Question about Refrigerators
Not making ice, indoor water spout working
My icemaker will not make ice, the indoor water spout does work and the mechanism inside the icemaker seems to be working. What could the problem be. Also when it did make ice the ice seemed to be hollow.
  • 585 Answers
Check the temperature in the freezer. The temperature must be below 0 degrees for most icemakers to perform properly.
Posted on Jun 14, 2009
  • Bruce Volkers
    Bruce Volkers Jun 21, 2009
    What IS the temperature in the freezer?
Icemaker not making ice
If no water is getting to ice maker either the water feed solenoid is not working, the water line is no good, or the cam mechanism of the ice maker is not switching the solenoid on.
Oct 05, 2016 | Refrigerators
Where do I find the ice maker inlet water valve or solenoid? The valve on the back of my fridge has only one hose going to both the water dispenser and ice maker and the water dispenser works fine.
Since there is water that flows to the water dispenser, the water valve is working. Now, there's a spout that water flows from to the icemaker tray. Look for it. It's located on the back wall inside the freezer and maybe behind the icemaker tray. Check and see if it's frozen. If so, defrost your freezer by turning the temperature gauge to off position. Wait a while until it's defrosted, then turn it back on.
Next, make sure that the metal wire is in down position.
If that doesn't work, your icemaker maybe defective and needs replacement.
Nov 01, 2014 | Maytag MFI2665XEM Stainless Steel
Have a Maytag side by side with ice maker...it quit making ice within 3 months of installation. Had one repair man look at it...said that it was a common problem w/ Maytag...hit ice maker with his fist a...
Assuming it's not still under warranty, I would probably replace the icemaker components inside the freezer.
The repairman's "fix" indicates that there is some kind of problem with the "brains" of the icemaker. It would probably not be cost effective to try to diagnose and fix the problem.
Oct 12, 2009 | Maytag MSD2756G Side by Side Refrigerator
Whirlpool indoor ice maker not making ice
Could not locate your model number. However, Check fill tube for icemaker inside the freezer. Iced solid? replace water valve. No ice in fill tube? Get correct model number and resubmit your request.
Sep 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The water isn't coming out of the spout on the ice maker. The ice is working, just not the water.
Sounds like you have a bad water valve. Look and see it the spout where the water comes out to fill your icemaker has ice in it. If so, you have a seeping water valve.
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE icemaker is not working
*It could be the water inlet valve.
* It could be the water fill spout in freezer could be plugged with ice. this can be thawed with warm water or a hair dryer.
Hope this helps.
Aug 14, 2009 | GE Refrigerators
Water Dripping and freezing from icemaker fill spout.
I appears that no one offers solutions to the hundreds of requests on your website. I don't have enough time to wait for an answer from you folks.
Aug 03, 2009 | GE Refrigerators
The icemaker in my Bauknecht KGN 7010 F/F has stopped making ice
First you need to find out if the lie is blocked. Disconnected water feed and try to run water through it into a bucket or sink. If you get water it is a valving problem. Also make sure the filter is clear.
Dec 29, 2008 | Freezers
Firgidaire FRS20ZRG Side by Side Refrigerator/Freezer Ice maker not working
reach into the icemaker and with a finger pull up on the ejector blades on the icemaker watch the blades and see if they go all the way around
Feb 13, 2008 | Refrigerators
Whirlpool icemaker
I changed the filter and it stopped making ice. I finally discovered that the rubber fill spout had frozen somehow. I heated the tube with my wife's hair dryer and the top of the fridge just above the tube. A pencil sized chunk of ice fell out of the tube and it started making ice again.
Jan 16, 2007 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Refrigerators Logo
307 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
