Question about HEWLETT-PACKARD Color LaserJet CP5225 Printer
CP5225N WRONG FUSER INSTALLED ERROR
Installed new CE710A fuser unit as specified by HP; wrong fuser installed error
    Problem Solver:
  • 9 Answers
Was the replacement fuser 'new' or 'refurbished'? Try re-installing the fuser, that will usually correct the problem. If not, contact your vendor & see if they will exchange it. Always try to replace parts with Factory New. I don't work for or represent any brand, but in always tell my customers: Buy new Factory parts.
Posted on Apr 09, 2014
How do I Fix HP Printer 50.9 Fuser Error online ?
50.9 Fuser error message HP LaserJet P4014 P4015 P4515 If you are seeing the message 50.9 Fuser Error on your HP LaserJet P4014, P4015, P4015 series printer, you have either a failing fuser or the wrong model fuser installed in your printer. (The fuser is the consumable part in your printer which heats up and bonds toner to the paper. Usually the fuser gets replaced several times over the life of these printers.)
HP makes 2 different model fusers that look very similar -- the P4014/P4015/P4515 series fuser, and the M600 series fuser. Because of the similarities in appearance, sometimes the wrong fuser gets installed in the wrong model printer and triggers a 50.9 error.
The easiest way to check which model fuser you have installed is to pull the fuser out of the printer and look at the fuser's barcode. It is easy to remove the fuser on these models; if you don't know how to remove your fuser see the removal instructions farther down this page.
Once you have the fuser removed from the printer, look at the barcode as shown below to determine which model fuser you have installed. For the P4014, P4015, P4515 series printers the fuser part# should read RM1-4554 as shown in the picture below.
Either way, whether you have a failing fuser or an incorrect fuser on your LaserJet P4014, P4015, or P4515, you can purchase a quality replacement fuser in the maintenance kit for the P4014, P4015, P4515 series. Click here to view our selection of fusers/maintenance kits. Call us with any questions toll-free 866-352-7108 or local 608-831-2396.
Removal instructions: How to remove the fuser from the printer
Turn the printer off and unplug the power cord. The fuser might be hot if you have been using the printer. As a safety precaution wait 30 minutes for the fuser to cool before proceeding.
If a duplexer is installed, remove it from the back of the printer.
Next fold down the rear door.
Flex the plastic arm-hinge (circled in red below) on the left bottom of the door . This will release the tab which holds the plastic arm in place, and will free the door.
While grasping onto both sides of the fuser, push the blue levers upward and pull the fuser straight out.
After you order a replacement fuser and it arrives, you can install the fuser by inserting the fuser and aligning the left side first. Push the fuser firmly on the left side, then the right--listen for the sound of both blue levers clicking into place. If the fuser does not click into place you run the risk of wearing out both the fuser and the gears that drive the fuser prematurely. Re-install the plastic rear output bin and you are ready to print.
Dec 28, 2017 | HP Office Equipment & Supplies
Hp laser jet 3500 printer has an error code 59,99 what can i do /
main motor has failed to reach revolution within specified time- in other words - something is siezed solid and is preventing the machine from turning over into normal warm up operation-
suggest if you have recently replaced a toner cartridge/ fuser/ Image transfer belt then remove the new item and cycle the power without the unit installed. if tour machine warms up then complains about no cartridge then you have confirmation of the new unit being faulty-
if you are using 3rd party toners/ fusers then that could also be your problem. 3rd Party toners do NOT save money rather they will incur repair costs as they are not correctly prepared for re-use.
Jan 16, 2014 | Office Equipment & Supplies
Hot error shown when we plug fuser...
you have the wrong type of fuser - probably HP 4200/4300or 4250/4350. these units look IDENTICAL the correct fuser unit assy part number is RM1 1044 a small white barcoded sticker should be present with the part number on the base plate of the fuser unitt
Jan 16, 2014 | HP LaserJet 4345mfp Printer
Ours's a hp color laserjet 4700dn ; the message is 59.30 error ; we bought the machine in the year 2007 what do you suggest?
59.30 states it's the:Fuser motor startup error
Based on the service manual here are the steps to follow:
Fuser motor error
1. Reconnect the connectors J4605 for
the fuser motor and J1024 on the DC
controller PCB.
2. Run the component test to verify that
the fuser motor is working correctly.
3. Replace the fuser motor.
How to preform the component test below
1. Press Menu to enter the MENUS.
2. Press to highlight DIAGNOSTICS.
3. Press to select DIAGNOSTICS.
4. Press to highlight COMPONENT TEST.
5. Press to select COMPONENT TEST.
6. Select the component test Fuser motor. Use this test to rotate the fuser motor and drive gears.
Menus cannot be opened during component tests, so serves the same function as the Stop button.
