Question about Premier Water Heaters
Rusty smelly hot water
Changed anode rod still getting rust one year old tank
  • Premier Master
  • 5,245 Answers
The rust can be from rusted pipes, and not necessarily tank:
New tank has new anode rod, and is NOT likely to be cause of problem.
Anode only protects the tank... not your steel pipes.
There are mathematical formulas for figuring what size and type anode is needed for steel structures like bridges and water heater and boat hulls... if anode is too small or deteriorated, or coated in calcium, or not electrically bonded to the steel surface, or if tank is not full of water or boat hull is out of water, then anode cannot protect the steel.
For more insight about problem:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
http://waterheatertimer.org/Replace-anode-rod.html
Gene h
Posted on Mar 21, 2014
Testimonial: "i do not have steel pipes,all piping is pvc.houses in this area are one year old. i seem to be the only one with rust in tank. i have a prefilter and water cond. thanks"
  • 659 Answers
SOURCE: foul(sulphur like smel from the hot water valve)
Have you removed the anode rod to check it? They dissolve over time and have to be replaced.
Posted on Apr 07, 2009
  • 98 Answers
SOURCE: "smelly water" from hot side of electric hwh
i always take them out. they say it voids the warrentee but i have never had any trouble with it removed.
Posted on Jun 06, 2009
  • 252 Answers
SOURCE: cant locate anode rod on rheem gaas water heater
It looks like a plug screwed into the top of the water heater (it IS plugging the hole so turn off water and release pressure b4 removing)
Posted on Oct 01, 2009
packrat1948
  • 528 Answers
SOURCE: where is the anode rod in a 606 electric reliance
It is the 1" or 11/8" hex nut on the top of the water heater some where buy the supply line. As for the anode rod it could be either depending where it was sold. If you are going to change it out call your water provider and ask which would be better for your area and water.
Posted on Feb 05, 2011
  • 1015 Answers
SOURCE: Our 40 gal Rheem gas
I would have to go along with your brother on this one. The aluminum anode rod is by far the cheapest way to go. Other options include extensive filtration,ozone treatment and acid treatment.
The aluminum anode rod is much cheaper and I would recommend you change it yearly at least. Good luck and thank you.
Posted on Feb 22, 2011
HOW DO I GET RID OF ODOR COMING FROM HOT WATER TANK
harmless bacterial reacts with anode rod
anode protects tank from rusting
change anode, or remove anode, or treat tank regularly with hydrogen peroxide
Gene
Sep 13, 2014 | Water Heaters
What is the best replace the elements and thermostats or just get a new waterheater
Best is to replace anode rod, and leave elements and thermostats alone until they go out. IF you can get the anode out.
Anode rod prevents tank from rusting. Anode rods deplete over time in most situations, and then tank begins to rust. If the anode can be successfully removed, and updated, then tank rusting stops, and you're tank is good for another 10 years.
So answer to question is: Depends if tank is rusty, and if tank is sitting in drip pan to protect home from possible leak.
http://waterheatertimer.org/Leaking-water-heater.html
Tank-type electric heater is unique since it can last almost indefinitely, with maintenance. Therefore maintaining tank-type electric water heater can pay you $5-10 per month.
http://waterheatertimer.org/How-to-maintain-water-heater.html
Ordinary electric tank type can outlast all other water heaters, and be far simpler to fix yourself than any other type heater: including gas tank-type, electric hybrid tank-type, electric-and-gas tankless etc. More complicated heaters will eventually fail, and the lifespan is limited. Which is argument against buying expensive water heaters that are controlled by computer chip etc. Avoid tankless promotion. Tankless cost more..Period.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
May 01, 2013 | Water Heaters
41vr50 leaking at the top connnections
Copy following link for troubleshoot resources:
Replace rusted tank
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Prevent rusted tank.
If nipples are leaking, and they did not leak before, then tank has most likely rusted out and needs replacement.
Cause for rusted tank is depleted anode rod.
Inspect and replace anode each 1-3 years.
Oct 23, 2012 | Water Heaters
My water heater is leaking and only 4 years old. Will the use of a water softener void the warranty?
The warranty should not be void by using water softener, BUT read product manual.
http://waterheatertimer.org/Water-heater-manufacturers.html
1) First thing: Why is water heater leaking? Where is the leak?
For example, if you have electric water heater leaking from element, then replace element.
Replace leaking TP valve.
If water is leaking down vent pipe, and combustion chamber rusted out, then vent problem must be corrected.
These are not covered by warranty.
If tank is rusted out, then read below.
2) If water heater is rusted out after 4 years, you might have stray current corrosion.
This happens when hot and cold pipes are not connected together with a ground wire, and/or if cold water pipe is not grounded to earth.
This might not be covered by warranty.
3) Read water heater instruction manual for advisories.
Tanks rust out when anode rod is depleted. Softened water depletes anode rod faster.
Instruction manual says to check anode rod each year.
Checking anode rod is like checking oil on an engine. If oil was never checked and engine burned up, the manufacturer will not honor the warranty.
If anode rod is depleted, and tank is rusted out, the warranty might not cover the rusted tank since owner was supposed to check for anode depletion.
4) Anode rods can also be covered with calcium deposits and stop working.
This night not have anything to do with water softener, but anode stops working and tanks rusts out.
