Question about Sony Vaio VGN FZ11Z.CEK Laptop Universal AC Adapter 18-20v (AC22VPNBTAD5J)
Wont read discs
Cd drivers are present but it wont read any discs
    Master:
  • 397 Answers
I would try giving the laser lens in side the CD drive a very gentle wipe with a cotton bud and alcohol first of all. This should be easy to access on most laptop designs, just press eject and you should be able to see and access the laser diode there in the CD tray.
Posted on Mar 20, 2014
CD player rotates but wont play or read disc.
Cd spins but player can not play - ecoustics.com
www.ecoustics.com > Forum > Home Audio Forum > Mini Systems Forum
Oct 30, 2003 - Cd spins once system is on but player can not read discs. ... Traywon't eject. ... I have a Memorex 2Extreme CD player, and I insert the disk, and pushplay, and the CD acts like it's searching for awhile and then the screen ... Dvd player won't read any CDs (but use to ) - eCoustics.com
Sep 22, 2005
Cd makes clicking noise and I get Disc Read Error PLZ HELP ...
Dec 24, 2004
CD Player screen reads no disc - ecoustics.com
May 30, 2004
More results from www.ecoustics.com
How to fix a boombox CD player when it wont play - YouTube
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
How to fix a boombox CD player when it wont play .... My box reads "no disc", but it is in proper position ...
Dec 22, 2015 | Audio Players & Recorders
Sony cdp-c215 wont read disc removed cover disc doesn't spin
The pladder motor that spins the disc is open, or the laser pickup is defective, the whole laser assembly would need to be replaced, not cost effective to repair cheaper to buy.
Apr 16, 2012 | Sony 5-Disc CD Changer with SA-CD Playback
My Toshiba Model L505-S5993 laptop won't read
Hello there,
The problem is that the Drives lens is already bad and cannot read any disc, no matter the type of disc you put into it, it wont read it still. The solution is to replace the drive. Replacing it is the best way to solve the problem. If not trying to replace the lens is going to be futile as the lens for the driver is not available and when you install a new disc drive, it will have to install the drivers software.
If you replace the lens, the laptop wont be able to install the drivers of the lens as it reads it alongside the driver itself and if they are not compatible, it wont install the drivers software. So my best advice is for you to replace the CD drive.
My laptop is a typical example because my disc drive is also bad. And i had to replace the drive and not the lens.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 09, 2011 | Toshiba Satellite L500 Series Notebook
Dvd/cd is not working
You can follow these methods to try to isolate and resolve the problem. Use these methods in the order in which they are presented.
Method 1: Clean the disc
When you have problems with a CD or DVD drive, always check the disc first to see whether it is damaged or dirty. To clean the disc, follow these steps:
1. Remove the disc from the drive.
2. Clean the disc with a disc cleaning kit or by gently wiping the silver side of the disc from the center outward with a dry, soft, lint-free, cotton cloth.
Note Do not use a paper cloth, and do not use a circular motion to clean the disc. These can scratch the disc.
3. Reinsert the disc in the CD or DVD drive.
If the computer can read the disc, you are finished.
If the computer still cannot read the disc, go to step 4.
4. Try again to clean the disc by using a cloth dampened with water, or dampened with a commercial CD or DVD cleaning solution.
5. Dry the disc thoroughly, and then reinsert it in the CD or DVD drive.
6. If the computer can read the disc, you are finished.
If the computer still cannot read the disc, go to method 2.
Method 2: Check the disc for damage
If the disc is clean, check whether it is damaged. To do this, follow these steps:
1. Remove the disc from the drive, and then examine the disc for scratches or cracks.
2. If the disc is damaged, try another disc to see whether the CD or DVD drive can read it.
3. If the computer still cannot read a disc, there may be a problem with the drive. Go to method 3 to troubleshoot the CD or DVD drive.
If the computer can read the other disc, there is a problem with original CD or DVD. Contact the manufacturer of the damaged disc to obtain a replacement.
