, but you get what you pay for.
Nov 07, 2013 | AGPtek TPLink TLWR740N IEEE 80211bgn...
When i open up the linksys WUSB54gc system tray icon to configure my wireless connection, the program opens but does nothing, only giving me the option to close the program, how do i fix this so i can...
What is the operating system on your computer ?
If it is windows XP then you can use windows software to connect to the wireless network. Windows XP has it's own software to connect to the network. For this you will need to start the WZC service on your computer.
When you open the Linksys icon, does it say , adapter is inactive ? If it says that then unplug the adapter and plug it back in. try again and see if that works.
Click here for more information
Apr 09, 2010 | Linksys WUSB54GC 802.11g/b Wireless...
Linksys WRT160N V3 Firewall issues
You need to check first if it is the program that is causing this or not. If you have a computer without the program, have it connected to the router. If it connects it may be the program. Check if switching cable may help. IT may be a faulty cable. It may also be something in your PC that is causing this one.
Aug 08, 2009 | Linksys Wireless-G WRT54GS Router...
I bought a Linksys wireless G-WRT54G Router. When I purchases it I was told this was all I needed and how easy it was to set up. I have no idea what I am doing but I can not get it to work. I have a...
Other than the laptop and the LinkSys WRT54G, you would need an active account/subscription with an Internet Service Provider (ISP) who then will provide you with a modem of sort.
On initial setup, connect your modem to your laptop and verify that you can connect to the Internet. Thereafter run the CD installer that came with the LinkSys before connecting/powering the LinkSys. Follow on screen instruction. At one point in the installation, you would be asked to disconnect the modem, connect the router and connect the modem to the router.
Should for some reason the above instruction will not address your concern, pls post back.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 02, 2008 | Linksys Wireless-G WRT54G Router
Installing linksys wrt54g
The quickest/easiest is to boot your PC attached to the modem through an Ethernet cable without the WRT54G. Pop in the CD installer and allow the installer program to run. Closely follow on screen instructions. At some point you would be asked to reboot and connect the LinkSys using another Ethernet cable. Once rebooted, the program will auto configure the router and you should be be able to use it. Of course the PC must be set to "Auto Obtain IP Address".
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Jun 27, 2008 | Linksys Wireless-G WRT54G Router
File sharing
File Sharing could be easily done between your laptop & desktop assuming both are running some Windows version with no other program needed to install. You have to right click on the filename/folder and enable sharing. Of course both computers must belong to the same network group for easy access.
Should you need additional information, pls post back your Windows version.
Dec 12, 2007 | Linksys Wireless-G WRT54GS Router...
Need the driver for Linksys WRT300N V1 ... can't find the CD
The LINKSYS WRT300N is a standalone device, there are no software/driver needed on your PC for the router to work. However, there is an easy Setup Wizard that is in the CD that normally comes with the unit.
Unfortunately, Linksys did not make the specific Setup Wizard (Version 1.3) for the WRT300N available online. However, if you care to try the Setup Wizard for a WRT54GC, it may downloaded from the LINKSYS ftp site here. I used to have a WRT54G and I did make use of the Setup Wizard for that model. I upgraded to WRT300N. The setup wizard for the old WRT54G worked likewise on the new WRT300N.
Alternately, the WRT300N can still be configured without the CD or the Setup Wizard by logging into the Configuration Page (192.168.1.1). Remember to use LAN interface when setting the router (as shown in the connection diagram) and set your PC to an IP Address of 192.168.1.2, Subnet Mask of 255.255.255.0; Follow on screen instructions and enter settings/configurations manually.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information. Additionally, if you still prefer to have a copy of the original WRT300N Setup Wizard, pls include your email address that I may send it to you as an attachment.
Nov 24, 2007 | Linksys WRT300N Wireless Router
Router failure
Just try to reset your router and enter again the router configuration..
Nov 16, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
130 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
