Question about Thermor Bios Digital Home Weather Station
Problems with wind speed
I'm getting 000 for windspeed, --- for wind chill. The wind direction displays correctly on the 16 position cirlcle, but displays 000 in the middle. Everything else works, temp, rain, barom, inside and outside.
A/c blower motor works if I pull power and plug back in until I cut engine off. Then I have to repeat process
Daryl, You may want to check the blower relay/ just switch with one of same type and try and if OK, problem could be the blower motor, wires/plug loose,damaged,burnt or a faulty blower motor resistor. Second link has some trouble shooting of a overheating wire problem, that is to be common in these trucks. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DIY 2003 Silverado Blower Motor Resistor
Sparkys Answers Chevrolet Silverado Blower Does Not Work On Any Speed
03 Silverado heater fan problem ChevyTalk FREE Restoration and Repair Help...
Jul 19, 2016 | 2003 Chevrolet Silverado 1500
Tip
Caterpillar Fault Codes
CID code Name
1 Injector? 1
2 Injector, cylinder number 2
3 Injector number 3
4 Injector number 4
5 Injector, cylinder number 5
6 Injector, cylinder number 6
7 Injector number 7
8 Injector number 8
9 Injector number 9
10 Injector number 10
11 Injector number 11
12 Injector number 12
13 Injector number 13
14 Injector number 14
15 Injector number 15
16 Injector number 16
17 The fuel shut-off valve
18 The fuel control valve
19 Bypass valve accelerator
20 Device change timing of fuel injection
21 Position Sensor Engine
22 Sensor fuel injection advance
23 Drive Racks
24 position sensor rail
27 is a variable geometry turbocharger number 1
28 Drive with variable geometry turbocharger number 2
41 Power ECU (electronic control unit) 8 V DC
42 Valve inclusion nozzles
70 contact with the parking sensor
71 Timer stop idling
75 Oil temperature sensor circuit hydraulic steering system
The pressure sensor 81 at the inlet trap foreign particles
82 Pressure Sensor pnevmozapuska
84 speed sensor
91 Accelerator pedal position sensor
94 Pressure Sensor fuel pumping
95 The differential pressure sensor on the fuel filter
96 Fuel level sensor
98 Oil level sensor in the engine
99 The differential pressure sensor on the engine oil filter
100 Oil Pressure Switch Engine
101 pressure sensor crankcase gases
102 turbo pressure sensor
104 Oil pressure turbocharger
105 temperature sensor intake manifold
106 sensor input air pressure
Pressure sensor 109 of coolant downstream of the engine
110 Coolant Temperature Sensor Engine
111 level sensor, engine coolant
The differential pressure sensor 112 to filter engine coolant
124 gearbox oil level
126 differential pressure sensor on the oil filter transmission
127 Oil Pressure Switch gearbox
138 Mode Switch low traction
139 Solenoid tip ago
140 Solenoid tip forward
141 Eco Mode Switch
142 position sensor door to clean the radiator
143 contact pressure sensor control unit neutral
144 horn relay reverse
145 power supply circuit 12
146 Mode Switch hitch
147 pressure sensor lock-up clutch
148 pressure sensor in the hydraulic stroke
149 Three-way solenoid stabilization system of the implement when driving
150 Speed Sensor trambovatelya
151 Solenoid trambovatelya
152 diagnostic lamp control systems course
153 speed sensor right drive motor
154 RPM Sensor left actuator motor
155 solenoid switching stroke
156 Solenoid right turn in reverse (electronic display)
157 Solenoid left turn in reverse (electronic display)
158 Solenoid right turn forward direction (electronic display)
159 Solenoid left turn forward direction (electronic display)
160 Relay working equipment paver
161 brake sensor (chassis) pedal
162 Sensor Steering Wheel
The steering angle sensor 163 rotation
164 Pressure Sensor inclusion nozzles
167 Sensor charging voltage of the alternator
168 Electric system
171 of the ambient air temperature sensor
172 temperature sensor in the intake manifold
174 Fuel temperature sensor
175 Temperature Sensor Engine oil
177 oil temperature sensor Gearbox
190 RPM Sensor engine crankshaft
191 sensor output speed gearbox
248 data channel of Caterpillar
249 data channel J1922 SAE (Society of Automotive Engineers)
250 data channel J1708 / J1587 SAE (Society of Automotive Engineers)
Block 252 calibration
253 Personal chip control unit
254 electronic control unit
256 Map adjusting engine performance
257 Level detonation
258 sensor crank angle
259 set via software point fuel injection
260 oxygen sensor in the exhaust gas
261 the fuel injection timing calibration
262 circuit sensor supply 5 V
The power circuit 263 digital sensors (8 or 12)
264 pedal revolutions reduction
265 Input circuit stopping the engine, user-defined
266 Input circuit dry scroll engine (without fuel injection)
267 Chain input remote control signal Safe Stop engine
268 Error programmed parameter
269 circuit sensor supply
Code 270 cable computerized monitoring system (CMS)
271 Sound the alarm
272 sensor has exceeded the allowable turbo
273 pressure sensor at the outlet of the turbocharger
274 atmospheric pressure sensor
275 pressure sensor at the entrance of the right turbocharger
Pressure transducer 276 at the input of the left turbocharger
277 sensor calibration injection timing
278 The indicator light turn on the automatic control of engine speed (AESC)
279 coolant temperature in the intercooler front section
