Question about Briggs & Stratton Garden
The engine dies on me from time to time.
I have a Briggs & Stratton lawnmwer. It tends to cut out once in a while. I have found that by tapping the base of the carburetor it will resume service. In the past (3 or 4 years ago) I did take the carb apart and clean the moving parts with petrol as I suspect the float sticks . I just had the mower serviced and am reluctant to bring it back (I never told him about the problem -it slipped my mind) Would my "diagnosis " sound right? Have I just got a carb that is prone to sticking even after it has been cleaned and will my tapping (not too forceful!) keep on top of the situation(it seems intermittent and hasn't really worsened over the years ,touch wood.
    Sergeant:
    Champion:
  • 266 Answers
A B and S Lawnmower carburetor replacement kit is surely the way to go?
Here you are
http://www.briggsandstratton.com/us/en/support/faqs/overhauling-the-carburetor
Posted on Mar 20, 2014
  • Will Laxton May 01, 2014
    i have found rolling a piece of fine grit sandpaper and .cleaning the inlet needle area usually does the trick.make sure to blow it with compressred air to get any debris out of it.
    New Friend:
  • 25 Answers
Nex ttime you clean it. see if the needle valve attached to the float is sticking.if it is,roll up a piece of fine grit sandpaper .stick it in needle valve seat and roll it around sanding off any varnished gas residue.clean the side of needle as well. touch sand the the tip or let it sit in carb cleaner. that will damage it .
Posted on Oct 20, 2014
highspeedsan
  • 61 Answers
SOURCE: 6.75 B and S push mower wont start.
Check the kill switch. It may be stuck in the off position.
Posted on Apr 26, 2009
  • 166 Answers
SOURCE: Briggs & Stratton Quattro lawn mower
A lot of time when the small motors on these push mowers surge it is a governing spring that is weak or broke. It does not hold enough tension and causes the valve to fluctuate. I have fixed this many time for a relatively cheap amount (under $5).
Posted on Jun 16, 2009
  • 5 Answers
SOURCE: Briggs and Stratton Engine Surges and dies after 5 minutes of loa
On B&S OHV it is always wise to verify the valve clearance is within specification. Correct setting should be in your engine manual or you can get it at www.briggsandstratton.com. Good luck.
Posted on Jun 26, 2009
  • 1129 Answers
SOURCE: Briggs and stratton engine surges and slows, repeatedly
There is still either water or debree contaminating the fuel system. Surging is usually debree, empty and flush the tank with gas or Iso alcohol, disassemble carb soak in solvent for 30 minutes blow out the carb passages, reassemble and if the problem persists run engine at top rpm with air cleaner off and block off carb intake with hand, this will stall the motor restart and repeat 4 - 5 times this wiil draw out any debree or other blockage in the carb.
Posted on Jul 25, 2009
mowerman1857
  • 389 Answers
SOURCE: Poulan lawn mower, Briggs Stratton engine, revving problem
Most likely problem is dirt?moisture in the carburetor float bowl. You would have to remove the bowl, clean it out and also clean the main jet up in the center of the carburetor. Another problem could be that the governor is out of adjustment but this is not something a novice could or should do
Posted on Sep 14, 2009
Cub cadet 30 inch 1450 briggs and stratton
About 625 results (0.89 seconds) Search Results
    Why wont my engine start - Briggs & Stratton
    www.briggsandstratton.com/.../why-wont-my-engine-st...
    Briggs & StrattonThe most common reason an engine will not start is due to an interruption in fuel ...(such as Briggs & Stratton carburetor cleaner to clean carburetor parts and body. ...gasoline be purchased in small quantities, not more than a 30 day supply. ... that canflood the engine, or cut the air supply enough that engine will not run.Missing: inch ‎major
    Information about the Carter, Kohler and Walbro Carburetors
    gardentractorpullingtips.com/carbfuel.htm
    Information about the Kohler Carburetor, Various Fuels and Fuel Systems. ... (Updated 5/23/15); Repairing Various Older Briggs & Stratton Carburetors. ... If used on a smaller engine, due to the larger venturi, the engine will not receive the ... which converts to 1.181 inches (30 ÷ 25.4 = 1.181"), but actually measures 1.200".
    Notes on the Troubleshooting and Repair of small Gasoline ...
    www.repairfaq.org/sam/lmfaq.htm
    May 19, 2015 - Timing; Lawn mower will not start after the blade hit an obstruction; Flywheel ... on Briggs and Stratton repair; Experience with Briggs & Stratton carburetor .... NEVER attempt to run a gasoline engine indoors. ..... For 2 stroke engines, special oil (not the usual 10W-30/40 type motor oil, nor WD40 or 3-In-One!) ...
    Briggs & Stratton - YouTube
Jan 21, 2016 | Garden
John Deere high performance technology g4 crankshaft OHV twin 23 gross horsepower manufactured by Briggs and Stratton whenever I run over big weeds the mower dies once it dies it will not start for 20...
if the engine is a briggs and Stratton then check the valve clearance as B&S engines have a history of the valve stems stretching early in use and when hot hold the valve partially open until cooled down
Sep 16, 2014 | Cars & Trucks
Engine runs good for about 30 min then dies
electric fuel shutoff in the bowl of the carb is going bad and not letting enough fuel in remove cut tip off if it runs fine replace or just leave it its all e same
Jul 05, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and stratton 875 series
Engine hunting is fuel starvation, dirty fuel, partly blocked main jet.
Jun 02, 2012 | Swisher T14560 T - 60" Trailmower with 14...
I have a 3.5 horsepower B&S push lawn mower. It is easy enough to start, but once started it fluctuates. Runs high and then low almost as if it will cut off and then it runs high again. What can I...
I have a Briggs & Stratton 3.5HP Model 91212 type 1319E1 engine that I'm having trouble keeping running. Once it starts it will run about ten minutes, then die, and then is impossible to get re-started. Is this a carburetor problem, or possibly a coil?
Kent
Aug 31, 2011 | Briggs Stratton IC Horizontal OHV Engine ...
My briggs and stratton twin cylinder engine runs good until I try to mow with it. The engine dies down and will cut off unless I disengage the mower.
If you are cutting to much grass this can happen or if the throttle control is not in fast speed (rabbit). If it is in slow speed (turtle) it will tend to die down in tall grass or wet grass. Good Luck...
Aug 16, 2011 | Garden
Why do my clocks run fast when my Briggs & Stratton 15kw generator is running?
Electric clocks use synchronized motors that run on 60 Hz AC. The power company provides AC power with a precisely regulated frequency of 60 Hz. That means that the voltage jumps back and forth (positive to negative) 60 times per second. Your generator would do the same thing if it could run at precisely 3600 rpm (that's rev's per minute) - but it can't, because the engine is not that precisely controlled. In your case it tends to run (on average) a little fast. I hope you found this helpful. By the way, in Europe 50 Hz is the norm. If you run a clock designed for 50 Hz on 60 Hz power, it will run 20% too fast! Al K
Jun 20, 2011 | Briggs & Stratton Briggs Stratton 7 kW...
My Briggs & Stratton Diamond I/C 13.5 HP has
it could be worn out piston rings letting unburnt fule past into the sump oil
Jun 20, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Garden Logo
93 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
