Question about Denon AVR-X2000 In-Command 7.1 Channel 4K Ultra HD Home Theater R
I have a denon avr-x2000 all hdmi ports except the cab/sat are fuzzy. it started with the PS3 on the game port
I tried switching the ps3 and the sony blu-ray player to different hdmi ports and all i get is a blinking screen that is also fuzzy
    Genius:
  • Denon Master
  • 1,342 Answers
Plug your ps3 and/or blu-ray directly into the TV and see what it looks like. use different HDMI cables to test them. Once you know that all works then setup your avr-x2000. Does the Denon menus look fuzzy?
Posted on May 11, 2014
Denon AVR and PS3 issues
Sounds like a problem with the digital board. Expensive fix - hope it's still under warranty.
Jul 02, 2013 | Audio Players & Recorders
I am trying to connect ps3. (bought may 2012 with uncharted 3). To my denon 2313 via hdmi. No video at all or sound? Please help
You need to tell the PS3 to use the HDMI cable output. To test have you tried connecting the PS3 directly to the TV. Once you have that working then add in the AVR.
Jan 19, 2013 | Denon AVR-2313CI
Fuzzy picture on PS3.
my ps3 just switched from a component tv to hdmi but the screen is fuzzy and off color and i've tried reseting the system but it's not working. help?
Dec 30, 2009 | Sony Playstation 3 (PS3) Console
After installation of ps3 and blue -ray disc remote control. tried using remote to turn on and play a dvd dics to no avail nothing works the ps3 player nor the remote does't appear to recognize each other...
Ive had the same problem with mine. I have a universal remote and a blu ray player separately installed on my tv. The only way i was able to play the ps3 without calling geek squad to reconfigure my tv was to unplug the blu ray and put the ps3 in its spot and push watch bluray. It worked great.
Nov 29, 2009 | Sony Playstation 3 (PS3) Console
I have my PS3 and TV hooked up to the HDMI ports. I have programmed the unit to show them under TV and DVD respectivly. When I change the source to TV or DVD, nothing shows up on my TV as expected
Sounds like you hooked them both up to HDMI input ports. Make sure that the PS3 is connected to an HDMI input port on the AVR-1508, and that the TV is connected to an HDMI output port (not an input).
Oct 21, 2009 | Denon AVR-1508 Receiver
Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Dec 12, 2008 | Denon AVR-2800 Receiver
PS3 setup to Denon AVR 2807 & Samsung LCD
Azahid
Since you are running the to LCD monitor instead of a LCD TV this is where you run into the issue. because the monitor is not setup to pull out the audio from the HDMI connection. So there is a few ways that you maybe able to to this.
The first one is look around at the different output cables out there the PS3. (I just got one so I do not know the accessories that are out for the PS3) This is becoming a common setup so if Sony does not have cable that will split off the audio then a 3rd party group may. I know they have one like that for the XBOX 360.
Another you can try is if your monitor will except an analog connection you may need to go that way. That is how I have my XBOX 360 that is my room connected. I have a RBG HD to VGA connect the VGA input on the monitor and the audio going to my sound card.
The reason why I suggested going analog is that right with our curent technology that if you are run with the 2 formats at the same time you will get audio/video sync issues. So you need to go all analog or all digital.
I hope this helps. Let me know if you have any other questions on this and/or need me to clarify anything.
Issken
Sep 29, 2008 | Sony Playstation 3 (PS3) Console
I cant hook my PS3 to the surround system for Sony DAV-HDX275W
what exactly is the problem? no connections? or connected and cannot get it to work?
Aug 31, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Denon AVR 588 7.1-- Sound setup questions
This reciever does not decode the audio through HDMI, the HDMI ports are simply a pass-through. To get audio you need to connect an optical audio cable from the PS3 to the reciever also. I figured this out after 2 hours of trying to get audio from the HDMI cable. Here is a link that shows the different audio formats supported through HDMI by the different Denon models. It looks like the AVR-788 is the lowest model that supports audio through HDMI. Hope that helps.
Apr 03, 2008 | Denon AVR588 Receiver
Denon AVR-X2000 In-Command 7.1 Channel 4K Ultra HD Home Theater R Logo
113 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
