Question about Philips Televison & Video
Power source Where is the power cord go on the flat screen > been searching and searching. The tv. is about 6 years old.
  • 47 Answers
Turn tv upside down and look on back.
Posted on May 26, 2014
SOURCE: The power cord for my Hyundai E320 flat screen tv
Start by confirming the circuit is hot at the wall. Plug in a lamp or something.
Try your generic cord with another device to eliminate it as a variable.
What sort of cord is it?
Posted on Mar 02, 2009
appman67
  • 33 Answers
SOURCE: how to hook up flat screen monitor??
The new flat screens hook up the same as the old CRT monitors.
Posted on May 03, 2009
  • 11 Answers
SOURCE: missing power cord 12v
go to radio shack get a 12 volt 1500ma power supply with I belive it is a N% plug end but any how 800 ma to 1500 ma should run this and the plug end is standard plug with plus 12 volts on the inner side and negitive on the outer case side look at the back of the TV or the old power supply it sould have info on voltags and amprage, and the plug as to inner voltage and outer voltage on the plug any old time radio shack or electronics shop should be able to help you bring in the flat screen if need be as if you know its 12 volts then It wont mater weather you use a 1000ma 1500ma 12 volt ubnaversale power pack as the tv will only use the current needed so more MA is good the only concrn you have is the right mini barrle plug and the right side of +/- voltage on that mini plug being most use + voltage in the inner most circle and - 12 volts on thje outer
Posted on Jul 03, 2009
  • 11 Answers
SOURCE: Panasonic flat panel just lost power while on,
Me the same some one please help!!
Posted on Mar 20, 2010
SOURCE: how do i tune in a 3 year old philips hd flat
my philips 32 inch flat screen doesnt give me freeview anymore when i scroll down to digital tuner i just get a blue screen
Posted on Jun 10, 2010
Th 37px70ba
Be sure the source(cable, satelite box) has sound output.Have you lost sound from all the inputs to the TV?(try hooking up a DVD player.
If these sources are OK then Most likely the Main PCB is the cause of audio failure, but could also possibly be the voltage source for your audio circuit & that comes from the Power Supply circuit. That's usually @ 12-15VDC.
Nov 24, 2013 | Panasonic Televison & Video
I have a panasonic HD plasma tv. It is about 5 years old. It will not turn on. And a red light next to the power button blinks 10x. Please help!
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Oct 08, 2013 | Televison & Video
X322BV-HD*WXC100
Warranty is usually 1 year parts and labor. Contact mfc for warranty service. likely main board.
May 28, 2013 | Televison & Video
New LG Flat Screen Plasma tv - worked fine and then when we tried to turn it on, nothing at all happened. What could the problem be? Clicker does not activate tv.
Check ur clicker like tries new set of batteries.Check the power source like the power outlet?Yes,tries tv unplug,replug the tv power a/c cord plug back like about an hour later for the tv to do resetting it seft back to the factory setting.The tv now should work again.If still have the same problems,tv have problems,new tv bought it under a year old.Call LG take ur tv warrenty repair.
Jul 20, 2011 | LG 42LC2D 42 in. LCD HDTV
I have a 42pfp5332d/37 plasma tv. I can not turn it on using the remote controller, however when plugged to the AC power source the blue light on the bottom left corner comes on and the screen is black and...
U know basic electronic's and soldering?Take ur tv aparts,where the A/C cord goes that power supply board.Searches all around the power supply board and it supporting boards.Look for these defective parts call capacitors,these capacitors have lekages of gases in one or two years of the tv in used,they alway bulges up it top,puff up it top.These capacitors are dead,replaced them u will stop hearing cliking,and have ur tv power back.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
May 07, 2010 | Philips 42PFP5332D 42 in. Plasma...
Tv has no power. It just went dead. 53 weeks old
Check power source with other devices see if have power?Check A/C power cord for loosen connection.Unplug,replug for temp.fix might work,must change the power board have all source check.
Dec 22, 2009 | Sylvania LC420SS8 LCD TV
Zenith Flat Screen stopped working
Had this several times on a Philips.
Undo all devices check powercord for shorts. My original one had.
Replaced. In following cases cord needed to be replugged, dirt in connection point. These flat screens consume a lot of power (3x conventional) and heat up extensive
Sep 22, 2009 | Televison & Video
How to hook up flat screen monitor??
May 03, 2009 | Televison & Video
Televison & Video Logo
46 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