In any case the owner's manual probably says to check anode rod to prevent leaking from rusted tank
Sep 07, 2011 | Water Heaters
We have an ariston pro pi water heater and water is dripping all over from the bottom. How do you drain this? It is less thasn 5 years old
The tank is drained by removing tank, and using hot water outlet as a drain.
Under-counter tanks are not made with thick steel hull that adds cost and weight to product.
Water heater can rust out quickly if anode rod is not checked and replaced each year.
Anode rod depletion is faster if home has water softener.
All tank-type water heaters have replaceable anode rod that protects tank from rusting, and most water heater manuals include general description of anode and maintenance.
http://waterheatertimer.org/Replace-anode-rod.html#ariston
Rusted water heater must be replaced.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 06, 2011 | Bosch GL4Ti Ariston Pro Ti Electric...
Ariston GL6+ Occasional rusty water. Can this be remedied? Thank you Ed
Ariston GL6 6-gallon electric water heater has anode rod to prevent steel tank from rusting.
Once anode rod depletes, the tank rusts.
All tank-type water heaters have replaceable anode rod that can stop rusting, but will not repair damaged tank.
Open following links for resources + manual with parts number and illustration on page 7 and 10. Part number is shown as 570241 anode rod.
http://waterheatertimer.org/pdf/Bosch-GL_English.pdf
Jul 12, 2011 | Bosch Ariston GL6-plus GL6+ Point-of-Use...
Bubbling water at pressure releaf valve on top of valve. valve is rusted. rusty water in pan. Unit was installed new two years ago. Offer suggestions. Thanks
Rusted water usually means anode rod depleted and tank is rusting. Change 570241 anode rod every year or so.
Boiling water could mean bad thermostat causing run-away heating so water is released out of TP valve. Replace 994062 thermostat for 4 gallon.
Leaking water at TP valve could mean bad TP valve: replace TP valve with generic valve from hardware store.
Open link for diagram, parts and replacement information
Jun 14, 2011 | Bosch Ariston GL4 GL4 Point-of-Use...
I have a Reliance 501 electric water heater ... Everything works great but below the water out. Be rusty? How can I fix it?
The tank is rusting. Replace anode rod or replace water heater.
Once the anode rod depletes, then the tank starts to rust.
IF you can replace the anode rod, it will stop rusting, and then flush the rust out of water heater.
This might buy more life with same tank, but old anode rods are pretty solid and even impact wrench might not loosen it up.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flush
Loosen anode rod on new tank before installing, and then inspect every 1-3 years, and 1-2 years if water is softened.
Add a comment for more help.
Upvote the help.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Jun 08, 2011 | RELIANCE ELECTRIC WATER HEATER
I own a house with an electric GE hot water heater. 8ESOT12AA01 Serial # 090122 5750 I do not know how old the hot water heater is and advice about when it should be replaced. No leaks to date but I...
GE is made by Rheem, but the market is always changing. Rheem-based serial number shows tank was made in 1990.
Tank will last as long as anode rod(s) protects steel tank from rusting.
If your tank has two anode rods, then tanks lasts longer.
That's how companies determine if water heater is '6-year' or '12-year.'
I don't have manual for your product to say if you have 12 year tank. Side of tank might have information blurb besides mandatory label that shows serial number.
You can update your water heater by replacing anode rod(s) assuming they can be loosened and removed after this number of years, which is a big IF with old heaters. Your plumber might have impact wrench he uses to see if anode can come out.
If the water heater is making gurgling rumbling and/or crackling sounds then tank has sediment build-up.
You can also get a baseline of rust by flushing tank and watching if water is very rusty.
http://waterheatertimer.org/Water-heater-will-not-drain.html
If you flush tank regularly, and inspect anode every 1-3 years, a tank will last many years longer than manufacturer's label.
Apr 20, 2011 | General Electric Water Heaters
I have a hot water heater model # EES 52917. It is 8 years old. The tank has rusted around the top heating element. Why has this happened and what can be done about this issue. From what I understand...
AO Smith is biggest manufacturer and ships about 140,000 units per month sold under different brands. Look at rating on tank. Is it a 9 year tank? Or 6 year? Or lifetime?
Number of factors can cause rust around element:
1) Element is seeping moisture: check and replace element.
Elements can start leaking any time
http://waterheatertimer.org/Water-heater-is-leaking.html
2) Anode rod can be depleted from variety of factors including water softener or calcification over anode so it will not work: Check and replace anode rod every 1-2 years with water softener, every 3-5 without water softener. New anode rod will STOP the rust, but will not repair tank that is rusted.
Tanks with longer warranties have 2 anode rods, one on hot water nipple, the other on top of tank.
3) Stray current corrosion: add a jumper wire between hot and cold pipes, and make sure tank is grounded. If there is stray current, it will deplete steel in tank if tank is not grounded.
For example one fellow had a tank that rusted out every few years until he discovered his big radio antenna was grounded back to hot water pipe and the tank was not grounded, so the interference depleted his tank.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#Ground-tank
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail or phone while you work on water heater or any do-it-yourself project.
Feb 23, 2011 | Water Heaters
Water Heaters Logo
102 people viewed this question
Top Premier Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Premier Water Heater Expert? Answer questions, earn points and help others
