Question about Unknown Us Patrol Video Patrol Security Camera
Setting the cam
Hello, I am new at this and have attempted to set the camera to only film at night; however, it does so all the time. What have I done wrong and what do I need to do? The manual is very difficult to understand.
I can record, i can take pictures inside or when it is night but i can not take pictures with the light of the day or when there is a strong light. I can see from the lcd monitor the icon bute when i take...
You have the ISO Setting set too high. This is the setting that in a film camera was called 'film speed'. The higher the ISO, the better it will take pictures in low light. Yours may be set to 3,800 ISO, when it needs to be on 200 or 400. The light during the day is bleaching out the sensor and that is what you are seeing on the screen. Also the higher the ISO, the more grain you will see in images.
Understanding ISO - A Beginner's Guide - Photography Life
https://photographylife.com > Photography Tutorials
Sep 4, 2017 - The lower the ISO number, the less sensitive it is to the light, while a higher ISO number increases the sensitivity of your camera. The component within your camera that can change sensitivity is called "image sensor" or simply "sensor".
Film speed - Wikipedia
https://en.wikipedia.org/wiki/Film_speed Film speed. ... Film speed is the measure of a photographic film's sensitivity to light, determined by sensitometry and measured on various numerical scales, the most recent being the ISO system. A closely related ISO system is used to describe the relationship between exposure and output image lightness in digital cameras ... ‎Film speed measurement ... · ‎Film sensitivity and grain · ‎Digital camera ISO speed ...
What is ISO (Film Speed)? - I STILL SHOOT FILM
istillshootfilm.org/post/592532284/what-is-iso-film-speed As I explained in How Film Works, photographic film is made up of millions of light-sensitive silver halide crystals, which we call grain. The lower the film speed, ... film iso explain in digital photography Google Search
Oct 31, 2017 | Canon PowerShot Pro1 Digital Camera
When i turn on my fuji polaroid cam, there is an "E" error message. I can't take any polaroid pictures with it altho the polaroid cam is loaded with film. Please help. Thanks
First, remove the remaining films from the camera. (while your camera is switched off) Second, press on both the shutter button and the power button at the same time. (to reset) Third, reload a new set of polaroid films into the camera.
Hope it helps!
Dec 26, 2010 | Fuji instax mini 7S Film Camera
TAKING NIGHT SUNSET PICTURES
this is becouse your not setting the "white balance"
up in the camera first,,,some digital cameras have a manual set up for "white balance" what the camera is doing is trying to put the color cast thats in a sun set right so it looks like day light,,,and you wont that color cast in the pitcher to give it that feeling,,,unless you over ride this white balance you will never get the color you are after,,, i use 35 mm film for sun sets
it will wip a digital camera every time here,,
but its horses for corses,good luck with your sun sets,,, but over ride that white balance first if you can
Nov 16, 2009 | Kodak EasyShare Z712 Digital Camera
Zoom
Generally when a camera refuses to take the photo is because you are operating beyond its expected lighting settings. If you are on automatic, it will just flash a light at you, or give you some indication it is beyond the limits of that setting. Try manual, or some other setting like landscape, or backlight. Generally this will happen on automatic settings.
Film? Try the f16 rule. In broad daylight, the rule is use f-16 and a shutter speed that matches your film's asa. So 100 ASA film? Shoot the sunset at 100th at f-16. Darker, open it up two or three stops. f-11, 8, or 5.6.
Bottom line, make sure you are on manual. The problem is likely an automatic exposure.
May 29, 2009 | Minolta Dynax 404Si Film Camera
Videoing or taking picutres at night
This camera is not designed for use in extremely low light. The sensor needs ample light to record a clear picture. You can compare this to using different speeds of film and needing to leave the shutter open for a longer time during night photography with still cameras. Unfortunately, there is no fix for this other than buying a light to use with the camera...unless it has an infrared setting (but then, everything would be green)
Nov 07, 2008 | Vivitar DVR-550 DV Camcorder
When using flash it flashes multiple times when taking picture..strobe flash
Hello
You will find that if the flash pulses slowly several times before taking the main picture you have got the camera set to red eye reduction flash, you will see an eye symbol on the display.
Check the owners manual for the method of changing this to the setting you need.
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/dynax_maxxum_400si/Maxxum400siManual-Part1.pdf
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/dynax_maxxum_500si/Maxxum500siManual-Part2.pdf
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/dynax_maxxum_500si/Maxxum500siManual-Part3.pdf
Above are the links to download the owners manual for this camera.
Hope this helps
Sep 25, 2008 | Minolta Maxxum 400si 35mm SLR Camera
Nikon F100, N90 & N80
"End" can be a message for "film over" or for a film jam in the cam. Did you check for this already?
Jul 26, 2008 | Nikon F100 with 28-80 and 70-300 lens 35mm...
Night shots
Hey matty reps,
You are attempting one of the most challenging types of photography there is, because you are combing nighttime photography and action photography. If you want to stop the action you normally would be using the highest shutter speed possible, but since you are trying to take nighttime action photographs I would rely on a flash since the flash duration in essence becomes your shutter speed. I would definitely use a hotshoe mounted flash because the built in flash will most likely not be powerful enough for your needs. I would have the camera set to aperture priority so I could control the depth of field, because the smaller the aperture the larger depth of field you will have and the less likely your subject will be out of focus. If you are attempting natural light nighttime action photography you will definitely need a very fast film speed such as 3200 speed film which will provide significant loss of image quality. You will also need a very fast lens meaning a lens with an aperture of at least f2.8 or larger, and your camera in this scenario should be set to shutter priority so you can set the camera to the fastest shutter speed possible but this will present focusing issues. In both scenarios I would have the AF system set to continuous so the camera doesn't require you to achieve focus to be able to trip the shutter. As in all challenging photography situations more photos are better than less, because you should have more failed photos than successful. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 28, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Blurred night time football pictures
The standard canon 75-300 lens is not considered a "fast" lens. Because of this, when zooming in on objects you are actually reducing the amount of light hitting the image sensor. Fast lenses cost $$$$. Just google "Canon L Glass" and you will see what I'm talking about. Try opening the field of view (zooming out) to allow more light to be absorbed bu the image senor. Crop your subject later in whatever software you use. You can also use one of the manual modes and up your f-stop to make the camera more sensitive to low-light conditions (higher f-stop means higher film speed.. higher film speed is how fast the "film"... aka image sensor absorbs the light. for action photos, faster film speed is key!!). have fun experimenting.
Sep 26, 2007 | Canon Digital Rebel XT / EOS 350D Digital...
Unknown Us Patrol Video Patrol Security Camera Logo
46 people viewed this question
Top Unknown Video Cameras Experts
Are you an Unknown Video Camera Expert? Answer questions, earn points and help others
