Question about Acer Computers & Internet
Getting in BIOS - aspire 5535-6637
How do I get into BIOS to get computer to BOOT from CD/DVD??
    Master:
  • 397 Answers
Try tapping F2 or DEL on the ACER logo splash screen when you first power up the system.
Posted on Mar 20, 2014
YourTech
  • 63 Answers
SOURCE: Can't find DVD drive under My Computer and regedit fix doesn't work for it
you may have to check the registry manually and if this will not work, you may have to reinstall windows.
1. click start > run > regedit > ok.
2. In Registry Editor, expand the following registry path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
3. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
4. Delete Upper and Lower Filters. (If only one is availabel, that's fine).
5. Restart system and check your drive again.
NOTE: Make sure to do this correctly or else, system will not load to windows.
If manually deleting upper and lower filters will not work then you may have to backup your files and reinstall windows.
Posted on Aug 26, 2008
  • 395 Answers
SOURCE: ACER ASPIRE 5100 DVD/CD ROM IS NOT DETECTED IN BIOS?
do you get an error 200 yet ? i got one here that does the same thing and its a bad motherboard. tried to replace cd drive and harddrive and was no help
the motherboard cost to much and not worth the part and labor
Posted on Dec 04, 2008
Fixe_You
  • 1800 Answers
SOURCE: i can't boot from external usb dvd/cd drive
please try to remove the connection between motherboard and vd/dvd drive.
then perform the previous steps.
Posted on Jan 27, 2009
My Aspire 5100 not only looses the cdrom but also the hard drive! It sometimes beeps 3 times.. I'd go into set-up (BIOS) and niether the hard drive or dvd would be listed.. As a last resort, I flashed the motherboard bios with the latest version from Acer and so far the problem hasn't returned. I also set the laptop to hibernate after 30 minutes of non use when both on battery or on ac power. Reason? My problem always started when I left my laptop unattended for some time. When I'd return, the computer would be off.. not asleep or hibernating, but off - even though it was set to never turn off in the power settings in windows. When I'd turn it back on, that is when the hard drive and dvd rom would vanish in the BIOS. So as an added precaution, I set the laptop to always hibernate after 30 minutes.. Like I say, so far so good..
Posted on Mar 25, 2009
jvernice
  • 63 Answers
SOURCE: Acer Aspire One has Hard drive Password frozen
There should not be a password set in the BIOS unless you set it up with one. You can clear the BIOS to BRAND NEW state. Acer can guide you through this if it is under warranty. If it is not, write back and I will help you do this.
Posted on Jul 28, 2009
ACER ax3470 boot
restart computer and push F12 then select DVD/CD bootable device then you can use it DVD
Jan 17, 2013 | Acer Aspire Ax3470 Desktop Pc Amd A6 3420...
Acer aspire 5740 DVD not recognized
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install. Check BIOS by pressing F key (correct F key is noted during boot) and make sure BIOS see's the Optical Drive.
Oct 25, 2012 | Computers & Internet
Acer aspire one ZG5 booking bios
have you change the settings of boot device from your bios?..in order for you to boot from CD or DVD once you install a windows, first go to your bios settings and change the boot device priority. The 1st boot should be the CD/DVD. Hope it helps thanks.
Nov 22, 2011 | Computers & Internet
How to reformat my computer Acer Aspire 4315? with cd or someother way
insert the bootable disk into your cd ROM.Restart the Laptop and goto your bios setup to change the first boot to CD/DVD ROM.save it and exit.it will ask you to press any key to boot from CD/DVD ROM.press and follow the wizard instruction
Feb 06, 2011 | Acer Aspire 4315 Notebook
Before reaching the login screen, my Acer netbook (1G and 160G harddrive) keeps shutting down. A blue screen appears with programming language on it for a brief second and the computer immediately...
What OS is your laptop.
If you have the correct OS CD / DVD, you should try and boot from this.
Inserting your disk and powering up the laptop it should automatically boot from the CD / DVD.
Follow the onscreen steps, then your should at some point be presented with a repair option.
If the laptop doesnt boot off the CD / DVD please select the relevant option when booting up to
enter the BIOS.
From the BIOS change the boot order to boot from CD-ROm 1st.
Let me know how you get on.
Nov 25, 2010 | Acer Aspire One Netbook 8.9" Notebook
How to reset the bios on an acer aspire idea 510
Insert the original "System Restore" CD/DVD into the CD/DVD drive.
Restart the computer.
Press a key to "change boot order".
Choose to boot from the CD/DVD drive.
Does your computer start to read the disk, and start to load something?
If so, then there's _nothing_ wrong with your computer that _WOULD_ be corrected by doing a "reset" of the BIOS. Put differently, try a "reset" of the BIOS *ONLY* as the _LAST_ thing that you try.
It's more likely that your 'C:' drive has a problem that prevents Windows from loading.
Take your computer to a qualified technician, for more trouble-shooting.
Jun 12, 2010 | Acer Aspire iDea 500 PC Desktop
Aspire sa80 how to get it to boot up with dvdrom so i can install vista
Enter bios setup by pressing F2 key or DEL key. Once you are in bios setup, go to BOOT or STARTUP setup. Look at the list of devices listed from first to last. It might has floppy or hard disk as first boot list. By using + - or pageup/pagedown, move your dvd rom to first place. This means that when you startup your computer, dvd rom should pick up as first boot. Don't forget to put the vista cd in the rom before your computer starts. Just a basic thing to remember, make your dvd rom first priority on boot or startup list. After finishing the loading, make sure to reverse the setting back to normal. Thanks
May 16, 2010 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
Cd/dvd drive missing on my computer
Enter in the BIOS and see in the boot order or the internal units if the dvd unit is still there. If it isn't then it's dead, replace it.
If it is then you didn't do a correct reinstall. Enter the bios again and make sure the dvd unit is the first in the boot order, boot from a Linux Live-CD like PCLinuxOS and from Computer Management/ Hard Disks  delete all partitions, format the entire disk to something else then format it again to NTFS or FAT. This is the only way you can be sure you are doing a clean install.
Oct 04, 2009 | Acer Aspire 4520-5582 Notebook
Im trying to put my pc bak to factory settings but the disc will not auto run
For that you need to SEt first boot device as your cd or dvd rom in bios.
When you power up the computer press F1 oe F2 or "del" key to enter in bios .
Then go to boot option then set first boot device as your cd or dvd rom then save settings and exit.
Then resatrt if your recoveri disk in rom then your computer boot with it.
Let me know if you need more assistanse.
Thanks.
Sep 26, 2009 | Acer Aspire™ T180 PC Desktop
Acer Aspire 3620
flash the bios to the latest version (bios flash update available on the computer manufacturer's website). if this is a bios glitch, flashing the bios will solve the problem.
Sep 25, 2008 | Acer Aspire 3050-1733 Notebook
Computers & Internet Logo
104 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
