Question about Kenmore Dishwashers
Kenmore ultrawash type 575
All of a sudden water is not "wooshing". Motor is running but no water. I hit cancel and tried again. Any ideas? Help!
  • 957 Answers
Sounds like u need to replace the water inlet valve.
Posted on Mar 22, 2014
SOURCE: Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Hi Claire,
Are you using rinse aid?
that may help with the film.you may also have stuff down in the trap causing the water to drain slow.
Posted on Nov 05, 2008
  • 338 Answers
Not draining may either need new drain motor. or something is blocking the drain pipe.
Spots on dishes means you are using to much detergent or the wrong kind of detergent.
Your owners manuel should tell you what type to use.
Posted on Nov 25, 2008
  • 117 Answers
SOURCE: top rack in Kenmore ultrawash not being cleaned
Check to make sure the upper wash arm is not plugged with debris. All Plates on the bottom rack and bowls on the top. Position the arm at 12 o'clock and check at the end of the cycle to see if it has moved positions.
Posted on Feb 25, 2009
lojacksdad
  • 121 Answers
SOURCE: Kenmore UltraWash QuietGuard 4 making horrible
you have a peace of glass or plastic stuck in bottom
around the sprayer arm
Posted on Apr 17, 2009
SOURCE: Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Posted on Sep 04, 2009
Dishwasher will not start
Unlock dishwasher if locked by holding heated dry button for about 4-5 seconds next quickly hit the following buttons in successive order heated dry, normal wash heated dry then normal wash this should run diagnosis of the unit. Wait about2 minutes then press the cancel/drain button this should reset it and restore operation be sure to check that water supply is on and the drain is clear or you may get the code again.
Dec 07, 2013 | Kenmore 24" Built-In Dishwasher with...
Kenmore Ultrawash dishwasher Model 665 15810000. Originally "water heating" light was flashing and no water in dishwasher. Replaced water inlet valve. Turned power back on, normal wash light goes on...
lock light is locking the panel push this child lock button for 3 sec and see if it un locks . then try it again .. may have a pannel out. mm
Dec 06, 2009 | Washing Machines
Kenmore Ultrawash Quietguard Deluxe Problem
kenmore washers nothing but problems, my washer says clean and will not do any cycles...... less that 2 years old
Oct 21, 2009 | Kenmore Dishwashers
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Can hear motor running but nothing happens in dishwasher
Hi, you need to test voltage to the water inlet valve. If you are getting voltage (120V) replace the valve. If you are not getting voltage check the water level switch located in the front corner of the tub.
If I can assist you any further with parts or part #'s, please let me know.
Thanks
Vic
May 16, 2009 | Dishwashers
Nov 18, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Hi Claire,
Nov 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
107 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
