Error code E4 on cold star mini split unit
Coldstar split unit 12000 BTU works for like 30 mins then it shuts down and displays E4. I need to turn off and turn on for it to work another 30 mins until the same thing happens again. Does someone know how to fix it or where the problem may be??
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
E4 usually means either blocked capillary, low refrigerant charge, high ambient temperature.
First: check the filters. The front panel opens up like the hood of a car and the filters are fine plastic meshes that you should be able to see through. If you can't see through them that means they are clogged. pull them put and clean them with water only and replace. If the filters are blocked the unit will be unable to refrigerate properly.
Second: check the capillary (water outlet). If the hose is clogged, water usually backs up and sometimes the A/C will start dripping into the room. This also makes cooling defficient. Do NOT try to force water through the hose. Sometimes there is debris in it and you will just make the plug harder to remove. The way to remove it is by sucking the water back, not pushing it forward. A technician should be able to do this for you. The other possibility is that the other end of the "hose" (on the outside) is clogged or under water. Just remove the obstruction.
Third: the ambient temperatre is too high and your BTUs are not sufficient to cool the space. In other words, your A/C is not big enough for the amount of heat/size of the room.
Fourth: have the refrigerant level checked by a qualified technician. They can refill the refrigerant. They have all the tools required.
Posted on Mar 21, 2014
Testimonial: "Thank you. I had the unit serviced, so filters are clean, no water clogged on hose, and the a/c is big enough since it worked well for a year. When it was serviced, the technician topped up the refrigerant cause it needed it but it still didn't solve the problem and wanted to have an idea before calling the same or another technician."
5 Suggested Answers
SOURCE: E4 error code on AUX mini-spit a/c unit
E9 Showing on my split unit a/c
Posted on Mar 19, 2010
icemelts
  • 246 Answers
SOURCE: Celiera 12000 btu Mini-split ac unit blows cool
It's 'possible' but not likely that you need additional freon.
What is more likely is the 'filter' (for inside coil) is dirty and possibly the coil itself - and/or - the outside coil is dirty.
I would check out the filter - if dirty - I would change it and would also inspect the inside coil. If it's also dirty I would clean it the best I could (with a brush of some sort).
I would also check the outside coil and clean it if need be.
Hope this helps.
Posted on Jun 11, 2010
SOURCE: Highlander KYD-25/c Error E4 displayed
You want to look up Guangdong Chigo who are the manufacturers of this unit. They have a list of error codes/service manuals etc on their site.... From the PDF:
"1、Check whether the operation current and power of the unit is abnormal. 2、Check whether the speed and wind quantity of the fan is normal, otherwise replace the outdoor fan or capacitance 3、 Check whether the surface of the condenser is too dirty, and it should be cleaned when it is too dirty. 4、Check whether the unit is short of the refrigerant, add the refrigerant after leakage detection and repair welding. 5、 Check whether the sensor and electric control board is normal, otherwise replace the board."
Posted on Jun 24, 2010
SOURCE: e4 in an innovair a/c
Check the Capacitor.
Posted on Oct 06, 2011
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
Display shows ec and then flashes 7 times
Don't have a answer but my 12000 btu is doing the same thing
May 13, 2016 | Senville 24000 BTU Energy Star Ductless...
I have a aircon that showing me the error code e3 on the display board. can you help me with this problem
Hi I googled (error code e3 for Sanyo 12000 Btu Mini Split Air Conditioner) and found this link below of a short youtube video of the answer you're looking for, Also on the right there are other video's you might be interested in...I hope this helps you..CHEERS..
https://www.youtube.com/watch?v=nISwqnhul90
Mar 22, 2016 | Sanyo 12000 Btu Mini Split Air Conditioner...
What does H1 code indicate?
Hello E, I appreciate your post!
I see that your Frigidaire air conditioner is displaying an error code of "H1". I have reviewed the air conditioner and the "H1" error code could be an "HI". The "HI" error code means that the room temperature is above the display range. I would recommend performing a reset on your air conditioner. In order to reset the air conditioner you need to unplug the power cord you can press the reset button and then the test button that should restart your air conditioner. If that does correct your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. I hope this information is helpful for you. -Matt
Jan 22, 2016 | Frigidaire FRS12PYS1 12000 BTU Split...
What wrong my comfortstar mini **** outside unit not coming on and I am getting e1 error code
I am somehow listed as someone who "solved" a Comfortstar mini problem - but I have not. And the company that installed it cannot. I am really fed up with the stupid thing.
Jun 17, 2014 | Ingram's Water and Air ComfortStar Mini...
E4 error on screen
Check out door unit. May be weak in Running capacitor/Fan motor capacitor/Condensor coil dust blocked. First clean and run, if still problem check speed of fan motor, if less replace fan-capacitor.
May 07, 2014 | Midea 24,000 Btu 17 SEER Inverter Mini...
Display is out
Push the swing button 2 times quickly. This will turn the display back on.
Jan 15, 2014 | Soleus Air KFHHP-12 12000 BTU Mini Split...
May 07, 2009 | Heating & Cooling
E4 in an innovair a/c
Jan 12, 2009 | Heating & Cooling
Heating & Cooling Logo
224 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