Method 3: Try a different disc drive
If the disc is clean and undamaged, check whether there is a problem with the drive. To do this, follow these steps:
1. If the computer has more than one disc drive, insert the disc in a different CD or DVD drive to see whether it can read the disc.
If your computer does not have more than one disc drive, you can insert the disc in a different computer.
2. If the other CD or DVD drive can read the disc, there may be a problem with your CD or DVD drive. Go to method 5.
If the other CD or DVD drive cannot read the disc, the disc may not be compatible with the drive. Go to method 4.
Method 4: Make sure that the disc is compatible with the drive
Check the following list to make sure that the disc that you are trying to use is compatible with your CD or DVD drive.
* A DVD disc is incompatible with a standard CD drive.
* A CD-RW disc is incompatible with a CD drive that does not support CD-RW discs.
* A DVD disc is incompatible with a drive that does not have a DVD logo on the front.
If the disc is compatible, go to method 5.
If the disc is incompatible, use a compatible disc or contact the vendor for a compatible replacement.
Method 5: Use Windows Update to check for updated drivers
If the disc is compatible with your CD or DVD drive, check for updated drivers that the CD or DVD drive may be missing.
Good luck
Jan 21, 2011 | Computers & Internet
Disc drive not reading disc
To best respond to your question, let me review what happens when the unit tries to read the disc. First a check is made to see if a disc is present at all. If a disc is detected, the next step is to spin it up. You should be able to hear this happen. OInce the disc is spinning, the initial track (closest to the center of the disc) is read. If the read fails, a number of times, the mesasge about not reading the disc is presented. This failure can be caused by a number of different things:
1) The lens is dirty
2) The disc is not spining at the correct speed
3) The disc did not get up to speed fast enough
4) The loading sequence did not complete.
5) Defective optics
I will list the typical solution for each of the possibilities above:
1) Clean the lens using a cotton swab and alcohol and try again.
2) Replace the optics assembly (motor is not a replacement part.)
3) Same as #2
4) Replace the loading belt located under the tray. (get help with this as it is a bit tricky to do without mis-timing the loading sequence.)
5) Replace the optics asembly.
To confirm that the optics are actually defective, try playing a music CD. If a music CD will play but a game or DVD will not and you have cleaned the lens, then the optics are likely to be defective. A game or DVD requires a different (higher) level of laser light to function than a CD.
Hope this helps,
Dan
Mar 09, 2010 | Microsoft Xbox 360 Console
My cd/dvd driver wont read any disc?
First clean the CD/DVD head by cd/dvd cleaner. If that doesnt work then probably you will need to get its read write head aligned or get the drive changed totally.
Nov 06, 2009 | Dell Inspiron E1505 Notebook
CD Drive wont read discs
clean first your cd drive by cd cleaner. if not its a problem in cd lens. change the lens. trust me!
May 20, 2009 | Acer TravelMate 2304LCi Notebook
My computer wont read computer games anymore
see my friend you first need to install msxml4.0
which you have within cd pack
1 open and see it .
install full game and then copy all files from crack folder.
2 paste in folder you installed it.
now u can play .
NECESSARY INSTRUCTIONS
1 YOU SHOULD HAVE YOUR DRIVERS
INSTALLED.
2 YOUR AUDIO DRIVERS SHOULD BE INSTALLED.
ENJOY THE GAME .
(ARKANTOS IS GOOD PLAYER.)
Mar 25, 2009 | Microsoft Age of Mythology for Windows
No disc present
Try running a cleaner disc in the unit if that doesnt work try the following.
Starting at my computer... Right click on my computer icon.
Go to properties.
Then Hardware tab then go device manager. Right click on cdrom in device list. Select uninstall then reboot the computer. If this doesn't help replacing the unit will be necessary.
Jan 19, 2009 | LG GCC 4480B CD-RW/DVD-ROM Burner
Unable to play cd/dvd on my laptop
LINK
This is a dvd player codec.
LINK to sony support for tool necessary for dvd to read
May 19, 2008 | Siemens Computers & Internet
Sony Vaio VGN FZ11Z.CEK Laptop Universal AC Adapter 18-20v (AC22VPNBTAD5J) Logo
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