280 temperature sensor gear
281 The indicator light necessary Engine
282 Light indicator exceeding the permissible engine speed
283 Indicator Light air filter
284 Radio on EMS (electronic control system) (the signal of the engine)
285 overheating indicator light, engine coolant
286 Indicator light low oil pressure
287 Miniature digital output? 7
288 Miniature digital output? 8
289 Fuel pressure - before the fuel filter
290 pressure sensor in the pump drive engine cooling fan
The solenoid 291 engine cooling fan
292 solenoid hydraulic oil cooling fan
293 power analog output? 3
294 power analog output? 4
The control unit 295 hydraulic excavator heavy-duty
296 gearbox control unit
297 all-wheel drive system control
298 The probe brake pedal
299 position sensor gear lever
300 The primary windings of ignition coils
301 The primary winding of the ignition coil? 1
302 The primary winding of the ignition coil? 2
303 The primary winding of the ignition coil? 3
304 The primary winding of the ignition coil? 4
305 The primary winding of the ignition coil? 5
306 The primary winding of the ignition coil? 6
307 The primary winding of the ignition coil? 7
308 The primary winding of the ignition coil? 8
309 The primary winding of the ignition coil? 9
310 The primary winding of the ignition coil? 10
311 The primary winding of the ignition coil? 11
312 The primary winding of the ignition coil? 12
313 The primary winding of the ignition coil? 13
314 The primary winding of the ignition coil? 14
315 The primary winding of the ignition coil? 15
316 The primary winding of the ignition coil? 16
317 load cell
318 Right knock sensor
319 Left knock sensor
320 RPM Sensor / injection timing
321 Key switch reset / diagnostic confirmation
322 engine stop switch
323 The indicator light engine stop
324 Alarm lamp
325 detonation caused by the ignition system
Detonation System 326
327 Wrong number of knock sensors
328 Wrong number of cylinders of the engine
329 Error Link
330 Login with contact sensor propane content
331 Ignition Switch
332 keyboard switch
333 switch alarm
334 Reserve output
335 solenoid screw scraper
336 switch engine control
337 Remote Switch emergency stop
338 Relay pre-lube pump motor
339 contact pressure transducer pre-lube the engine
340 solenoid shut-off air
The solenoid 341? 4 warm-hydraulic distributor
342 Auxiliary speed sensor engine crankshaft
343 injector NOx catalyst in the exhaust gas
344 Relay injection pump converter of nitrogen oxides in exhaust gases
Pressure sensor 345 of the injection NOx catalyst in the exhaust gas
346 Relay stabilization system of the implement when driving
347 solenoid feed control (working volume) motor hydrostatic transmission
348 lock switch gearbox
Solenoid 349 gearbox synchronization
350 position sensor rod lift
351 position sensor rod misalignment
352 Sensor lift lever (in the cockpit)
353 sensor lever skew (in the cockpit)
The solenoid 354? 1 lift
The solenoid 355? 1 lowering
The solenoid 356? 1 unloading
357 Solenoid No. 1 return
358 Drive pressurization of the control loop hydraulic system work equipment
359 solenoid locking lifting
360 solenoid lock lowering
The electromagnet 361 tilt lock to download
362 solenoid control the fan speed of the engine
363 Drive stabilization system of the implement when driving
364 pressure sensor piston cavity lift cylinder
365 switch for limiter
366 contact gauge semiautomatic recess
367 Switch stabilization system of the implement when driving
368 switch, automatic / manual mode transmission
369 Login with shift indicator on the gearbox
370 Solenoid floating position arrows
Solenoid 371 beep
372 solenoid opening bucket (for excavator shovel)
373 solenoid closing bucket trucks through the hinged bottom (for excavator shovel)
374 Solenoid swing brake
375 Solenoid swing brake
376 Warning stroke
377-way solenoid brake
378 solenoid automatic lubrication system of the machine
379 Pressure Sensor automatic machine lubrication
380 contact pressure transducer modulation shift gearbox
381 Contact neutral position sensor lift lever (in the cockpit)
382 lever position sensor coupling
383 position sensor coupling
384 shifter
385 contact sensor neutral position tilt (in the cockpit)
386 solenoid lifting hitch
387 Solenoid lowering hitch
388 Contact line solenoid coupling
389 The probe neutral auxiliary lever
The solenoid 390 controlling the flow of hydraulic oil through the forward clutch
The solenoid 391 controlling the flow of hydraulic oil through the reversing
392 solenoid oil supply
The solenoid 393 to drive the front wheels
The solenoid 394 controlling the flow of oil through the drive motor
395 solenoid switch actuator pressure of the front wheel
396 Light on lamp-wheel drive (AWD)
397 contact pressure transducer feed pump
398 pressure sensor in the front wheel drive
399 sensor to the control lever-wheel drive (AWD)
400 The secondary windings of ignition coils
More Fault Codes HERE Caterpillar DTC
on Dec 20, 2016 | Cars & Trucks
Is there such a thing as a reset for the Autohelm WIND ST 50? I purchased a boat with one that showed proper wind angle but not speed. I removed the sender, greased both the wind vane and cuos. now
I assume you have an ST-50 or ST60 windvane setup. These are the calibration instructions from the unit manual for the ST-50. They are the same for the ST-60 and ST-60+ units.
