Speaker is not producing sound. Connector looks good. Other speaker works in either connection point.
SOURCE: speaker sound is very low
Open the master volume control window by clicking the sound icon on the right hand side of your taskbar(near your clock).and check the balance is set to low for your speaker or not.try to set it at centre.
or try to update your sound driver.
SOURCE: no sound from cable via V665 receiver
Can't pass HDMI thru this or any other receiver with version 1.1,1.2,1.2a,or 1.2b. HDMI is riddled with issues! it's not Yamaha, it's HDMI. The current version 1.3b is working "so far" If your receiver is still under warranty, Yamaha will update the software and hardware at N/C. If it's out of warranty, Run HDMI directly from source to TV and Audio to your receiver via optical or digital coaxial. For more info than you can process, google "HDMI forums" and there are over 73,000 posts/sites/etc. If you need further info, post a comment and I will be glad to help.
SOURCE: no sound from speakers, intermittent problem.
.I openened the sound touch control.My logitech subwoofer doesn t work,but all other repros do
SOURCE: I have inbuilt sound card with asus mother board
you can download the driver here.
*Product Type: Motherboard
*Select Series: LGA 775
*Model: P5GC-MX/1333
*Operating System: Depends on your OS
and if still having the same issue after installing it check if the volume is not set to mute and if still have the same problem might be that the problem is the sound card of your motherboard since the speaker is working on a different pc
SOURCE: When speakers are connected to the computer, they
these speakers are quite problematic aren't they!! From the information you have given there is either a problem with the mains trans former or the internal wiring. Neither of which are user serviceable.
