Question about Dell Vostro 1014 Laptop Computer
I tried to clean the dell vostro 1014 fan, after i assembled the fan and turned on the laptop it appear black screen with dim image on my laptop screen, When I plug in external monitor it shows boot s
I am using dell vostro 1014 laptop, i cleaned the laptop fan and assembled as well after assembled and turned on the laptop,it shows dim boot screen and windows logo while on booting it struck with shattered windows logo on my laptop screen,later it connected to external monitor brightness is increased but colored lines are appearing in mid of booting and struck with lines, please suggest me what i have to do now?
    Master:
  • 397 Answers
It sounsd like your GPU may be BGA chip and would require a re-flow/re-ball if your laptop shows graphical distortion on both monitors.
However I would first try taking the laptop apart again and double check you have connected everything properly.
Posted on Mar 20, 2014
cpenzes
  • 1102 Answers
SOURCE: Laptop black screen during boot, then normal in Operative System
is it affecting your pc
you can change the bootup display time if you want
but I would leave it as is if your system is not affected by it
Posted on Jan 20, 2009
  • 144 Answers
SOURCE: Dell Vostro 1500 will not boot
NEEDS TO BE REINSTALLED SEE IF YOU CAN HIT F12 AND SEE IF YOU CAN GET THE BOOT MENU
Posted on Jun 06, 2009
justin217
  • 85 Answers
SOURCE: Dell 610 here stuck on boot up screen with green vertical lines
If it is unable to boot up, its probably not a monitor issue, although it could well be without examing it. If your good with computers, you can take it apart and look to see if the lcd ribbon cable is torn or damaged. If you don't feel you can do it, contact dell support or take it to your local computer repair shop. I hope this helps!
Posted on Jul 15, 2009
graysand
  • 558 Answers
SOURCE: My Dell Vostro 1500 laptop screen just blacked
your problem is easy to fix the cable from your lcd to your motherboard is disconnected,here is what you will have to do first remove the battery,the ac cable then if you are strong enough use your fingers to pry away the hinge cover off from right to left, and then remove it from the computer.You will see below a biege cable which is the conector to your motherboard unplugged.Plug it in and carefully replace the hinge the battery turn it on and you should see the dell logo.
Good Luck
Posted on Aug 26, 2009
parrotheadpc
  • 2600 Answers
SOURCE: I have a Dell laptop D505. The laptop powers up
Sounds like your inverter or your backlight is failing. The inverter is an easy repair, the backlight can be replaced but it involves taking the LCD panel apart, The backlight comes installed on new screens. I can include a service manual below and possibly a generic guide to backlight replacement....
http://support.dell.com/support/edocs/systems/latd505/sm/display.htm#1052500
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Posted on Oct 01, 2009
My display screen of laptop fluctuates and some times it black out
Try replacing the LCD screen first. (Screens usually have a 2-5 year life span. )
Oct 18, 2013 | Dell Vostro 1014 Laptop Computer
My dell vostro 1014 laptop computer display driver stops working often and recovers automatically within few seconds, how to get it clear?
Try to download the latest driver and check the power saving options how long it takes the screen to turn off when the computer is not in use.
Nov 27, 2012 | Dell Vostro 1014 Laptop Computer
Dell vostro 1014 laptop screen going to white while working, how can i solve
By the screen (If there are rubber stoppers remove them) Find screws And get a screwdriver remove screws.After that the screen should be screwed in at the top and/or sides remove the screen.After screen is removed Check the Connector cable is CLEAN and inserted correctly After that reinsert the cable to the screen and screw it in and the frame and your screen should not bother you
Jun 12, 2012 | Dell Vostro 1014 Laptop Computer
How can i turn on wifi in dell vostro 1014?
IF THERE IS NO WIFI DRIVER IT MAY HAPPENS .INSTALL WIFI DRIVER FROM YOUR MOTHERBOARD CD
Aug 20, 2011 | Dell Vostro 1014 Laptop Computer
I have dell vostro 1014. OS windows7..I CANT ENABLE BLUETOOTH DEVICE
windows 7 & bluetooth are not working normally. a beep sound is coming at time of opening (dell vostro 1014)
Feb 25, 2011 | Dell Vostro 1014 Laptop Computer
How to format DELL Vostro 1014 Laptop
If you wish to FORMAT your hard drive so you can re install the OS.
Put your Windows disc into the CD/DVD drive, boot the computer and press F2 (if that does not work try CTRL+ALT and enter) to enter the bios. Change the boot order to boot from the CD drive first.
Follow the onscreen instructions to Install the OS, you should get the option to delete the existing partitions and then to FORMAT.
Aug 06, 2010 | Dell Vostro 1014 Laptop Computer
Dell Vostro 1014 Laptop Computer Logo
80 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
