Question about Sewing Machines
How to thread juki 51e
I can't figure out how to thread my machine can you give me pictures to easily follow
    Champion:
    Habit-Forming:
  • 201 Answers
yalmer
  • 549 Answers
SOURCE: threading a juki ddl 5530
Go to this link and you will find how to thread your machine.
Posted on Apr 02, 2008
  • 13 Answers
SOURCE: juki ddl-227 industrial machine
Before all else. Turn off machine!
(1) break screws on the hook loose.
(2) tighten one back up very skightly, one you can reach when the needle bar is at its lowest position.
(3) lower needle bar to its lowest position.
(4) loosen the screw just tightened.
(5) position the tip of the hook behind the needle hole. the tip should be as close to the needle hole as possible without actually touching the needle
(6) tighten screws
(7) slowly hand turn the machine (depress the foot pedal to disengage clutch brake on motor) several revolutions to make sure the needle doesn't hit anything on the hook.
(8) if it passes this test, try on a scrap of fabric
Posted on Dec 15, 2008
  • 5 Answers
SOURCE: threading juki DDL-227 machine
There is a free download threading diagram for the DDL-227 here:
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_552_553_555_227_Threading_Diagram.htm
Posted on Mar 23, 2009
sew dutch
  • 24 Answers
SOURCE: Juki HZL-E61: cannot get tension right on straight stitch
Loops on the bottom of the fabric direct the problem to the top thread. Rethread again and make sure the thread goes through the tension discs. Lift the foot, because this is what opens the discs. When sewing and the foot is down, the discs should be closed and thus giving the upper thread the tension it needs.
Posted on May 25, 2009
  • 1116 Answers
SOURCE: good diagram showing how to thread a 4 thread Juki
You can download a free threading guide here - http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_MO_644_Threading_Diagram.htm
The same site also sells manuals.
Threading Tips:
Have the thread antenna at it's highest position.
Set the tensions to zero.
Have the presser foot up while threading.
When you thread a serger for the first time, or if you are having a threading problem, use a different color thread for each guide. This can quickly indicate where the problem lies.
Once the stitch is satisfactory, change to the color you prefer - but this way is the easiest - cut the thread near the thread cone and tie off with the new thread. With the tensions at zero, slowing run the serger until the new thread appears. You will need to stop as the knots approach the needles and thread them by hand.
Do the tie-off before running out of thread and this will save a lot of time and stress.
Posted on Mar 02, 2010
Threading diagram needed for the looping needles
There are quite a few pictures of threading diagrams on the internet. Just perform a search for the make + model + the word "threading."
Be sure to follow the threading order specified in your owner's manual. If the order is not followed accurately, the machine will most likely not work properly. Also, be sure to RAISE the presser foot BEFORE threading. While threading each thread, grasp the thread with one hand between the thread tree and the tension disk and grasp the thread below the tension disk with the other hand and gently tug the thread to make sure it has seated in the tension disk. With most sergers, the lower looper thread MUST drape over the top of the upper looper in its final threading process Before being pulled under the presser foot.
Juki MO 816 threading Google Search
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwiOt_7mqbHKAhVK52MKHc5XB5MQFggdMAA&url=http%3A%2F%2Fwww.raichert.com%2Fadobe%2FMO804-12-16%2520Inst.pdf&usg=AFQjCNH1vfonoEQ29McTsOItvQoW8ECZag&cad=rja
If any either looper thread breaks or comes unthreaded, it is the best advice to unthread all the looper threads and re-thread from the BEGINNING. Just bite the bullet and do it. It will save a lot of frustration.
Jan 17, 2016 | Juki Sewing Machines
Juki 8300N
Dear Rosemarie,
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
Cheerup and Be Happy always
Mar 27, 2008 | Juki DDL-8300
Need beginners manuel for 1541-s Industrial Sewing Machine
Contact your seller or Juki and ask for a threading diagram.
Sep 01, 2012 | Juki Sewing Machines
Correct threading for 4 th. Juki ind. overlocker
Overlockers and or Sergers are ALWAYS threaded the same way. Upper looper, Lower looper, right needle, left needle. If you have a model number for your Juki we might be able to find you more information.
The best way to figure out tension problems is to thread each thread in a different color so you can determine which thread is giving you problems.
These machines can be frustrating and EVERY time the thread breaks you MUST start the threading problem from the beginning... upper looper, lower looper, right needle left needle.
Aug 31, 2012 | Sewing Machines
THREADING FOR JUKI MO 357
Put new needles in it.
Following the colors, thread the upper looper first, then the lower looper. Next thread the needles. Always thread in this order.
Jun 27, 2009 | Juki MO-644D Mechanical Sewing Machine
May 25, 2009 | Juki HZL-E61 Computerized Sewing Machine
I have a Juki MO 3716 and I cannot thread it. Please help. It has four threads.
I also own a Juki MO3716. It is a five thread not a four as it has three lower looper threads. Two are fed through the front, just follow the color codes and the threading diagram on inside plate that you lower to see the threads, the third is threaded through the back and around the left side. I can send email with picture of diagram if needed. the other two threads are for the two top needles. This machine is a true safty stitch with the overedge row of serging and an inner chain stitch row for secure seaming. You can run this machine quite nicely with only three thread ( one inside needle and the two front loopers. If you need further held email me at wanmacinnes@eastlink.ca
May 23, 2009 | Juki Sewing Machines
Needle thread breaks while quilting on machine frame
My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
Nov 01, 2008 | Juki TL-98Q
Threading a juki ddl 5530
Apr 02, 2008 | Juki MO-644D Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
