Question about Kodak EasyShare C613 Digital Camera
Easyshare c713 screen will not light. camera will come on.
Kodak easyshare c713 screen will not light. camera will come on.
    Top Expert:
  • Kodak Master
  • 6,702 Answers
If your camera is in display mode, and the screen stays dark, check the memory settings. (internal / memory card)
Put the main dial to automatic and shoot a picture, to see is anything comes on the screen.
Posted on Mar 21, 2014
  • 3 Answers
SOURCE: LCD Screen
I was told by a Kodak tech that the cameras are identical. The different numbers were a marketing thing.
Posted on Aug 09, 2008
SOURCE: Kodak Easyshare camera turns on and off
Hi, here is whats going on, if your M763 is powering on for 2 secs and the lense opens up then go's right back in, there is a 90% chance you got sand in the unit from say the beach ?
here is a test , when you press the power buttion watch the lense you will notice that the bigger part rotates as it comes out, what you want to do is give it a little help Lightly rotate it abit more just at the point where it normaly stops and go's back in, the cam will prob stay on and work like normal.
now the hard part 2 things to try, a can of AIR from walmarts try to blow out and sand thats around the rings, i did this and have fixed about 20 of these's now, on the others you will need to take it apart and clean the gears and mech of the lense housing then put it all back together.
hope this helps
IST tech
Chris
Posted on May 26, 2009
Jaap Davids
SOURCE: cannot turn on my Kodak easyshare c713
Hi I had the same problem with my daughters c713. Tried several bateries found out that the camera is specific with its bateries brand. When i put in new ones from kodak itself from my sons camera a c913 the c713 turn on again. Tried a new pack local brand checked them first and voltage was ok but didn´t work again. Back in those from kodak and ok again. Tried philips also ok.
So try different brand and find out. Good luck.
Jaap Davids The Netherlands
Posted on Jun 20, 2009
leepania
  • 1099 Answers
SOURCE: Kodak easyshare M893 IS will not stay on. The
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Nov 23, 2009
  • 3 Answers
SOURCE: kodak easyshare c713 showing lens error 221,0,0,0.
KODAK C713 LENS ERROE 20E 1,0,0?
IT DID NOT RESOLVE AFTER PUTTING NEW FULL CHARGE (AA) SIZE BATTERY EVEN , WHEN I TURN ON CAM IT SHOWS ERROR 20E 1,0,0 AND SHUT DWON.
Posted on Jan 15, 2010
Kodak C713 LCD Problem
I've not worked on a C713 before, however I've worked on many Kodak cameras and LCD replacement is one of the easier tasks. Although this is best to have done by a trained technician, many consumers can indeed change the LCD themselves. It requires patience and dexterity as well as extreme care when performing any maintenance on a digital camera. First you want to ensure you are wearing a grounding strap, or are standing on a non-static surface. Once you remove the rear cover screws, carefully remove the rear cover so you can get to the LCD. To unplug the LCD ribbon cable, sometimes an additional metal plate must be removed. You then need to carefully lift the tiny plastic bar that retains the ribbon cable in the connector (these break easily!). Install is the reverse of removal. Hope this helps.
Apr 26, 2010 | Kodak EasyShare C713 Digital Camera
My kodak c713: just recently have the seized and
It is not possible to buy a LCD for KODAK cameras.
If the camera is Out of Warranty repair for this model for this fault is about 48 pounds + shipping. KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
In order to arrange your repair/Trade up: Contact KODAK:
Jan 18, 2010 | Kodak EasyShare C713 Digital Camera
It looks like i took a picture of shattered glass
Sounds like the LCD is faulty. But in order to avoid a repair.
Please try to upload new firmware:
If this doesn't work I'm afraid it'll be a repair.
Connect the camera with the computer.
Turn the camera on.
Click onto the link and follow the instructions.
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=11887/11895&product=EKN034494
Jan 10, 2010 | Kodak EasyShare C713 Digital Camera
Kodak easyshare c713 showing lens error 221,0,0,0. what does this mean.
Dec 31, 2009 | Kodak EasyShare C713 Digital Camera
Have mislayed english instructions please advise sinple steps to eliminate red eye and set it on camera all the time
You can download the required manual by clicking this link
For more details, visit Kodak C713 support page by clicking this link
Hope this solves your problem. Thanks.
Oct 20, 2009 | Kodak EasyShare C713 Digital Camera
White out LCD screen
Try a manual reset. Remove the card and battery...press all the buttons...leave the camera alone for 20 minutes...insert the card and then the battery...turn it on.
Oct 05, 2009 | Kodak EasyShare C713 Digital Camera
Cannot turn on my Kodak easyshare c713
Jun 17, 2009 | Kodak EasyShare C713 Digital Camera
Easyshare C713 LCD view is flushed out.
you push on the little 'i' button thats right under the delete button.
May 14, 2009 | Kodak EasyShare C713 Digital Camera
My kodak easyshare c713 ...
you cannot turn on the flash while taking a video
Dec 27, 2008 | Kodak EasyShare C713 Digital Camera
LCD Screen
May 31, 2008 | Kodak EasyShare C743 Digital Camera
Kodak EasyShare C613 Digital Camera Logo
41 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
