Question about Iomega Ext.DVD Id +/- Rw USB2.0 HD Burner
DOOR NOT OPENING
DRIVE IS NOT REGNENIZED BY MY COMPUTOR AND DOOR DOES NOT OPEN
    Master:
  • 397 Answers
It sounds like either the drive is faulty or the external shell the drive uses is faulty. Try swapping the drive into another caddie.
Posted on Mar 20, 2014
How do you get your internet phone data to work on home computor
Unplug USB from charger and plug it into USB port on computer.
Open "My Computer" or "This PC" and you should see your phone listed. You can open it just like any other hard drive and navigate to the folder where you have the data to copy or move it to your computer.
Sep 07, 2014 | Samsung Galaxy S 4G Cell Phone
Where is the computor located
Remove the glove box door. The PCM in a Grand Am is located behind the glove box. You do not need to remove the entire glove box, just the door. Remove the glove box by opening the door any emptying its contents. Squeeze together the outside part of the glove box that becomes visible while open. Squeezing it will release the clip from its fastener, and the glove box will slip right off.
Thanks
Tom Miller
Aug 21, 2012 | 2000 Pontiac Grand Am GT
Can't save file in hardisk
connect the hard drive via your usb port, go to my computor and left click to open, then right click on your hard drive icon on the drop down bar click on open or explore, then find the file you want to download, right click on it and select on the drop down my documents and it shall download to your PC
Feb 27, 2011 | Western Digital WD Passport 250GB Portable...
How do i downloag music stored on a file in the computor to my card to put in my phone. I put the card in the computor and it dont tell how to use it
first insert your card to computer, use card reader your card will show as removable disk
if the card was show, open windows explorer, search music that you wan to download to card
select the music file that you want to insert to card
right at file that you select then click copy
after that go to removable disk drive, open it, open the folder music/sound
at that folder right click and click at paste
and you done the process download from computer to card
eject your card from your computer
insert your card to the phone and you canplay music at your phone
i hope this helpful
thank you for using fixya
Feb 07, 2011 | SanDisk 2GB microSD Memory Card
DVD Drive door will not always open. No obstructions. DVD Drive light flashes, but door will not open. Is ther some software conflict?
The door drive motor may be frozen.
  1. Shut down the computer and unplug it.
  2. Open the computer casing to access the DVD drive from inside.
  3. Disconnect the cable on the DVD drive leaving only the power supply connected to it.
  4. Turn on the computer.
  5. Push the OPEN/CLOSE button on the DVD drive. If it does not open, the drive is broken or the door drive motor is defective. If it opens, push the button repeatedly to open and close the door repeatedly to release any frozen part.
  6. If the door does not stuck anymore, shut down the computer.
  7. Reconnect the cable and turn on the computer.
Oct 30, 2009 | Sony Computers & Internet
I have a 22 Cu.Ft. GE refrigerator. The freezer works perfectly, however the refrigerator section stopped working. I cleaned the motor in the back and the blower fan turns. Any suggestions?
Ge has many issues, but the most common is defrost problems, computor board problems or motorized damper door issues. Defrost problems you would see frost build up on the rear freezer wall, computor pc problems fans cycling on - off . Damper issues not opening fully or not at all. A little home work fist though.
Sep 01, 2009 | Refrigerators
Door ejecting
If you have a decorative bezel or door over your drives, that may be the problem. Sometimes the door presses on the drive release switch. Decorative bezels, meanwhile, have a spring-loaded extension button that goes through the extra case material to press the drive's actual release mechanism. I've seen a faulty spring on this type of arm cause a drive tray to go in and out at random, come out part-way and go back in, etc. — all without anyone touching the button itself. The effect is almost as if the drive is possessed. Kind of spooky when it happens, but fixing it is usually a simple matter of adjusting the spring or just removing the bezel completely (since it's only decorative). Alternatively, you may have a trojan on your machine that either fools with the drive automatically, or gives remote access to the drive so that someone else can toy with your machine over your network connection. "OfficePoltergeist" is a program that pranksters love to use to do this. NetBUS is another example of a remote tool from many years ago that could play with your CDROM trays. Your antivirus or spyware scans should be able to detect this, though... It is possible you have a new trojan of this sort that is not yet detected by antivirus software...
Oct 08, 2008 | Compaq Presario SR1810NX Sempron 3200+ 1.8...
Can't find where to put in A cd IN MY EMACHINES COMPUTOR
If you open "My Computer" and right click on the cd drive and click eject, the drive should open revealing itself.
Some drives don't have a tray that eject and you'll have to find the slot to slide it in. This is generally only on laptops though.
Sep 04, 2008 | Computers & Internet
Chamberlain garage door opener won't close
read manual, if you have, on trolley engagement
May 30, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Pen drive
format it this will solve ur prob.
May 19, 2008 | Computers & Internet
Iomega Ext.DVD Id +/- Rw USB2.0 HD Burner Logo
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
