Whe I start my pc a small window says the installer failed to exit a running instance of magic jack
When I start my pc a window says installer failed to exit a running instance of magic jack
    Master:
  • 397 Answers
I think magic jack relates to your sound driver/device. I would try removing and re-installing your sound driver. If you let me know your model of computer or sound card I may even be able to provide a download link for the drivers.
Posted on Mar 20, 2014
I have magic jack on windows7. I need to down load on my crome book as well
Magic Jack is not supported on Chrome OS. Below was taken from Magic Jack website.
magicJack supports the most popular operating systems in the world:
  • Microsoft Windows XP
  • Microsoft Windows Vista
  • Microsoft Windows 7
  • Microsoft Windows 8
  • Intel-Based Apple Mac
Oct 17, 2014 | Computers & Internet
Will this cost me money?when I start my pc a smsll window says,the installer failed to exit a running instance of magig jack
Try Press CTRL...alt ...del..together and hold them down
This should switch everything off. Pull the power plug. Pull the battery off.
Wait five minutes and power it on again.
If your desk top comes type "system restore" in the search menu next to start. Follow the link to the calendar which should pop up.
Restore back to a previous time when it was working properly
Mar 20, 2014 | Office Equipment & Supplies
How do I install my magic jack usb dongle and get it to work on my MS Surface running 8.1 RT
Your Magic Jack won't work on MS Surface with RT because Magic Jack is made to run on Windows. If you had Windows Pro 8.1 then it wouldn't be a problem. What you can do is install your Magic Jack to another computer. While you are away, you can remotely connect and control that computer (assuming you leave it on) with an App called Remote Desktop. This will let you hear the sound and use your mic from your tablet to make those calls. Good Luck.
Jan 02, 2014 | Computers & Internet
When i open my windows my magicjack doesnt open the magicjack install component setup shows this, the installer failed to exit a running instance of magicjack
Uninstall all components of your fist installation.For that you can use REVO uninstaller to erase all traces from the MJ installer.Then try again.
Oct 03, 2011 | magicjack.com
How To Install magic jack in window 7
First, from the magicjack device copy the magicjack folder to a CD or to a floppy under an earlier version of windows, (Windows 7 does not recognize the quasi CD that is on the device). Be sure that the Magicjack device has been upgraded to the latest firmware. Start Windows 7 Plug in the Magicjack device. (The Windows 7 drivers will load). If a window for magicjack vista pops up ignore and close it. Be sure to be connected to the internet. Run the .exe file from the media that you placed the copy of the magicjack files on, or copy the files to your hard drive then run them. Magicjack will upgrade. After this you only need to click on the Magic Jack icon to activate the device (of course, have the device plugged in).
Like Magic! It works. Thanks
May 23, 2011 | Computers & Internet
How to install the magic jack to window 7
To magic jack its works fine in windows 7, you should do the following things:
1. Copy the mjusbsp folder from a working install on XP or Vista to the C:\Users\UserName\appdata\Roaming folder in Windows 7.
2. Start it the no splash way to make it to load "C:\Users\UserName\appdata\Roaming\mjusb... ck.exe" /scf _magicJackPersonalDataRoot X:\magicJack
What's more, at the time of installing magic jack, do right click on the exe file and select the "Troubleshoot Compatibility". A window showing that Windows is testing the software. After completion it shows "Try recommended settings". Click on this settings that you will use. Click the "Start the program". Follow the on going instructions.
Nov 28, 2010 | Computers & Internet
PLEASE HELP ANYONE! I WENT INTO THE ADD/REMOVE PROGRAM SECTION WITHIN THE CONTROL PANEL! I THOUGHT THAT DELETING THE WINDOW SECURITY UPDATES FROM 2007/2008/2009 WOULDN'T CAUSE A PROBLEM, BUT IT...
Yes there is an option that you can use to restore deleted files. Its called System Restore. You did not provide any information about your Windows version so the procedure may be a bit different.
From XP onwards the System Restore option is found: Start --> Programs --> Accessories --> System Tools --> System Restore. You can also access it through Help and Support by typing System Restore in search bar.
Try restoring your Windows to a date where it worked fine. Try the most recent date before you started experiencing this issue.
You should also check if the Magic Jack is working OK by plugging it another PC.
If System Restores fails, its better to backup your data on D: and reinstall Windows than to keep looking for a solution. This will save you time and frustration.
Aug 08, 2010 | Acer Computers & Internet
I cant log out of facebook
Try deleting your cookies. Use one of the below options: How to manually delete cookie files in Internet Explorer 8 loadTOCNode(2, 'moreinformation');
  1. Exit Internet Explorer 8, and then exit any instances of Windows Explorer.
  2. Do one of the following:
    • In Windows Vista, click Start Collapse this imageExpand this image vistastartbutton.jpg, type inetcpl.cpl in the Start Search box, and then press ENTER
    • In Windows XP, click Start, click Run, type inetcpl.cpl in the Open box, and then press ENTER.
  3. On the General tab, click Delete under Browsing History in the Internet Properties dialog box.
  4. In the Delete Browsing History dialog box, click to clear all of the check boxes except for the Cookies check box.
  5. Click Delete.
To verify that the cookie files are deleted, follow these steps:
  3. In the Internet Properties dialog box, on the General tab, click Settings under Browsing History.
  4. In the Temporary Internet Files and History Settings dialog box, click View Files. This opens the folder where your cookie files are stored.
  5. In the folder that you opened in step 4, verify that there are no .txt files.
How to manually delete cookie files in Internet Explorer 7 loadTOCNode(2, 'moreinformation');
  1. Exit Internet Explorer 7, and then exit any instances of Windows Explorer.
    • In Windows Vista, click Start Collapse this imageExpand this image vistastartbutton.jpg, type inetcpl.cpl in the Start Search box, and then press ENTER.
  4. In the Delete Browsing History dialog box, click Delete Cookies.
  5. In the Delete Cookies dialog box, click Yes.
To verify that the cookie files are deleted in Internet Explorer 7
How to manually delete cookie files in Internet Explorer 6 loadTOCNode(2, 'moreinformation');
  1. Exit Internet Explorer 6, and then exit any instances of Windows Explorer.
  2. Click Start, click Run, type inetcpl.cpl, and then press ENTER.
  3. On the General tab, click Delete Cookies in the Internet Properties dialog box, under Temporary Internet Files.
  4. In the Delete Files dialog box, click to select the Delete all offline content check box, and then click OK.
To verify that the cookie files are deleted for Internet Explorer 6:
  2. Click Start, and then click Run, type inetcpl.cpl, and then press ENTER.
  3. In the Internet Properties dialog box, on the General tab, click View Files under Temporary Internet Files.
  4. In the folder that you opened in step 4, verify that there are no text files.
Jan 19, 2010 | Facebook Social Network
My Magic Jack software does not load into my Windows XP PC
are you running NT or is it the xp form 98 that you are running? a little confused.
Nov 19, 2009 | Computers & Internet
"warning you must plug in magicjack"
check the connections. Get ahold of magic jack you may have to format your magic jack
May 24, 2009 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