More information on a Fuser motor failure detection
  • The DC controller determines the fuser motor failure and notifies the formatter of an error status when it encounters the following conditions.
  • Fuser motor start-up abnormality. The interval of the fuser motor speed detection signal does not reach the specified interval after 1.5 seconds of the fuser motor drive start.
  • Fuser motor rotation abnormality. The interval of the fuser motor speed detection signal stays at an irregular interval for two seconds and longer after it reaches the specified interval.
I've attached a screen shot of where the fuser motor is located It is # 8. tballone.png
Feb 25, 2011 | HP LaserJet 4700 Printer
HP laserjet 3600 error message 50.9 Fuser Error
Thank you for the inquiry.
Yes you will probably have to replace the fuser. If this is a new printer still under warranty and the page count has not reached the service life of the fuser, contact HP for warranty replacement. Once the new fuser in installed you will need to restore the service count.
nav?h_pagetype=z-001&h_lang=en&h_cc=us&h_client=z-a-r1002-1&h_product=501046
Fuser Kit Part Number: (Sometimes Called a Maintenance Kit)
RM1-2665 This fuser is compatible with the following printers: HP Color LaserJet 2700, 3000, 3000N, 3000DN, 3000DTN, 3600, 3600N, 3600DN,
Link to Installation pictures and instructions:
http://printertechs.com/tech/mkinst/3000/mk-3000-2fuser.php
Restoring the maintenance count after installing new fuser.
This printer tracks the number of pages printed on the fuser, and a reminder message will appear when the fuser reaches a certain page count. The message will instruct you to replace your fuser. Whenever you install a new fuser, you should reset the fuser page count so the warning message will not appear prematurely.
To reset the fuser count :
1. Press MENU to enter the MENUS.
2. Press Down arrow to highlight Configure Device.
3. Press Checkmark to select Configure Device.
4. Press Down arrow to highlight RESETS.
5. Press Checkmark to select RESETS.
6. Press Down arrow to highlight RESET SUPPLIES.
7. Press Checkmark to select RESET SUPPLIES.
8. Press Down arrow to highlight NEW FUSER KIT.
9. Press Down arrow to select NEW FUSER KIT.
10. Press Down arrow to highlight YES.
11. Press Checkmark to select YES.
The fuser count will be reset and then the printer is ready to use.
Thank you for being a FixYa Valued Customer.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jan 19, 2011 | HP LaserJet 3600 Printer
925 service fuser error
A 925 Fuser Error indicates that the wrong fuser lamp or the incorrect fuser assembly is installed.
  1. If this error appears shortly after the fuser unit in the printer is replaced, put the old fuser unit back in.
    If the error message goes away with the old fuser unit, please check that the new fuser unit is the correct one for this printer model.
  2. If the printer has not recently had its fuser replaced, plug the printer directly into a wall outlet. Surge protectors and power strips can sometimes regulate the voltage to a fault for the printer. If the printer is already on a wall outlet, plugging the printer into a different outlet may solve the problem. Keep in mind that there is no need to have the printer connected to a computer during testing for a fuser error as any pages to test the functionality of the printer can be processed internally.
  3. If you have tried the printer on other wall outlets and the 925 Fuser Error still appears, the printer will require service to clear the message.
Jan 12, 2010 | IBM Infoprint 1352 Laser Printer
Replaced fuser unit on HP 4350dtn and now get a 50.5 error.
The 50.5 error indicates "wrong fuser installed" on a 4350DTN printer the correct fuser is RM1-1082, it will not work with RM1-0101 even if the 0101 fits the printer. Remove the fuser and look for a small label giving the part number and check it. If you need to get a fuser let me know, we have them in stock.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair
Jul 23, 2009 | Office Equipment & Supplies
Hp colour laserjet 9500 hdn with noise and fuser error 50.6 .
Look at fuser rollers and make sure the new one doesnt have spacing to far in between rollers. Also on front side of fuser there is a big connector that meshes with one inside machine. The fuser connector assy RG5-5925-000CN could be broken as well
Jan 21, 2009 | HP Color LaserJet 9500HDN Printer
Hp 4350 error code 50.3
I have just changed the fuser unit and the printer is still giving the
same error [fuser error and low heating] Kindly help.
Maxwell Mpundu@technet.co.zm
Apr 21, 2008 | HP LaserJet 4350 Printer
HEWLETT-PACKARD Color LaserJet CP5225 Printer Logo
469 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Victorman
Victorman
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
