Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Clean printhead - Kodak EASYSHARE 5300 All-In-One InkJet Printer
  • 101 Answers
If you have used the cleaning cycle and did not have success, you will most likely have to replace the print heads.
If you do not print weekly with a Kodak printer, the ink can dry inside the heads and they stop printing or start missing lines that cannot be fixed by using the kodak cleaning cycle. . I have had this happen to two of my Kodaks. To prevent this, if you are not using them regularly, print a test sheet weekly and you should have no problem. At this point, your best bet is to order new heads for your printers and then maintain them with weekly test prints.
Posted on Apr 02, 2014
After cleaning printhead printer says printhead needs cleaning
If that's the case, the printhead will need to be replaced. If your printer is still under warranty, you can contact our technical support team to have the printhead replaced. If not, you can purchase a printhead online at http://bit.ly/IZYhWo.
Also, make sure that you're using genuine Lexmark cartridges. Refilled/remanufactured cartridges might damage your printhead.
Oct 28, 2012 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
HP designjet 1055cm plus: Installed new toner, printheads and printhead cleaner packs and the black one is failing? Said, alignment so reinstalled. Still failing. Help!
hello,
Try to reconfigure your printer setting and then run diagnostic on your printer to know the status of your printer if it still supports the new toner , printer heads you install.
Thanks
Jul 31, 2009 | HP DesignJet 1050c InkJet Printer
Tip
Cleaning Printheads
Step one: Clean the contacts on the printhead CAUTION: Electrical contacts contain sensitive electronic components that damage easily.
  1. Gather the following materials:
    • Dry, soft, lint-free cleaning cloths (coffee filters and eyeglass-cleaning cloths work well)
    • Paper towels or clean sheets of paper
  2. Lift the product lid. The top cover rests in an open position. Figure 1: Lift the lidc01607665.gif
  3. Press and hold the OK button for five seconds. The carriage moves to the left side of the product.
  4. Unplug the power cord from the rear of the product. Figure 2: Unplug the power cord from the rear of the productc01609893.gif
  5. Inside the product, lift the blue printhead latch. Figure 3: Lift the printhead latchc01607666.gif
  6. Lift the handle of the printhead, and then pull the printhead out of its slot.
  7. Hold the printhead by its sides, and wipe the electrical contacts on the printhead with the cloth. Do not touch the nozzles. CAUTION: Do not use water or other cleaning materials.Do not touch the nozzles on the printhead. Figure 4: Clean the printhead contacts, but do not touch the nozzlesc01609894.gif 1 - Nozzles - Do not clean 2 - Contacts - Clean
  8. Set the printhead on a sheet of paper or paper towel with the nozzles facing up.
  9. If necessary, repeat these steps to print the other printhead.
Step two: Clean the contacts inside the All-in-One
  1. With a fresh cloth, wipe the electrical contacts inside the carriage. Figure 5: Wipe the contacts inside the carriagec01609896.gif
  2. Plug in the power cord to the rear of the product.
  3. Press the Power button (c01602202.gif ) to turn on the product, if it does not turn on automatically. The message 'Printhead missing ' displays on the control panel.
  4. Hold the printhead by its sides with the nozzles toward the product, and then insert the printhead into its color-coded slot.
    • Insert the Black/Yellow printhead into the slot on the left.
    • Insert the Magenta/Cyan printhead into the slot on the right.
    Figure 6: Insert the printhead into its slotc01607670.gif
  5. Repeat these steps to insert the other printhead into its color-coded slot.
  6. Pull the blue printhead latch all the way forward, and then press down to fully engage the latch. You might have to apply some pressure to engage the latch. Figure 7: Lower the printhead latch c01607671.gif
  7. Close the product lid. Figure 8: Close the product lid c01607672.gif
  8. Wait for the product to initialize the printheads and print an alignment page. This process takes about 20 seconds.
on Oct 05, 2010 | Office Equipment & Supplies
Tip
How to Clean Your Printer once in a while
  7. Hold the printhead by its sides, and wipe the electrical contacts on the printhead with the cloth. Do not touch the nozzles. Figure 4: Clean the printhead contacts, but do not touch the nozzlesc01609894.gif 1 - Nozzles - Do not clean 2 - Contacts - Clean
  4. Hold the printhead by its sides with the nozzles toward the product, and then insert the printhead into its color-coded slot.Insert the Black/Yellow printhead into the slot on the left.Insert the Magenta/Cyan printhead into the slot on the right. Figure 6: Insert the printhead into its slotc01607670.gif
My printer prints a blank page what can I do to fix this?
