Question about Yale Locks P8k117blx Door Bolt Brasslux Cylinder
I have a yale comp door,I want to fit the lock so when you close the door it locks . I have the bar with springs is it just a case of take long bar out and replace with the two small bars with spring
How to change so door will lock when you close the door
When I was fixing the door switch for my Kenmore front load washer this spring fell out. Where does it go?
I've seen that door lock assemble before and I normally just replace it. But good job on your end to give it a go. That door lock has a coil that when energized it closes on the door strike. When its de-energized, that springs assist to open the lock. I can say exactly where it fits, but look for a spot between the red part on inside. Good Luck
May 25, 2016 | Kenmore Washing Machines
How do i reset a yale series 150/30 padlock
this step by step guide should help you reset the lock, if its not the exact same lock, its the closest thing that Yale currently makes. Be aware you cannot reset locks like these unless they are open already, atleast not to my knowledge
Combination Cable lock Reset the combination of Yale travel lock Secure...
Jun 06, 2014 | Yale Y150/30/125/1 Combination PadLock
I lost the keys to my back door yale lock, how do I get another one?
Somehow your answer ended up in the Office Shredders problem area. I suggest you resubmit your answer to the correct problem area. When you do, clarify if the lock is installed in the door, in that case, either 1) remove the lock and take it to a locksmith to make a new key (It is expensive if they come to you) 2) Buy a new lock and hide a spare somewhere safe outside your house 3) If it is a pad lock, cut the lock and get a new one.
Dec 09, 2013 | Office Equipment & Supplies
Toyota door lock
Hi John, If the latching mechanism is in the locked position, does it open when either of the handles are pulled? If it is not opening you may need clean and service the linkages and the latching mechanism or replace the latch. The locking mechanism inside the latch is is an off center sort of horse shoe shape. If it is closed you will see a bar which will be in an almost vertical position, and it should release when either of the door handles is operated. If it is failing to lock, (which I am suspecting), the latch will be at an angle of about fifty degrees. If that is the case, using a Philips (star screw driver) push the latch back to find out if it is latching. If it does, use either of the handles to release it again. If it fails to hold in the closed position, the linkages from the release handles may be fouled, damaged or disconnected. If everything is correct in those areas, the latch may need replacement. Check that first, let me know how you get on and if we need to go further and carry out a replacement, which will mean removing the door panel, and the mechanism let me know so we can go through it together. Regards John
Jan 18, 2013 | 2000 Toyota Avalon
The Yale lock on my Front door in becoming increasingly difficult to open with the right key. I'm worrie dthat one day soon I wont beable to open it at all. What is wrong with the lock? Could I use...
Yes I would useWD-40 to spray in lock. Insert key part way in lock and spray a small amount on key and into lockset if tou can, If you can fit spray nozzle into keyhole ,and spray liberally. You can also use dry graphite to lube lock mechanism. I would check to make sure that your keys aren't bent or worn to the point that I hope this helps you. Thanks they can't engage all tumblers inside lockset. I would also make sure that latch on lock is lining up with strike plate in door frame. One easy way to do this is to use a felt tip marker to cover strike plate on door frame and open and close door several times. Where ink from marker is rubbed off will show you where latch is contacting strike plate. If it is out of aligmment this will make it harder to open or lock with key. If necessary adjust strike plate for better fit. I hope this helps you. Thanks
Nov 17, 2010 | Garden
We tried to rekey our kwikset smart key, but couldn't and now the original key doesn't work
I had mine do the same thing right before I was leaving to the airport [re-keying for the house-sitter]. I was setting the lock and I hear a spring-type ping and the keying was lost.
The tumbler can be reset to your key. However, it involves disassembling the device and has small parts.If you are feeling lucky, you can do this yourself or take it to a qualified person.
If you are feeling lucky:
A: Disassemble the lock from the door
B: Remove the door handle from around the key side.
C: Remove the U retaining-clip from the outside of the lock that is securing it to the shaft.
