Question about Home
AS2000XT triton shower problems
No water flow
    Scholar:
  • 42 Answers
1. make sure there is water getting to the triton control & pump
2. make sure there is power available to the pump
3. if 1 & 2 correct, then check to see if shower head needs cleaning to open the spray holes. if yes then use vinegar solution.
4. if 1, 2 and 3 do not fix problem, there is something wrong with unit and it may need to be repaired or replaced.
Posted on Apr 10, 2014
  • 44 Answers
SOURCE: Triton T80si shower will not switch off
its the water solenoid valve stuck in the open position so when the shower is turned off the shower stays running
Posted on Dec 15, 2008
  • 44 Answers
SOURCE: triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
  • 20 Answers
SOURCE: I have a Triton Rapide R2 electric shower problem
you can check the pipe lines there are normally more thane one way to set the pressure of the water one by the shower knobs 2 by the behind the head in the wall there are some water valves that may need to be opened up or by the water heater there are some valves there one coming off the heater one just on a pipe by the heater they may need to be opened. try that if that doesnt work come back and let us know and see what else you can do to fix it
Posted on Nov 11, 2009
peterrance19
  • 399 Answers
SOURCE: triton jade 2 shower not generating sufficient heat
your element needs de caling i suspect
Posted on Nov 15, 2009
  • 16 Answers
SOURCE: triton topaz t80i. Power to unit ok, but no water flow.
sounds like the pump is broke. better off just replacing whole unit unless you order new pump from triton.
Posted on Jan 10, 2010
My Triton t80si shower "cycles " going hot then cold then back to desired temperature - only just started happening no problem with flow of water
It sounds like the cartridge has to be changed. Pressure balance is not working in the cartridge.
Apr 13, 2013 | Home
The water flow from my triton electric shower does not stop even after unit is switched off
28487001 is not an electronic shower head made by Hansgrohe. It is an overhead shower head that has no electronic parts. Triton is a completely different company. If you have an electronic shower system by Triton you will need to contact Triton. If you have a Hansgrohe product feel free to contact Hansgrohe at 1-800-334-0455.
Apr 13, 2013 | Hansgrohe Showerhead Shower Power ...
Low pressure to a triton as200xt can i fit a t22i pump in front of the shower
I have just put a new triton as2000xt and I have no water coming out.
Mar 16, 2011 | Home
I have a triton dart shower which is operated by turning a flow control block. This is so hard to turn that I sometimes struggle and my family require my assistance. It is just as difficult to turn off...
I can't offer you a solution but will say that I have the same problem with my Triton Dart. I have put it down to a build up of hard water inside the valve but not sure. Think I'm going to have to contact Triton under their warranty although they do say that they will not cover faults resulting from limescale.Great
Nov 09, 2010 | Home
My Triton (Jade) electric shower has abruptly stopped supplying hot water. The pressure appears unchanged and altering the temperature control dial has no effect on the heat. Is it likely that, if needed,...
I have a Triton Ivory 111 shower, twice this week the water as just stopped flowing mid flow, presure ok and power still on what could be the trouble??
Stew.
Apr 05, 2010 | Home
Shower has power but no water flowing can you suggest a reason
The solenoid valve on the water outlet needs replacing. This fixed my Triton Power Shower anyway!
Oct 29, 2009 | Sun Time California San Diego Tritons Ncaa...
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
Triton Millenium Power Shower
generally if the flow sensor notices no water through the pump it will auto matically shut the pump down. so it could be the flow sensor is bad or the pump is not working like it should. now it depends on how old the pump is. i would start with the flow sensor.
Aug 30, 2008 | Home
Home Logo
269 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
