Question about DeLonghi Coffee Makers & Espresso Machines
New Delonghi ec860.M coffee maker. On switching on light B8 continues to flash. No motor noise. Have checked connections, filters and cup warmer works. Nothing is happening. Have lect on for 30 minut
The product arrived with a EU plug. On contacting the company they sent an adapter for the plug. It is clunky nut the standby light works, the cup warmer light works and heat does come from the top. The only problem is tat the top right light just flashes (B8)
  • 123 Answers
SOURCE: instruction manual for delonghi combi espresso/filter coffee maker bc0255
http://www.delonghi.co.uk/pdf.php?key=Coffee%20Machines
Your manual is listed on this page and you will be able to download it.
Good Luck.
Posted on Apr 10, 2008
  • 333 Answers
SOURCE: Brand New Nespresso Essenza just stopped working..
If you just bought it you should return it immediately and try another.
Posted on Dec 24, 2008
SOURCE: standby light is flashing
I had the same problem with my machine and managed to get it working again in a few easy steps. This machine is great but it can be VERY tempermental so here are a few tips:
1.The barcode reader MUST be clean or it will not read what the disc is (It is the little glass screen where you place the disk.) If it is not clean the lights will all flash.
2. The little floaty thing in the water container has to be floating in order to keep the machine running- if it won't float, shake it well to dislodge the air pocket that might be jambing it.
3. If the red stanby light won't go away, it is because the disc you are using is either damaged or leaking and it WON'T go away until you replace the disc...(you might have to do it more then once) if that doesn't work- try hitting the reset button on the back of the machine (the little black switch that has a (- and o) as well as unplugging and plugging the machine back in. Lastly, what worked for me was inserting a new disk and only partially clicking in the disk so the 'heating' light came on- leave it like that for about 10 seconds and then very slowly close the disc completely. Hope this helped!
Posted on Feb 25, 2009
  • 5 Answers
SOURCE: Braun Tassimo Coffee maker quit working
Hmm if not in covered try
http://rapidshare.com/files/238159116/Braun_Tassimo_3107_Disassembly.pdf.html?killcode=397312781122638452
Posted on May 28, 2009
SOURCE: Coffee maker not working
I've got a B50 as well, and none of these solutions are quite accurate. The problem is with the ball valve directly above the top needle. You first need to remove the handle by taking out the screw on either side. Mine is some size of torks. Then open the hood and remove the two screws from under it. The hood then lifts right off the body. There is a rubber hose that goes into the top part of the ball valve; this must be removed. You can then use a slightly bent paper clip to reach in carefully and push the ball down to unstick it. It is being pushed up by a spring from underneath, so coming from the bottom with a paper clip just pushed it up tighter in the seat. Once it is clear again, put the hood and handle back on.
I think Keurig should send free replacement valves, maybe better designed as well so they don't stick anymore. If not, I am going to see if I can purchase a replacement.
Posted on Jan 06, 2011
Red light keeps flashing all the times
Witch red light?
Could be that the red light telling you to descale the unit is flashing.
if so then you have to descale the unit...see manual
Oct 05, 2016 | DeLonghi Espresso And Cappuccino Maker -...
My delonghi ec860 red light keeps blinkin when coffee finishes coming out what does that mean.
Robert is it the light that has two signs underneath, if so then it is time for descaling.
kolbrun
Jan 23, 2015 | DeLonghi EC860 Silver Espresso/Cappuccino...
Brand new machine, out of packing. No self test, just green flashing water light. No noise, nothing happens at all when button is pressed and held, pressed and released.
I think I would start by contact the seller and ask why a brand new machine behaves like that.
Then there is always the troubleshooting chapter in the user manual. If yours isn't handy you can always get it here Free User Manuals and Owners Guides ManualsOnline com K
Jan 13, 2015 | DeLonghi Die-Cast Pump Espresso Cappuccino...
PAC N125HP has switched off and is not working.. On off button flashes
Check the heating element. Use an ohm meter to check it. The reading should be 0 - 150 ohms. If it reads a much higher number or a 1, the element is no good.
Feb 16, 2014 | Delonghi DC514T 14-Cup Programmable Coffee...
How do I reset my delonghi ec860
my coffee machine is not working,,, the water ligh is blinking green n not doing anything.. anyone can help with this?
May 18, 2012 | DeLonghi EC Coffee Makers & Espresso...
I have a DCR902T coffee maker. The red ON/OFF light is continually blinking, and pressing the ON/OFF button does not turn it off. Disconnecting the coffee maker does not change the problem. No idea what...
This is telling you that it is time to clean the coffee maker. Press the minute and hour buttons at the same time and hold untl the light stops flashing. Take out the water filter and fill the water tank to 10 cups and add 2 cups of white vinegar. Put the water tank back in, without the water filter. Take out the permenant coffee filter. Turn it on and leave it until about half the water goes through. Turn it off. Let it sit for about an hour, then finish the job. Then, run 2 pots of clean water through. You are good. It will notify you to clean your system every 40 pots or so.
Jul 29, 2011 | DeLonghi DCR902T Coffee Maker
Coffee Makers & Espresso Machines Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
