Question about JVC AV-27230 27" TV
Clock what procram ??
How to set clock ON GE- JB860SJ1SS
RANGE SETTING THE CLOCK NON-ELECTRONIC CLOCKS: To set the clock:
  1. Push the center knob in.
  2. Turn the clock hands to the correct time. If the Minute Timer pointer should also move, let the knob out, and turn the Timer pointer to OFF.
DIGITAL CLOCKS: To set the clock:
  1. Push in the center knob of the Minute Timer.
  2. Turn knob in either direction to set the Digital Clock numerals to the correct time
ELECTRONIC CLOCKS: To set the clock (models with Clock or Set Clock pad):
  1. Press the Clock pad
  2. Press the + / - pads or number pads (depending on model) to set the time.
  3. Touch the Start pad. The time of day will show in the display.
To set the clock (models without Clock or Set Clock pad):
  1. Press and hold the + and - pads for 3 seconds.
  2. Press the + / - pads to set the time.
Nov 05, 2017 | Audio Players & Recorders
Elements work but both ovens and clock face are off
Reset breaker or unplug and restart stove. Open back of stove to clock face and make sure the harnesses are tightly fitted to clock board. You could even remove and reinstall the harnesses to the clock board.
If able, check for 120v to clock. If clock is getting power but not lighting up, replace clock.
You did not say whether the clock controls the oven; ie. oven does not work when clock is off. if so, replace clock. If not, ignore it unless you want to know the time from that clock.
Oct 20, 2013 | Maytag GeminiĀ® MER6765BA Electric Kitchen...
How do i set my clock on my pioneer deh-p7800mp
Here is the link to your manual:
http://www.pioneerelectronics.com/vgn/images/portal/cit_11221/310077279DEHP7800MPOperationManual.pdf
Setting the clock
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select Clock.
Clock appears in the display.
2 Push MULTI-CONTROL left or right to
select the segment of the clock display you
wish to set.
Pushing MULTI-CONTROL left or right will select
one segment of the clock display:
Hour—Minute
As you select segments of the clock display
the segment selected will blink.
3 Push MULTI-CONTROL up or down to
set the clock.
Pushing MULTI-CONTROL up will increase
the selected hour or minute. Pushing
MULTI-CONTROL down will decrease the selected
hour or minute.
Notes
! You can match the clock to a time signal by
pressing MULTI-CONTROL.
— If the minute is 00 to 29, the minutes are
rounded down. (e.g., 10:18 becomes
10:00.)
— If the minute is 30 to 59, the minutes are
rounded up. (e.g., 10:36 becomes 11:00.)
! Even when the sources are off, the clock display
appears on the display. Pressing CLOCK
when the sources and feature demo are off,
turns the clock display on or off.
Turning the clock display
on or off
You can turn the clock display on or off.
% Press CLOCK to turn the clock display
on or off.
Each press of CLOCK turns the clock display
on or off.
Note
appears on the display. Pressing CLOCK when
Cheers!
Jan 03, 2010 | Pioneer DEH-P7800MP
I need to know how to set the clock pioneer deh-p6500 thank you
Here is the link to you manual:
http://www.pioneerelectronics.com/pio/pe/vgn/images/portal/cit_11221/50163operation_manual_DEH-P6500_2003117151397330.pdf
Setting the clock
wish to set.
Hour—Minute
set the clock.
hour or minute.
Notes
10:00.)
on or off
on or off.
on or off.
Note
Cheers!
Dec 04, 2009 | Pioneer DEH-P6500 CD Player
How do i set the clock on a pioneer car stereo
http://www.pioneer.co.uk/uk/support/manuals/DEH-2700R/index.html
Setting the clock
wish to set.
Hour—Minute
set the clock.
hour or minute.
Notes
10:00.)
on or off
on or off.
on or off.
Note
Cheers!
Nov 24, 2009 | Pioneer DEH-2700 CD Player
How do i set clock on pioneer deh 1800
here is the link to your manuals:
http://www.pioneer.co.uk/uk/support/manuals/DEH-1800R/index.html
no instruction in there for setting clock!
usually is the same here are the usual instructions:
Setting the clock
wish to set.
Hour—Minute
set the clock.
hour or minute.
Notes
10:00.)
on or off
on or off.
on or off.
Note
Note: on some models you can only set the clock with the clock on display and power off on radio.
Cheers!
Nov 10, 2009 | Pioneer DEH-1800 CD Player
I want to see the clock on my microwave amana rcs820bl
Set the clock?
Normally one of these combinations will work:
CLOCK > 1 > 2 > 3 > CLOCK
CLOCK > 1 > 2 > 3 > START
CLOCK > CLEAR > 1 > 2 > 3 > CLOCK
CLOCK > CLEAR > 1 > 2 > 3 > START
Please write back if you need further help.
Sep 07, 2008 | Amana Microwave Ovens
Audio trouble with my tv
use your remote . manually fine tune your tv.
May 05, 2008 | Toshiba 27A33 27" TV
Clock Problem
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If you don't have the manual, the usual sequenceof clock setting is one of these:
Clock > digits> Clock
Clock > digits> Start
Clear > Clock > digits> Clock
Clear > Clock > digits> Start
Clock > Clear > digits> Clock
Clock > Clear > digits> Start
Otherwise, it may be hard to help beyond this, since it;s been a long time since Toshiba made microwaves.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 17, 2008 | Microwave Ovens
JVC AV-27230 27" TV Logo
16 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
