Question about Sony VAIO Computers & Internet
Resource Conflicts errors for PCI in Slot 01
PGC-8112L /VGN-AR720E won't boot up. I get Vaio splash screen then it goes to Resource Conflict errors: Resource Conflict - PCI in Slot 01 Bus:08, Device:03,Function:00 Resource Conflict - PCI Serial Bus Controller in Slot 01 Bus:08, Device:03,Function:01 Resource Conflict - PCI Mass Storage Controller in Slot 01 Bus:08, Device:03,Function:02 How can I correct these conflicts? I cleaned all connections and replaced the cmos battery. I don't know what to do next. Thanks in advance for any help, Carl hemi2k@comcast.net
  • Carl Solheim
    Carl Solheim Mar 20, 2014
    I have not added or removed any components and I reset the bios to defaults 3 times. No difference.
  • 24 Answers
Hey carl - first thing - laptop or desk top - if desk top (tower) remove all slotted cards and boot system - when it boots completely to home screen. shut down and insert 1 card at a time until you recieve you nasty screen. or boot into safe mode f10 or12 get in and disable all your cards -windows system- control panel - then turn on one by one doing a reboot - when you do find the conflicting card you should be able to figure which card or cards they conflict to - you will have to change the resource allocations on probable 2 or 3 cards to allow all to work - there all lots of sites that will explain this better - hope this helped
Posted on Mar 20, 2014
5 Suggested Answers
spare_head_2
  • 47 Answers
SOURCE: Resource Conflict - PCI Network Controller in Slot 02
Hi akwasi,
Try pressing F2 and look in the bios for a setting that says "Load Bios defaults". If you have any PCMCI cards inserted please remove them first and try a re-boot.
Have you added any new components on the PCI bus? If you have you need to make sure that the BIOS is allowed to reconfigure the interrupts. The device in slot 03 is conflicting with the integrated network controller hosted on the PCI bus. Remove the device in slot 3 and all should be well.
Most BIOS manufacturers allow the PC/Laptop to manage it's own interrupts, so ensure the device you've inserted allows for this. If it uses fixed interrupts this might be your problem.
A good manual should details the BIOS setting you can adjust in order to get the PCI controller happy again and allow the machine to POST correctly.
Regards,
Spare head 2
Posted on Jan 04, 2008
check for an update of bios on acer.com it will fix your laptop problem....
Posted on Apr 24, 2008
alien_x
  • 281 Answers
SOURCE: I have Acer Aspire 5101
you need to flash your bios with a new version try the laptop manufacture's site.
Posted on Nov 02, 2010
  • 8909 Answers
SOURCE: Bus: 06, Device: 01, Function:
I would firstly reboot and if that doesn't clear the error run www.iobit.com asc.setup utility to remove crosslinked files and sort out a crosslinked registry. Failing that remove the driver from the Control Panel and let the OS set up a fresh driver. Make sure the driver is the correct one!
Posted on May 02, 2011
Bus: 06, Device: 01, Function: 00 ERROR Resource Conflict - PCI Network Controller in Slot 02 Bus: 06, Device: 02, Function: 00 ERROR Resource Conflict - PCI in Slot 03 Bus: 06, Device: 04, Function:...
May 02, 2011 | Acer Aspire 5100 Notebook
EROR Resource Conflict -PCI in slot 03 Bus :06,Device:04,Function:01....ETC 02,03
Enter Control Pane, select Device Manager and uninstal devices that have conflicts.
Re boot and your OS should install new drivers in the correct order.
Hope this helps.
Nov 09, 2010 | Acer Aspire 5100 Notebook
When starting the laptop acer 5100 it tyries to start and it shows the following Bus 06, device 02 ,function 00 error resource conflict pci in slot 03 bus 06 device 04 function...
If it just started doing this all of a sudden, then it is a good bet that *********** board is fried. If you just installed some memory or a communications card or new drive, then take it out and see if it still does it. If not, check the installation instructions to make sure it was put in right.
Sep 08, 2010 | Acer Aspire 5100 Notebook
Al encender mi ACER Aspire 5100 suenan 2 pitidos y en la pantalla me pone: Sistem BIOS Version:V3.13 Bus:06, Device:01, Function:00 ERROR Resource Conflict - PCI in slot 03 Bus 06, Device:04, Function...
You have a n IRQ conflict meaning you have a device that is trying to use an IRQ slot that its not meant to talk on. From the looks of it you have been in the bios already so go back in and set it to factory default.
Aug 16, 2010 | Computers & Internet
I BOUGHT A USED ASPIRE 3100-5100 MOTHERBOARD AND GET THIS ERROR WHEN IT TRIES TO BOOT. ERROR Resource Conflict ? PCI in slot 03 Bus:06, Deice:01, Function:00 ERROR Resource Conflict ? PCI in slot 03...
You should try clearing the cmos battery. It's a small battery on the motherboard that can be taken off. Take it off for 20 minutes and put it back in. Then boot up again.
May 03, 2010 | Computers & Internet
My laptop wil not boot. Not even in safemode . It has wndows xp that i had recently put on there.. its been doing this for a min but it would come on after a few tries.. This is exactly what happens when i...
Hello Karen
Try removing and resetting your memory modules.
Blow some air in the slots to remove any dirt trapped in there.
They are locate don the back of your laptop.
The instructions are in the manual under how to change or upgrade memory modules.
Please don;t forget to rate this answer if it helps
Jul 22, 2009 | Acer Aspire 5100 Notebook
Aspire 5100 resource conflict - pci slot 3
Yuor RAM memory conflicts with each other check RAM memory fix same frequency memory into laptop.
Thanks for using fixya.
Jul 20, 2009 | Acer Aspire 5100 Notebook
Computers & Internet Logo
246 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
