Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
The highest deck setting cuts my grass down to one inch.
How can I raise my deck higher?
  • 97 Answers
Leveling bolts hang from each side deck by frame...tightened up and level...will give you some more room....be sure the blades are not bent.
Posted on Jun 14, 2009
I have a riddeing lawn tractor and on its highest setting cuts grass too short how do i raise the deck to get a taller grass
if you look under lawn mower were the deck attachs you will see the adjustment rods unhook one at a time to adjust ether screw the rod in or out do this on a driveway so you can measure with the tape measure how for you or lifting deck and can match hight on both sides
May 14, 2014 | Yard Machines 13AC762F000 38-Inch 344cc...
How to raise cutting hiegth
wow, and you think we know what kind of mower you have ?!?!?!
May 14, 2014 | Yard Machines Garden
Troy Bilt zero turn Mustang Xp 50" deck height. My
raise the back as high as you like but unless you raise the front as well it will still cut short. If you want it higher and there appears there is no adjustment left you may have to re thread the adjusting screws to shorter dimensions or if it is on levers you may have to drill new holes further up the bars.
Jun 02, 2013 | Garden
At the highest setting, I still cut the grass to short
The deck may be installed in the incorrect position on your tractor (if this is a tractor). If you have the owner's manual, check the information for installing the cutting deck. If not, then check the action of the lever and deck when raising it and lowering it, to verify it is working properly.
Jun 08, 2011 | Garden
2010 Craftsman Lt 2000 deck height adjustment?
just bought a new craftsman riding mower. model lt1500. 17.5 hp with 42 inch deck. first time using I had the deck hight handle set on 6 the highest setting and still cuts grass to short, matter of fact it scalped the grass. anyway to set the deck higher. Its only 3 days old and still under warranty but the sears store is 20 miles away and I rented a trailer to go pick it up and hate to go rent another trailer to bring it back if its just a simple adjustment.
Jul 31, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Uneven grass cut, makes the lawn look striped.
First make sure all the tires have the same pressure of air.
Then I would measure how much the one side of the deck is higher than the other. Then I would look under the tractor and there should be a horrozontal bar atatching to the deck and a bar coming down from the mower into this bar. usually there is a nut on the bottom than can be tighened or loosened to raise or lower the deck on that side.
There might also be a nob on the tractor that shows a picture of tall grass being cut, if you turn that that might also raise or lower the deck on either side.
Apr 22, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Even on the highest setting, it still cuts too low. can i adjust it to cut higher?
When you put it in the highest setting can you see the deck actually moving in an upward direction? If not the linkage might be broken or damaged. When you raise the deck up or down with the lever it should move, a deck setting in the full up position is a pretty high setting you have to have some long grass to be cutting in the full up position and still think its to short. You might be able to reposition the deck, if when you look under the unit you see a bracket that controls the deck height setting that has a number of holes in it(maybe even 2 brackets), there should be a pin(s) in one of the holes this could be set in a low position and therefore you can change position to change height of deck.
Oct 15, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Deck not high enough
Assuming this is a Craftsman, there is an adjustment for height, but mainly just for leveling purposes. There is a nut on each side in the center of the hanger and unless these are all the way to the bottom end, it's not going to raise the deck that high. I would look carefully at the deck hanger mechanism on each side. Something is obviously not right. Has it always been like this, or did you just get the mower? You can go to.. http://www.searspartsdirect.com/partsdirect/index.action Then enter the model number that's under the seat, hit search, then scroll down to Lift Assembly for a look at how it is set up. I have seen broken hanger rods as well as a broken weld on the lift handle where it's attached to the cross shaft. Hope this helps..
Jun 28, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
570 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
