Question about HP PhotoSmart Office Equipment & Supplies
Color cartridges are full but colored pictures are gross
Just installed new color cartridges but color articles are not coming out natural....black background with a face comes out purple background and hair is red and face is bronze..took cartridges out and re-inserted them ..did not change print.
    Problem Solver:
  • 16 Answers
Use the HP print utility and run through the tests. One bad cartridge will muck up the color completely.
There should be a clean print head option. Run it if the initial color test shows a clog.
Posted on Mar 20, 2014
  • 23 Answers
Also remember that "if you are using a cartridge that has been refilled the ink in the cartridge may not be exact as the Original Equipment purchased . the printer is trying to mix what is in the cartridge colors to make it as close as possible. I would try a new set of ink from HP,
Posted on Jun 03, 2014
dixibabe82
  • 54 Answers
SOURCE: HP c3180 color printing problems
I would definitely start by printing a self-test page. With your model press and hold the Cancel button and then press the Start Color Copy button and then release both buttons. When this page comes out you should be able to identify the 4 different color sections...black, cyan, magenta and yellow. If any of these seperate areas are choppy or non-existant, you need to replace your cartridge. Here is a link that will show you examples of what you should/shouldn't see on the self-test report.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00661556&lc=en&dlc=en&cc=us&product=1146331&rule=25470&lang=en
Posted on Mar 30, 2009
  • 137 Answers
SOURCE: Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Posted on Jul 18, 2008
leroyal
  • 2120 Answers
SOURCE: new tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Posted on Jan 22, 2009
SOURCE: Dell 926 won't recognize new color cartridge
Try this...shut down the printer. Insert new cartridge, let the printer cycle out with new cartridge. then reboot the computer. This should solve the problem. The cache in the printer will not cycle out. It wants to see the printer as a new entity
Posted on Jun 17, 2009
ErusTownsend
  • 592 Answers
SOURCE: my printer only prints color..have installed new
Unlike most printers where the print cartridge and printheads are attached and sold together, the ESP 3 has a separate printhead from the cartridges.
Remoe both cartridges. Then look at the place where the cartridges sit. There is a latch you push down in the back. This will release the printhead to allow it to be removed.
Remove the print head
Take a cotton swap and a little alcohol and clean the printhead of all ink. Repeat this until it is totally clean.
Make sure the printhead is dry and clean of all ink and alcohol.
Replace the printhead.
Place cartridges in and test.
If this does not work, then you need a new printhead for this printer.
here is an example of how to remove and replace printheads for thsi unit.
http://faqs.kodak.com/atg/faq/attachments/AUR1780-2.pdf
to gt a new printhead you must contact kodak
http://www.kodak.com/go/contact
probably as expensive or almost as expensive as a new printer.
The seperate printhead from the carts are why kodak can have their ink so cheap. Those other brands cost that extra 15-20$ for the attached new head with each cart.
Posted on Jun 12, 2010
I had been out of color ink for a few months, so just printed using black&white mode. I installed a new color cartridge, and the computer is not acknowledging that a new cartridge is in. It will only...
Start, control panel, printers, your printer, printer preferences, advanced. Uncheck the complete-a-print boxes and also check to make sure the print in black & white box in unchecked.
Rick
Sep 12, 2011 | Dell 926 All-In-One InkJet Printer
Re: The printer will not recognize the installing of a new color cartridge.
after installing a new cartridge you need to open the program for your printer tray and reset your cartridges so that the printer and pc reconize the cartridge is full
Sep 19, 2007 | Dell 942 All-In-One InkJet Printer
My HP F380 all in one does not print at all even tho I just installed another (3rd) new black printer cartridge. Color cartridge is empty.
Stupid printers refuses B/W print jobs when color cartridge is empty. Sorry, the answer is: install full color catridge.
Nov 07, 2010 | HP DeskJet F380 All-In-One Printer
Can I disable the color? It's empty but black is full
even if it is empty, most printers require that you have the color cartridge installed. you have to go into the printer settings and change it there to print only black copy.
Sep 18, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Can't Print with black ink because all color ink are empty.
yes you need to install all cartridge before printing any page ...I have also this model...but u need to install all 4 cartdge. before printing any page wheather color or blacknwhite..
Jan 08, 2009 | Office Equipment & Supplies
Despite installing new cartridges,cleaning and priming, my HP Deskjet 710C prints pink only. Using Windows XP test page shows no blue, or yellow.
hi,
do you installing both cartridges (black and colour)?
if you do so, my advice is to reinstall the driver for your printer.
if you install ONLY the black cartridge, and the color cartridge remain the old one, (which in my opinion is the present case), your problem is from the color cartridge.
The color cartridge have 3 colors and this are: cyan (some kind of blue), yellow and magenta (similar with a pink color, but more intense). The problem is simple: in your color cartridge has left only the magenta color, cyan and yellow tanks are empty.
have 2 options:
1. buy a new color cartridge
2. refill the color cartridge.
Sep 23, 2008 | HP Office Equipment & Supplies
Dell A960 cartridge problem
Does the black cartridge print? If not did you take the tape off of it? Error 50 is a generalized error reading relating to a number of cartridge problems. If the color cartridge is empty, it may be theproblem although I have not found this to be true on Dell printers. If you remove the color cartridge and reinstall it the reading will indicate its full (even though it isn't. This may solve the problem.
Sep 19, 2008 | Dell A960 All-In-One InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
192 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
