Question about Price Pfister 34-3LC Genesis Kitchen Faucet with Spray - Polished Chrome...
Geness kitchen faucet leaking at top of handle replaced cartridge and diverter also 2 o rings im stumpted
  • 3 Answers
SOURCE: price pfister faucet handle drops and turns off.
Re the 'falling handle' issue, I think you misunderstood the problem, jgwhomeequip. Unfortunately for me I bought *two* similar Price Pfister faucets and both had the same problem - the water wouldn't stay on and the handle just wouldn't stay up.
I took mine apart looking for something to adjust, fruitlessly. Put it back together and have lived with it like that for ~2 years.
Finally I decided to not be a knucklehead any longer and call the manufacturer. Once I got through to their rep (on a Saturday no less!) she helped me identify the model I had (a 533-50SS, just FYI), and asked me 'what finish'? I replied 'stainless steel' and she promptly replied, 'I'm going to mail you out new lighter handles to replace the ones you have'.
Brilliant! Gold star for PP for standing behind their product well past the warranty for what was apparently a common problem. Replacing the handle will take about 10 seconds per faucet.
I only wish I had got of my a$$ and called them 2 years ago.
1-800-PFAUCET (1-800-732-8238)
Consumer Service Department:
7:30am to 4:00pm PST, Mon-Sat
Fax: 1-800-713-7080
Hope that's helpful to somebody.
Posted on Apr 04, 2009
  • 659 Answers
SOURCE: Moen One-Handle Kitchen Faucet Leak - Hot Only
http://www.moen.com/browsecatalog/catalog/specpartsearch.cfm?location=TopNavCustomerSupport
Moen uses a cartridge on their faucets. You have to remove the handle. You will find the stem and a small U shaped retainer. Pull the retainer out and pull the cargridge straight up. Sometimes the cartridge is in there pretty tight and you have to pull hard. Once you do this, take the cartridge to your local hardware store. Replace it with the one you have because they have 2 different one. Install it back in the same order it was removed. Hope this helps and good luck.
Posted on Apr 11, 2009
  • 74 Answers
SOURCE: price phister marielle kitchen faucet is leaking
Take the faucet back to where it was purchased as I believe PF has a lifetime warranty on their products.
Posted on May 03, 2009
  • 297 Answers
SOURCE: how to replace sprout seal kit in american standard faucet ?
just pull straight up,wiggle back and forth,the o-rings are holding it on .
Posted on Jul 15, 2009
SOURCE: 533-50 kitchen faucet leaks above base mount at
There are O rings that seal the various body parts of this faucet. I would try turning off the supply lines, removing the handle, and unscrewing the faucet and the housings. Look for O rings that seal each part. Could be a broken, or maybe some foreign material has gotten in the O ring grooves. Best bet would be to replace any O rings and tighten it all back securely. It should not have any Up and Down play, should only swivel side to side. I'm thinking O rings. While there, you can replace the seat seals and springs, so that you preclude any leaks from the faucet itself. Lowes, Home Depot, carry the repair kits for these faucets at a reasonable price. And they usually include the allen wrench and wrench to remove the handle and the body parts. And they are relatively inexpensive. Around 4 to 6 dollars. Its an easy fix.
Posted on Sep 27, 2009
Jameco single handle kitchen faucet with spray hard to turn
make this steps and fix it. God bless you
f a faucet leaks, replace seals and gaskets . If a shower head leaks, create a better seal or replace seals .
If a sillcock wears out, replace the washers .
If a compression faucet drips from the spout, replace the washer and/or the seat .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type.
If a ball or cartridge faucet leaks from the collar, replace worn O-rings .
If a disk faucet leaks around the base or has reduced flow, replace cracked or pitted disk assembly or worn inlet seals
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes .
If the aerator leaks around the edge, replace the washer in the aerator
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head
Nov 25, 2013 | RTO Jameco #K-1320B Bone Drop In Lav Sink
Jameco single handle kitchen faucet with spray is hard to turn
Leaking diverter valve
is it a kitchen faucet or a tub faucet? if it a kitchen faucet it will be a cartridge issue, if it is a tub faucet it could be as easy as a o-ring or a separate cartridge. in any case the cartridges are usually in the main part of the handle and you usually have to take apart the faucet. i know this may sound funny but make sure you turn off the water to the faucet, you would be surprised how many people try to fix this with water on.
Aug 30, 2012 | Kohler Plumbing
2 year old Moen 87845 began leaking at handle - some water coming out where it attaches to deck, some leaking out from under sink. Do I need a new cartridge? Also, when using sprayer, not all water is...
Yep, you have a bad cartridge and a diverter, the handle leaks all come from the cartridge
just remove the handle expose the U clip that keeps the cartridge in place. This is were yo will need a handle puller to extract the old cartridge. When you get it out make sure you clean out the inside befrore you place the replacement unit it. If not the junk will mess up the work you just did.
Make sure you use a food base lube to make surre the new one going in with out cutting O rings.
While you have to spout removed youo will see the diverter and pop that iut and put in a new one and the water to the spray unit will work like new.
Hope this helped you out, Be safe and take care
Tom
please take a second to rate us for its the only way if we know what kind of a job we did for you.:)
Sep 10, 2011 | Moen 87845 Quinn Single Handle Kitchen...
I want to change the cartridge but am lost as to how the faucet comes apart.
From www.hamatusa.com
Turn off water at supply line. Turn and remove top ring. Remove handle. Remove top half of body of faucet. Remove diverter (using large screwdriver) and replace. Replace body handle and ring.
Let me know if this works or not.
Gary
Dec 16, 2010 | Hamat 3-2861ST Everest Pull-Out Kitchen...
I have a two handled price pfister kitchen faucet and replaced the cartridges and now have low water pressure what did i do wrong?
probably the diverter, order from mfg & replace or you can disassemble diverter and replace internal white part and O ring which is what I did and worked great
Oct 04, 2010 | Price Pfister Plumbing
When we squeeze the handle of the side sprayer, only about half of the water flow is diverted through the sprayer. The remainder continues to flow through the faucet. I replaced the cartridge but the...
yes.
there is a "diverter" under the spout. you have to remove it to replace the diverter. should also replace the o rings at the same time. make sure everything is clean when you put everything back together and use a non silicone lubricant on all the parts and o rings.
Aug 15, 2010 | Price Pfister 34-3LC Genesis Kitchen...
I have replaced the cartridge on my single faucet single handle moen kitchen tap, but water still leaks out under the central area that holds the cartridge. Is there a schematic that shows where and what...
did you replace the spout, -o- ring's. they would cause a leak to show up there as well.no need to pull cartridge again,just handle,and then pull up spout and that is it. there should be a small packet of lube w/ -o- ring kit,lube up around shaft and new -o- ring's.available at any good hrd ware store
Apr 19, 2010 | Moen 7310 Legend Single-Handle Kitchen...
I replace the O-rings and cartridge on a legend
check the diverter sleeve/collar it may be getting in the way ,and water push's it out of the way.
Mar 02, 2010 | Moen 7310 Legend Single-Handle Kitchen...
I have a single handed Kohler Vinnata kitchen faucet that is leaking from the handle. Cartridge has been replaced and hasn't stopped leak. What now?
turn off water remove handle and check retaining nut remove cartridge and check o-rings for damage or replace replace and tighten cartridge check for leak
Nov 04, 2009 | Moen 7437 Chateau Single Hole Kitchen...
Price Pfister 34-3LC Genesis Kitchen Faucet with Spray - Polished Chrome... Logo
89 people viewed this question
Top Price Pfister Plumbing Experts
Marvin
Marvin
john h
Mike
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