D: Remove the lock from the shaft
E: Remove the U retaining-clip from the tumbler body and the case
F: You will have to press the five fingers down evenly on the length of the case to slide the cylinder out of the case. (I cut a plastic card with small wire cutters to make a tool, but you could probably use thick card-stock and some scissors.)
Be careful; you will have to watch for and secure the check ball on one side of the tumbler and the finger lock bar on the other side as you slide this out.
G: Remove and store the check ball securely as well as the finger lock bar. (careful with the plate surrounding the fingers that the finger lock bar resides in)
H: Remove the finger locking plate. Carefully, make sure the fingers are still inside and oriented correctly and the spring at the back of the finger locking plate is left in place.
I: You will notice a u channel groove in the fingers and the finger locking plate. Align the fingers in the finger locking plate evenly so that the grooves in the fingers match the groove in the finger locking plate.
J: Replace the finger locking plate with fingers aligned evenly with the u channel groove back onto the tumbler body and hold back against the spring left on the rear of the tumbler body. This puts the tumbler into re-key position.
K: Replace the finger locking bar onto the finger locking plate while holding the assembly against the spring and tumbler body. (If this is done correctly, the finger locking bar will now be flush with the side of the finger locking plate and not raised as normal.)
L: While holding the tumbler assembly together and maintaining the locking plate pressed against the spring, Insert your new key into the tumbler body.
M: While holding this assembly in this position, add the check ball to the tumbler assembly.
N: While holding the assembly in position, slightly depress the black plastic block at the back of the finger locking plate and slide this tumbler assembly back into the tumbler case taking care to rotate the case 90 degrees clockwise from normal. (Note the U channel groove inside the tumbler case that normally receives the finger lock bar and use that for orientation.)
If the tumbler does not insert cleanly, verify the finger locking bar is flush. If it is not, redo while maintaining proper pressure to keep the finger locking plate firmly against the spring in re-assembly. Also, verify the fingers are not protruding from the tumbler body. If they are, redo the procedure taking care to align the fingers properly on assembly and maintain proper force on the finger locking plate against the tumbler body during re-assembly and new key insertion
O: Rotate the key and tumbler body in the case to the normal position (counter-clockwise 90 degrees).
P: While holding the tumbler body firmly against the case, remove the key.
Q: Re-insert the key and verify smooth rotation.
R: Align the tumbler body and case back to the normal position and while holding the tumbler body firmly against the case, remove the key.
S: Replace the U retaining-clip that belongs on the back of the tumbler body to secure it within the case.
T: Replace the tumbler body in the main lock shaft and secure with the shaft U retaining clip.
Mar 24, 2010 | Kwikset Professional Door Lock...
The door won't close.
replace the door lock assy, you can't fix this without almost certainly breaking it by prying with a flat screwdriver. Remove door boot spring, fold door boot back over door lock area, unscrew door lock screws (3), then remove from harnesses and replace. Reverse door boot and spring removal, top of spring first, then work your way down ensuring a good snug fit with no water leaks, it may take you a couple of trys.
Jul 02, 2009 | Frigidaire Affinity ATF7000E Front Load...
2006 aveo alarm system
this happened to me and it drove me crazy for a few days. check that the hood is closed tightly. its held shut for the most part by a peice of metal with a screw on one side, a spring around it, and a nub looking shape that fits into the locking device above the bumper. When i finally checked my hood, the entire bit of metal had come unscrewed and was stuck in the locking device, leaving my hood held shut only by the safety clamp. remove it from the locking part and screw it back into the hood, closing it a few times to find the right distance to screw it in. lock your car and hear that chirp, that should fix it
if thats not the case then check that all of the doors are closed nice and tight... if the doors lock but the audible alarm is not armed then that is most likely the case
May 19, 2009 | 2006 Chevrolet Aveo
Yale Locks P8k117blx Door Bolt Brasslux Cylinder Logo
Top Yale Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Yale Lock and Locksmithing Expert? Answer questions, earn points and help others
