Question about Astak Home Security
How do i convert my astak rca to connect to my pcs usbs
Adapter
3 Suggested Answers
jyvibar
  • 148 Answers
SOURCE: USB to Ethernet adapter for printer
to run your printer on the network follow this steps. ist add your printer in your 1PC then share it. then add printer to your pc3, pc4.
To do this go to Start Menu/printer and faxes/add printer/follow add printer website. Do this process again to PC2, PC3
Posted on Mar 16, 2008
  • 4234 Answers
SOURCE: i have old tv with rf connection need to adapt to rca plugs
Simply insert the converter between the curent cable and the TV. The converter should have come with a short RF cable that you can use between teh converter and the TV. I have incluede a before and after line diagran below.
Dan
BEFORE: cable==> TV
AFTER: Cable==> converter ==>TV
Posted on Feb 25, 2009
How do i setup a astsk 840t wireless camera with a astak 2.4 wireless reciever to a tv with rv jacks ?? What jumper do i buy??
Hello James Waligora,
I've had a lot more trouble trying to decipher what we are talking about "rv" jacks ...
and since you provided ABSOLUTELY NO CLUE about the
"TV" ... I'm just going to BULLDOZE ahead with
my OWN conclusions... "TYPICALLY" will be used a lot.
ASTAK 2.4GHz cameras are a pretty straight forward
set-up ... with the receiver POSITIONING being your only challenge... Two REGULAR Twin LEAD RCA jack ended
cords should be sufficient... LEAD LENGTH is for your ease of adjusting for best reception.
If you already have ECHO, ALEXA... x10 devices (etc.) you
can TYPICALLY expect interference
The yellow is all you need for "video" the OTHER
you can stick in the red or white audio input of your "TV"
for sound (red typically means right side
(Left being what's left... again typically white)
STAY AWAY
from the RED, BLUE GREEN inputs...
While they are VIDEO... they are called "composite"
and ARE NOT COMPATIBLE with your single lead
Yellow corded RCA PLUG...!!
** Don't even try: Not compatible... not.
TYPICALLY 2.4 GHz is low power straight line
(easily interrupted radio signal that is over used)...
ASTAK instructions:
(ah... ) they do come with manuals... but the FIRST SITE
I attempted to access for you set off EVERY internet security protection I have... EXERCISE CAUTION THERE...!!!
Audio Video Cables ShowMeCables com
Astak 811T Wireless DIY Mini Spy Surveillance Hidden Pinhole Color Video...
Nov 12, 2016 | Astak Home Security
Can I connect my i pad wirelessly to my hp pcs 1210
yes using the usb cable but remember you will have to download itunes from apple website n have to download a converter to convert audio or video data for your ipad to accept it
Oct 02, 2015 | HP Office Equipment & Supplies
What comes with a "astak cm918t night vision security camera"? How do I and what does it hook up to?
If there is a place for an antenna then it is wireless. You can use any computer monitor, doesn't have to be anything specially made for it. You will however need the wireless receiver and you will still need power to the camera. On top of that you will need a DVR for recording unless you have no intent of recording then you can hook it to the monitor with will take a converter to match the inputs properly.
Sep 02, 2014 | Astak Home Security
Would like to rewire Astak CM-918 camera due to missing hardware
Red and black, are power; white to a rc plug center pin yellow to the center pin of a rc plug and there should be a bare wire you need to split it off to the outside section of the yellow and white rc plug
Nov 26, 2013 | Astak Home Security
I want to download driver pk-101
There are no drivers needed for this unit, the usb cable is only for power charging If there is the case to be connected to a computer, the you need a vga to rca adapter like this one: http://www.ebay.com/itm/PC-Laptop-Computer-VGA-to-RCA-AV-Signal-TV-S-Video-Converter-Box-Adapter-/221090134653?pt=US_Video_Cables_Adapters&hash=item3379ffba7d
Aug 05, 2012 | Optoma Pico PK-101 DLP Projector
Can I use The computer USB link To PS2 USB to play on my Lcd screen attached to my Desk top Computer.Thank you. Victor
You are not able to use USB to send video out of the PS2. What you would need to do is figure out what video inputs your computer has, if any. Most don't come with any, unless there is a seperate video card attached to the machine. If you have this then there may be an S-Video connection on this card. Most cards with this connection can use it for input or output, but sometimes need a seperate "dongle" or box with cable, to allow for this to occur. If you have this connection on the card then you can find a S-Video to RCA adapter and then run the Yellow RCA from your PS2 into this adapter, then plug the S-video on the other end into the PC. You will also need a 3rd party software to view the video. I use Nero Recode, which is a part of the Nero Burning Rom package. There are many other products out there that allow the same thing, try a few trials and see what works best for you.
You can also then get an RCA to 1/8" headphone jack converter and plug the red and white RCA's from the PS2 into the adapter, then plug the 1/8" headphone jack into the Line IN on your soundcard on the pc and then you will have video and audio coming into the pc.
Let me know if this helps or if you need more info.
May 01, 2010 | Sony Video Game Consoles & Games
I just purchased a used Logitech Z-340 bass speaker. It has a power cable and what looks like a S-video connector. What kind of cable and where do I plug it in? Also if I need a adapter. Thanks in advance.
Try to go to an electronics store that has converter on your connector. I guess it is something like RCA jack but look for RCA connection and converter for USB plug in type of. Some old type laptop logitech you've bought would be used since some PC has RCA jack plug in at the back of it.
Anyway, look for the one I said earlier, an RCA to USB converter-connector.
Thanks.
Feb 07, 2010 | Altec Lansing Multimedia Computer Speakers
Audio Connection For GT-USB Turntable
The red/white plugs on the cable are called "RCA jacks", you'll need to get an adapter which will convert the rca jacks into one stereo pin jack to plug into the input jack of your computer
Apr 02, 2008 | Audio Players & Recorders
Home Security Logo
23 people viewed this question
Top Astak Home Security Experts
Tammy Bishop
Level 1 Expert
Robert Kulkofsky
Robert Kulkofsky
Nitin Khatri
Nitin Khatri
Are you an Astak Home Security Expert? Answer questions, earn points and help others
