Question about Microlux Cherry Wood Finish 7-stage UV Ion Air Purifier with Remote 7 Stage UV Ion Air Purifier with Remote - Cherry Wood Finish
How to clean filters
How can I clean the filters on a Microlux ML4000D Air Purifier? Also, how can I clean the Needlepoint Ionizer? The unit is running, but the air quality doesn't seem to be as good as it was when new.
Unplug the unit. You need to clean the Ionizer plate periodically. Just run it under water and use a clean sponge if you have to. Let the plate dry completely before reinserting it and make sure you put it in the same way it came out. It's marked with arrows on the side that faces the front. The needle itself should be fine without cleaning but if it has some build up on it GENTLY wipe it off with a dry rag. Wipe towards the tip.
As far as the filters go. I haven't had to clean mine. As strange as it seems I get more dust on the front of the machine and the fan than the filters themselves.
Source: I own one of these in black.
Posted on Nov 04, 2015
I need a filter for Amcor Ficus Tree Air purifier
If the activated charcoal filter, take your old one apart and trim down a larger on from a competitve machine to fit yours. The same if it is a HEPA filter you want to change as well.
Otherwise metal and plastic filters can be washed. Spray with a grease cutter like 409, which will also lightly etch the metal without reacting with the plastic.
Jan 31, 2012 | Amcor Ficus Tree Air Purifier & Ionizer...
Where can I get a replacement filter for bap4010?
According to their website:
PERMAtech Permanent HEPA Type filter traps 99 % of all allergens and dust down to 1.0 micron.
PERMAtech Permanent Filter Never Needs Replacement!
Simply vacuum the filter every three months to maintain performance.
Requires less cleaning and maintenance than other permanent filter systems.
Built-in Ionizer assists in cleaning the air from dust and allergens.
Oct 10, 2011 | Bionaire PERMAtech BAP4010-U Air Purifier
How do I clean the ionizer when the check filter light turns on?
with no power to the unit take a soft moist cloth and wipe easy all the wires are flat plates
Apr 14, 2010 | Brookstone Ionizer/ Air Purifier Air...
No problem but can't find replacement filters for my Family Care air purifier/ionizer Model HAP221
Hi just a tip for you, if you can't find a filter you can buy filter media at your hardware store such as Home Depot, and have it cut to fit. It is good material made to replace any type filters. Sincerely,
Shastalaker7
Dec 04, 2009 | Family Care HAP221 Air Purifier
My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Nov 14, 2009 | Alpine Air XL-15 Air Purifier
Ionic Breeze Silent Air Purifier GP
Ionic Breeze products are no longer being supported because Sharper Image has gone into bankruptcy because the units were proven to be ineffective for cleaning the air by Consumer Reports magazine and by EPA studies. In face they have proven that ionizers can be harmful to use if you have breathing problems.
Here is an article about Sharper Image
Here is the EPA article
Jun 30, 2008 | Sharper Image Professional Plus Ionic...
Users Manual for Kenmore HEPA Air Cleaner Model No 85244
I have an kenmore air purifier and cannot locate where to find a replacement filter or manual for it? Can you help. It is Model # D42M32957
Apr 06, 2008 | Kenmore 85244 Air Purifier
Lost amnual
the lights are the ionizer light, the filter indicator light which is the light that will come on when the filters need to be changed, ionizer control button, the speed control and the power light.
Dec 04, 2007 | Bionaire BAP825-U Air Purifier
Annoying ticking
My air purifier was doing the same thing. The ticking noise you are hearing is caused by dust build up on the ionizer pins. When the ionizer pins collect too much dust, they tend to start making the clicking/ticking sound caused by static electricity. The solution is simple. Take the filter out and clean it real good (follow directions on filter on how to clean). Now, with the filter out, if you look down inside the vent where the filter was, you'll see a white piece of plastic with nine holes in it that are about the size of a silver dollar. Directly in the center of each hole there will be something that looks like a needle, those are the ionizer pins and they will probably have dust built up on them. Next, with the filter out, blow out the air purifier with compressed air to clean all the dust off the ionizer pins. This should take care of the problem, it worked on mine.
Dec 02, 2007 | Kaz Honeywell QuietClean HFD-135 Air...
Hepa filter
The red light indicates a plugged filter. Replace the filters plug the machine in and get a paper clip. Streighten out the clip and put it through the tiny hole in the top. You'll feel it push a switch that will give a click you can feel. Keep holding the clip wire down for several seconds. When the red flashes remove the clip wire. The light will stay off if the filter is clean.
Aug 22, 2007 | Holmes Products HAP422-UC Air Purifier
Microlux Cherry Wood Finish 7-stage UV Ion Air Purifier with Remote 7 Stage UV Ion Air Purifier with Remote - Cherry Wood Finish Logo
541 people viewed this question
Top Microlux Baby Care Experts
masud
masud
Tom Chichester
Are you a Microlux Baby Care Expert? Answer questions, earn points and help others
