Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool ED2KVEXVQ01 no power to compressor had this happen a couple times in last to months but found out of level and thought door was staying open and seemed to be fine after that but now down and
Would be nice to have wiring diagram, schematic.
  • 60 Answers
Youll probably find that you need to replace the thermostat they arnt very expensive
Posted on Mar 20, 2014
aborcass
  • 2651 Answers
SOURCE: Whirlpool fridge freezer
trying to open door?? does it feel as if top wants to open ad bottom of door is being stuck shut? or mabye a package of frozen food has shifted of a shelf and is holding the door shut, if so brute force will solve that one.if it feels like held at bottom sounds as if youmight have a clogged defrost drain tube.drain water backing up onto freezer plor and holding door shut. even then forcing door open is only way then removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over.
Posted on Mar 01, 2008
bobicehouse
  • 1524 Answers
SOURCE: Bad Compressor, valve sticking in the compresser
Contact Whirlpool Customer Care about this. There has been a serious problem with the Embraco compressors they are using.
Posted on May 15, 2009
SOURCE: Whirlpool Door Ice Dispenser Not Working
mine froze up in the shute, had to put water down iti
Posted on Aug 26, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Whirlpool 25.6 cu. ft. side by side Refrigerator with in door ice
The process of Refrigeration is for one section to be hot while cooling another section. I.e freezing in one section result in the heat build up and dissipattion else where. Any compressor working properly is going to be quite warm to the point of being hot to the touch when working NORMALLY. There is nothing that you need to do for the continued safe operation of your compressor. If your freezer has ice build up again in the near future your uint is not defrosting properly. If it functions normally after 2 or 3 days of use then you more than likely had a one time buildup of ice usually caused by someone leaving the door partially open
Posted on Jan 03, 2010
SOURCE: whirlpool refrigerator not cooling freezer seems to be working
my icemaker makes ice and water but the ice doesn't come out when pushing the button what is the problem?
Posted on Sep 20, 2010
Erratic garage door opener
It is an adjustment problem. Any obstruction and the door goes up again. So try adjusting again but don't leave space to invite rodents that will cause damage to car wiring. I am just going thru that.
Dec 04, 2013 | Craftsman Sears Liftmaster Garage Door...
The Whirlpool side-by-side refrigerator, model ED2KVEXVQ01 occassionally leaks water onto the floor. There could be a cup or more of water, but the problem has occurred a few times, but may go weeks or...
sometimes we overload our refrigerators and the doors will not close properly, next time you notice the water see if your doors are closed tightly and the seals engaged tightly. My wife has this habit of not checking after she has put away the remains of a big dinner or BBQ and I find drips of condensate water all over the floor as a result. The defrost collection pan overfills and the excess water goes on the floor. once the doors are closed properly the problem goes away.
Aug 03, 2010 | Whirlpool ED2KVEXVQ (217 cu ft) Side by...
Unit is about 5 years old have had tech. come in and looked at it because it would not stay on. The temp. would drop. He stated that the compressor was fine. He did something in the top inside unit by the...
NEXT TIME IT STARTS TO WARM UP, OPEN THE FREEZER DOOR AND TAP OR THUMP THE TEMPURATURE CONTROL. IF THE UNIT TURNS ON THEN I WOULD BET THE COLD CONTROL IS BAD. ORDER PART NUMBER 67003000 FROM YOU PREFERED SUPPLIER OR REPAIRCLINIC.COM
Mar 23, 2010 | Amana ARB2557CSR / ARB2557CSL Bottom...
My Whirlpool Dishwasher cleaning light stays on
Try unplugging the machine from power to reset the program, if that fails you may need the control panel replaced.
Apr 19, 2017 | Whirlpool Dishwashers
Dishwasher only a couple of months old. Ran it
The water may not be hot enough. Increase the temperature of the incoming hot water or try this: put the tab in the open soap cup so it will start to dissolve during the pre-wash. Then it will finish dissolving during the main wash. If the dishes get clean using this method you may not have to increase the water temp.
Aug 25, 2009 | Dishwashers
May 15, 2009 | Whirlpool GD2SHGX Refrigerator
Fills on its own door open or closed
I would bet the water inlet valve is weeping. It may not seal shut every time. It could have a piece of rest stuck in it also. It's cheap and easy to replace. The part # AP3128776.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Radio won't turn off.
The radio should still shut off after 20 minutes even if the door is not opened. If it stays on longer than this there is still a problem..
Jan 25, 2009 | 2003 Oldsmobile Alero
Not keeping cold both frig and freezer side.
First you need to check if the compressor is working properly.
Remove the rear panel and look for a cylinder with bunch of copper lines going in and out. feel those copper lines one of them should be warm and the other should be cold. Also you should hear the compressor working (pretty noisy) when the temperature in the freezer is not cold enough. If the lines are about same temperature and the compressor does not seem to work, the first place to check is the starter relay. Often the relay breaks. The part is WHIRLPOOL 2188830 2220475 RELAY. I found one on ebay.
Good luck
Jan 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Dryer door pops open. leaves burn marks on clothes.
check to see if you have bent door hinges first, do this by opening the door all the way down and see if it is level with the floor. if it goes past level then the hinges are bent.
guess someone may have fell on the door or used it as a step.
if so, then you can take a hand towel and roll it up, then put it at the bottom of the door and close the door gently to "bend" the hinges back into place. this will aloow the door to stay closed and should also take care of the "burn" marks on your clothes.
i would guess the unit was overheating from the door not closing right allowing air to enter around the door. that will cause the unit to overheat and leave marks on your clothes.
Dec 28, 2008 | Kenmore 63942 Dryer
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
43 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
