Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
Dryer will not stay lit all the time
I recently converted my dryer from natural gas to propane. The burner comes on but will not stay on. It acts like it is not getting enough gas is there something that needs adjusted.
  • 909 Answers
The burner nozles are different on N.Gas and P.gas. They are different sizes as the gas burns differently. So if you have not changed the nozles, do so, if you can actually aquire them from whirlpool.
Posted on Jun 14, 2009
Whirlpool wgd9400swo. Gas clothes dryer The burner only stays lit for 1 minute the new goes out, tries to re-light but can't seem to
The limit switch is bad. most likely or the igniter. Does it give off a gas smell? If it is propane you can really smell it. But Natural Gas You may not.
Nov 08, 2016 | Whirlpool Dryers
Natural gas to propane
the pilot and/or burner orfices need to be changed.depending on your model the gas valve may also need to be converted.
Sep 27, 2007 | Whirlpool GGW9250PL Gas Dryer
How do you convert to propane a kenmore elite model # 79671622310
You have to get the conversion kit. Mostly the burner gas nozzels has to be changed. Propane has a higher BTU value than natural gas. So the burner nozzle has to be smaller with propane.
You have to have the right nozzle kit for your dryer. Normally the propane nozzle kit comes with the new dryer. It is attached in a plastic seethrough bag and attached somewhere in the back of dryer.
Also you have to adjust the air opening in the burner for propane. Propane need more air than natural gas to burn properly. If you buy the conversion kit or find the conversion kit in the back of your unit, it will clearly give instructions how to do it.
Sep 26, 2014 | Dryers
Patio glow outdoor propane fire pit does not stay lit
Fire pits motivated by gas. Need suffocation. A natural fire needs oxygen. Gas fires need suffocation. Take the wood or rocks and make it tighter over the gas holes. Meaning Pile the rocks on top of gasoline tighter or more generously so the gas and the flame are not coming out hitting straight oxygen. Give the fire something to hold onto. Natural fires need the opposite. Propelled fires need a sauna /steam room / hot rock type of relationship.
Aug 13, 2014 | Heating & Cooling
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
I have a older 40,000 BTU 3 burner natural gas deep fryer. I would like to convert to propane gas. The orifice number is size 32. Do I need to get different orifices to convert? The serial number is...
Hi there.
Burner orifice size for propane gas is number 55. You have to replace all burner orifice with this size if you want to use the fryer with propane gas. Pilot burner orifice should be replaced with propane pilot orifice.The gas valve spring should also be replaced with propane spring kit. The difference between the two spring is the natural gas spring is lighter or thinner compare with the propane gas valve spring.
Regards.
Jul 13, 2011 | American Range AF40 Deep Fryer
Can the minimax natural gas be converted to propane like a laundry dryer ?
Check out this link: http://ths.gardenweb.com/forums/load/pools/msg0522222224880.html
Per this link, these are the parts that you'll need to replace:
Natural gas burner tray 472028
Propane burner tray 471931
Propane gas valve 471671
Remember to always be safe around electricity and gas lines. If you're not sure then hire a professional.
If this has helped, please give me the appropriate thumbs up! Thanks, and good luck!
Aug 15, 2010 | Pentair Pool & Spa
Liquid Propane vs. Propane (like used for BBQ)
They are the same thing.
The propane you buy for your BBQ is liquid in the bottom of the tank. At the top, it comes out as a gas, which you run through a regulator and then into your grill. If you by some chance turn the tank sideways, the valve inside will shut and keep the liquid propane from coming out. If it did you could have a serious fire.
However, there is a difference between what most folks call "Natural Gas" and propane. If you have gas piped into your home, it's natural gas and not propane.
Natural gas dryers won't run right on propane (LP Gas) and vice versa. There is usually a conversion kit you can buy to switch them over.
Oct 14, 2009 | Dryers
Convert propane dryer to natual gas
You need the NAT gas orifice and the stem under the cap on the burner needs flipped over
Jun 08, 2009 | Whirlpool GGX9868J Gas Dryer
Dryer has been converted to propane using conversion kit #131776600 and I need the info needed to get it back to run on NG The dryer is a Fidgaire Gallery series model #FDGC648GHS0 any help greatly a
Hello there. If the parts were saved, they can be reused. If not, contact your propane provider and tell them that you plan to convert back to natural gas. They will be able to get you the kit you need, and will possibly have a technician come out and install it for a fee.
May 27, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Open Questions:
See all Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Questions
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Logo
129 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
