Hasbro Fur Real Friends Smores Pony Logo
Heather Cook Posted on Mar 20, 2014
Hello so my boyfriend got my daughter this used furreal Pony and the pony resently stopped walking what can I do to fix it
Can you email me the solutions please and thank u my email is [email protected] and my name is Heather
4 Related Answers
Anonymous
  • Posted on Dec 29, 2008
SOURCE: Furreal Pony neighs like a broken record
I had the exact same problem, and all I did was replace the batteries. It worked right again! I just knew the kids had broken the neck of it. It sort of slings to the left and neighs over and over again. BATTERY ISSUE :) The instruction manual should tell the consumer this. Hope this helps!
Anonymous
  • 8 Answers
  • Posted on Jul 23, 2010
SOURCE: Hi, Where can I buy a new tail for my
Not sure where to buy a replacement but I just fixed mine today. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of plastic tubing with 1/4" inner diameter and 3/8" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the hole. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. The end of the tube with the hole should be just visible. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
Anonymous
  • Posted on Dec 09, 2010
SOURCE: Replacement parts for furreal smores pony
I need a carrot and a harnessm movers lost this on me. how do I get a new one or used.
lisaf
Lisa Fletcher
  • 47 Answers
  • Posted on Dec 01, 2011
SOURCE: furreal pony head clicking when moves
More information would really help :) Is this a new sound? The animatronics make S'mores sound like a middle school robotics project rather than a horse. It sounds like you should contact Hasbro's customer support at 1-800-327-8264 for their expert advice and response. :)
Can I buy carrot and brush for furreal butterscotch pony
Hey, replacement parts for Butterscotch can still be found on ebay, here's one: https://www.ebay.com/itm/263543016418
Charger
The Furreal Butterscotch pony is operated by 6 D sized batteries.
To replace them open the velcro on her belly and loosen the screw holding the battery compartment. You can then replace the batteries and turn the pony on after repeating the procedure backwards.
Butterscotch pony head not working
First, calling poor Grace at Hasbro will provide fruitless. Hasbro does not make any parts for the full size FurReal Ponies, they have nothing in stock and cannot help you. I, however, can. I am going to post a link to a distressing site that turns the normal FurReal Pony into a fire breathing demon. However, in the process, you can see the diagram of the skeleton of the pony and head. You can search for other links but this is pretty comprehensive. Just don't open when kids are around.
Lisa
http://www.instructables.com/id/Make-a-Fire-Breathing-Animetronic-Pony-from-FurRea/
Butterscotch pony makes gallop sound but very loud whirring noise at same time and head doesn't move side to side
Hey, that sounds like something in your pony's neck mechanism broke. Sadly Hasbro doesn't repair these ponies anymore and you have to investigate it yourself. You can follow this tutorial on removing the head: Hasbro FurReal Friends Smores Butterscotch Pony Head Removal How To...
Furreal freinds butterscotch pony doesnt have gallop noise
Hey, are you sure you are applying enough pressure in the pony's back? It needs to compress fully in order for the 'Riding mode' to activate.
My daughter has broken off her furreal pony's ear can it be sent away to be repaired?
you should ask a professional to fix it but i dont know and how did your daughter break it .hope it gets fixed ^^
Top Hasbro Toys Experts
ZJ Limited
ZJ Limited
Jesse Walters
Jesse Walters
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