Hi Good day!! Maybe your printer head needs to clean.
Cleaning the printhead
Use one of the following methods to run the printhead-cleaning tool
NOTE: The cleaning process might take several minutes to complete.
Method one: Clean the printhead from the HP All-in-One control panel
Follow these steps to run the printhead-cleaning tool from the product control panel.
1.Load letter, A4, or legal size, unused, plain, white paper into the main input tray.
2.On the product control panel, press the Setup button.
3.Press the Right Arrow button to select Tools , and then press OK .
4.Press the Right Arrow button to select Clean Printhead , and then press OK . The product cleans the printhead.
5.Press the Back button to return to the main screen.
Method two: Clean the printhead using HP Solution Center
Follow these steps to run the printhead-cleaning tool from HP Solution Center, which is a component of the software that shipped with your product.
1. Open HP Solution Center:
Windows XP: Click Start , click All Programs , click HP , and then click HP Solution Center .
Windows Vista: Click the Windows icon, click All Programs , click HP , and then click HP Solution Center .
HP Solution Center opens in a new window.
2.Click Settings, and then click Printer Toolbox . The printer Toolbox opens.
3.Click the Services tab, and then click Clean Printhead .
4.Click Clean to begin the cleaning process, and then follow the on-screen instructions to complete the process. A test page prints after the cleaning process completes.
Oct 17, 2010 | HP Officejet 6500 Wireless All-in-One...
Red is coming out pink
try to clean the printhead 2x you can do this using the computer and launching the home center software Just click the help icon(?) then lokk for maintenance and under maintenance click the clean printhead.
Or if you using the ESP3 you can press and hold at the same time copy and cancel button, if you hear mechanical sounds release the buttons and the clean printhead begins.,
If cleaning the printhead will not resolve the issue it means the printhead is already clogged please call kodak tech support toll free for printhead replacement 1 800 421 6699 ext 02,. I think printhead is free of charged
Nov 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Clean print heads? Kodak 5300
Yes,it can be cleaned but not manually. Here are the steps on how to clean the printhead on your printer:
a.Press the Menu button of the printer.
b.Use the down arrow key and go to Clean Printhead.
c.Press OK button then select Deep Clean.
Sep 24, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP officejet Pro 7580 problems with streaking
Clean the electrical contacts on the printhead and inside the product The ink nozzles on the printheads might clog if they are exposed to air for more than a few minutes or if the product is not used for long periods of time. Follow these steps to clean the electrical contacts on the printheads. CAUTION: Follow these steps carefully to avoid damaging the sensitive electrical components.
  1. Make sure that the product is turned on.
  2. Open the top cover of the product.
  3. Press and hold the OK button for five seconds. The carriage moves to the left side of the product and stops. Release the OK button.
  4. Wait until the carriage is idle and silent.
  5. Unplug the product power cord from the electrical outlet.
    NOTE: Do not turn the product off by pressing the Power button (c01346625.gif ). This causes the carriage to move out of reach.
  6. Lift the printhead latch. Figure 1: Lift the printhead latch c01448109.gif
  7. Lift the handle on the printhead that the error message indicates is missing or damaged, and then pull the printhead out of its slot. Figure 2: Lift the handle and remove the printhead c01448110.gif
  8. Use a dry, soft, lint-free cloth to remove any ink from the electrical contacts on the printhead.
    1. Wipe the electrical contacts with the swab until no ink residue remains, and then wipe the electrical contacts with a fresh cloth to dry them and remove lint.
