Question about Samsung CLP325 Laser Printer
Red light is on, no paper jam, all toners are full. please help
As soon as printer turns on, it wont get full start up. something stops the motor.
  • Paul Bell Apr 25, 2014
    You should have a program called "Smart Panel" on your computer it will pop up with an error message such as "install waste ink tank"
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 150 Answers
Hi your clean the printer wastink tank & then put into the printer ok
Posted on May 06, 2014
yooperbud
  • 8637 Answers
SOURCE: Paper feeding halfway through then stops
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 28, 2009
  • 4 Answers
SOURCE: Samsung ML-2250 red light
Check the paper tray. There's a latch along the lower left edge that's supposed to let the paper pop up when the tray is inserted so it can feed. If the tray looks OK, check the paper path again and look for a torn off piece of something in there. All it takes is one little piece of paper jammed in there to make the light come on. Use a flashlight and try blowing some air through it with the tray out, back door open and cartridge removed.
Posted on Mar 09, 2009
rigan86
  • 13 Answers
SOURCE: Red light Samsung ml 2010
I had the same problem and I finally solve it!
I simply took out the fuse and put it again in the cartridge, i don't know why, but it works
Riccardo
Posted on May 02, 2008
xptareq2000
  • 1447 Answers
SOURCE: phantom paper jam . Samsung clp300. Flashing red light
you clean your printer drum unit wast ink poder drum open and wast ink
Posted on Jul 23, 2009
  • 191 Answers
SOURCE: Printer has status light red as if a printer jam.
please your printer is check a paper tray. and openyour head couver
and towner is out of printer and so the paper piceses is in fixing to the any other roller ? and put in towner and couver is close and printer is on and aply a paper put in paper tray and aply the printer self print to button is on.
Posted on Oct 07, 2009
Testimonial: "Thank u very much!"
Red Light comes on and wont print
There is a lot of faults that cause the red light to turn on, toner cartridge empty, waste toner tank full, paper jam, imaging unit replacement, etc. The only real way to know what the problem the printer is seeing is to use the smartpanel utility on your PC. It will show you what the printer is reporting and how to correct it. Hope this helps you.
Mar 09, 2011 | Samsung CLP 300 Laser Printer
Red light stays on... wont print wont pick up paper... cleaned as much as I could...
There are a lot of conditions that cause the red light to come on. These include toner cartridge empty, paper jam, waste toner tank full, etc. The only good way of determining the printer fault is to check the smart panel software on your computer. It will tell you what the printer is experiencing.
If the printer can't pick up the paper, check the condition of the paper pickup roller. It is located in the back, and above the paper tray. Often it get dirty and cleaning it with a damp cloth helps it to pick up paper better. Hope this helps you.
Dec 29, 2010 | Samsung CLP 300 Laser Printer
Printer stops when printing should begin with red light in status
There is a few reasons that cause the status light to turn red, paper jam, paper empty, toner cartridge empty, cover open and waste toner cartridge full. The PC Smart panel utility should give you an exact fault condition. Hope this helps.
Jul 08, 2010 | Samsung CLP 300 Laser Printer
Red "Paper" light stays on; printer will not print.
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 11, 2010 | Brother HL-2040 Laser Printer
Chronic paper jams
If it appears to start printing sucks up a sheet a little way and then stops red light on etc try the waste toner trick. I was plagued by this problem for ages then took out the waste toner container sucked out the dust with a vacuum cleaner stuck it back no more jams. It is less a jam than the thing just getting an error from the waste toner. The other thing could be the paper feed roller. There is a rubber on this that grips the paper and feeds it if it is worn then the paper wont feed. I flipped it over kind of turning it inside out to get a fresh smooth side that will grip and feed the paper. If you are a little dextrous then it isnt a difficult job. Had two of these and problems on paper feed with both. The toner is expensive the waste container at a tenner is a ridiculous price. Still the second one was bought as it was cheaper to get the whole printer with toner than a 4 colour toner pack, I use it for spares! email if you want to try the feed roller trick.
Sep 11, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP-300 Printer has red light on, won't print, don't see any paper jam
I have to open the front panel as though I were going to replace the toner cartridge, but, instead I pull out the toner reclamation cartridge (the gray "L" shaped one to the left of the cyan cartridge) and then put it back in. This has cleared it each time for me.
Aug 10, 2008 | Samsung CLP 300 Laser Printer
Brother 2040 all lights keep blinking
Just got the following solution that worked for me:
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Got it from here:  http://www.fixya.com/support/t612015-print
May 05, 2008 | Brother HL-2040 Laser Printer
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
Printer problem
hi, Take out the toner and check for a paper jam.turn the printer upside down and check under the paper tray for a jam. When you reset the printer check to see if the printer picks up the paper, if it tries to pick up the paper then the red light flashes you should rough up the roller on the front above the paper tray, the rollers sometimes get smooth and won't pick paper up. You should also look inside where the toner cartridge goes and there are some little plastic flaps.Check that these are not stopping the paper going it. hope this helps
Sep 25, 2007 | Brother HL-2040 Laser Printer
Samsung CLP325 Laser Printer Logo
66 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