    2. After the electrical contacts on the printhead are clean and dry, place the printhead on a sheet of paper or a paper towel. Make sure that the ink nozzles face up and do not touch the paper.
    3. Use a fresh, dry, soft, lint-free cloth to clean the electrical contacts inside the product. Figure 4: Clean the electrical contacts inside the product c01448112.gif
    4. Allow at least five minutes for the contacts to dry. Check the contacts for lint or debris, and then dry or clean the contacts again if needed.
    5. Plug the product power cord into the electrical outlet.
    6. Press the Power button (c01346625.gif ) to turn on the product. 'Printhead missing or damaged, replace the printhead' displays on the control panel.
    7. Insert the printhead into its color-coded slot. Press down firmly on the printhead to make sure the electrical contacts touch.
    8. Pull the printhead latch all the way forward, and then press down firmly to engage the latch.
      NOTE: You might have to press firmly to engage the latch. If the error message indicates that both printheads are missing or damaged, repeat the steps in this procedure to clean the other printhead.
    9. Close the top cover of the product. The product restarts and then prints an alignment page.
    10. Click on setup on the printer select tools and select clean printhead.
    11. inside the printer clean the metal carriage rod,rollers and that is it (clean with moist cotton swab)
Jun 22, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP D135 - replaced printhead - still doesn't print in that color
try this link : I followed the directions and fixed the problem. the instructions that came with the new printhead weren't really complete.
Here's essentially all I did for my fix - Opened the printer top, turned the printer off. Removed the "bad" printhead, cleaned the metal contacts on the printhead and printer with windex. Closed the printer. Turned it on. waited for it to reset. Opened the printer. Turned the printer off again. Installed the printhead. Closed the lid. Plugged the printer in again. When it was ready I accessed the HP toolbox and alligned the printheads and cleaned the printheads. It worked. Here's a link with photos.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa02107&lc=en&cc=ca&dlc=&product=64986
Oct 18, 2008 | HP OfficeJet D135 All-In-One InkJet...
Printer doesn't pring
Try cleaning the printheads
Performing the printhead cleaning procedure
  1. Power on your printer, press and hold the "RESUME" button until the printer light flashes once.Note: You can also clean the printhead by clicking the Cleaning button in the Maintenance tab of the printer properties dialog box in Windows; or clicking Cleaning pull-down menu in the Printer Utilities dialog box on a Macintosh computer. Choosing this option will allow you to select all nozzles, black or just the colour nozzles.
  2. Pressing Resume on the printer will clean all nozzles. When the printhead cleaning begins, the POWER light starts flashing. This will continue for about 30 seconds. Wait for the light to stop flashing before you resume normal operation.3. Perform the Nozzle Check Pattern test again
  3. If the results are satisfactory, resume normal printing
  4. If the results are not satisfactory, you may need to execute a printhead deep cleaning.
Deep printhead cleaning from the operation panel
  1. To deep clean the printhead from the operation panel
  2. Press the Maintenance button.
  3. Press the Right Arrow button three times.
  4. Press the Print button. Printhead deep cleaning starts.
  5. When deep head cleaning ends, press the Maintenance button to exit.
Deep printhead cleaning in Windows
  1. Make sure the printer is turned on.
  2. Click Start, then Settings, then Printers.
    Note:Windows XP users: Click Start, select Control Panel, then Printers and Other Hardware, then Printers and Faxes.
  3. Right-click the Canon S820D Bubble Jet printer icon, then select Properties.
  4. Click the Maintenance tab, then click the Cleaning or Deep Cleaning button. The Maintenance tab and procedures may vary for Windows 2000 and Windows XP. Follow the instructions when prompted for those operating systems.
  5. For each message displayed, click OK. The BJ Status Monitor opens automatically and closes when the printhead cleaning is done. The POWER lamp on the printer flashes green during the cleaning process.
May 18, 2008 | Canon BubbleJet i560 InkJet Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