Hope it helps you.
Initial Calibration Windvane Alignment
Before the unit is used for navigational purposes the masthead transducer must be accurately aligned to the vessel. Before this procedure is carried out the windvane should be linearised as follows.
1 . Powerup lhe ST50 Plus Wind instrument.
2. Tum the vessel through two complete circles, making sure that the windvane remains in line with the wind -the instrument will automatically linearise the windvane.
Alignment
1. Press and hold CAL for 2 seconds until CO is displayed by the LCD.
2. Press < > to move the pointer to the correct wind angle.- WIND
- Press < > once to move the pointer by 1 degree.
- Press < > for 1 second to move the pointer by 10 degrees/second.
The LCD will now display the applied correction.
3. Press and hold CAL for 2 seconds to exit and store windvane alignment.
Windspeed Unit Selection
1 . Press and hold CAL until Ul (Knots) or U2 (Meters/second is displayed.
2. Press CALwithin 8 seconds to change the windspeed units selection.
3. After 8 seconds the wind instrument returns to normal operation.
Nov 22, 2014 | Boating
Autohelm st50 wind
Go to Raymarine.com to find the usermanual for these units. They should be helpful.
May 06, 2013 | Boating
Can't find a switch to change the direction of the fan. Not on the wall switch. Minka Aire F701-PW 52-Inch Pewter Delano Ceiling Fan
Generally, the fan directional switch is located on the lower portion of the fan's housing. It will be a 2 position slide switch. Up for Winter, Down for Summer. Do not try to change the direction wihile the fan is ON or rotating. In the Summer, the higher the speed the better. As it generates a wind chill, that fools your body into thinking it cooler that what it really is.
Hope this helped you.
Jul 09, 2011 | Heating & Cooling
Reset oil change milage
GM OIL LIFE SYSTEM - RESETTING
The engine oil life monitor will indicate when to change the engine oil - usually between 5 000 km (3,000 miles) and 16 000 km (10,000 miles) since the last oil change. Under severe conditions, the "CHANGE OIL SOON" light may be displayed before 5 000 km (3,000 miles). The vehicle must not be driven more than 16 000 km (10,000 miles) or 12 months without an oil change.
Reset the oil life monitor when the oil has been changed, use the following procedure:
  1. Turn the ignition key to the RUN position.
  2. Fully push and release the accelerator pedal 3 times within 5 seconds.
  3. If the Change Oil Soon light flashes, the system is resetting.
  4. Start the vehicle.
  5. The oil life will change to 100%.
  6. If the Change Oil Soon light comes back on, the system has not reset. Repeat the procedure.
Mar 06, 2011 | 2004 GMC Sierra 1500 Crew Cab
Does the switch to change the direction of the fan need to be up or down to pull warm air down
In the winter you would want the fan turningclockwise and on most ceiling fans it is in the up position. and in the summer you want it in the down position running counter clockwise creating a wind chill effect.
Dec 11, 2009 | Aloha Housewares (93645) Ceiling Fan
Stop cooling
These are run on amonia so they dont freeze up as or in a compressor. You will first need to know that it is level. Then were you using LP or electric? You might want to verify that it is lighting and that the rear of the unit is getting hot. You can e mail me direct at hunter42558sbcglobal.net. I am willing to help you through this and I am a certified rv tech so I will know what to have you look for.
Jan 18, 2009 | Dometic NDR 1292 Refrigerator
St60 wind instrument
You might want to double check that all of the spade connectors that are used to plug the wind transducer into the ST60 wind display are firmly plugged onto the display's terminals.
Because of the blind connection, sometimes the terminal ends up lodged between the red insulator and the spade, rather than within the spade connector itself. This results in intermittent or missing readings from one part of the sensor or more.
Also make sure the display is in Master mode. You will need to get into its setup mode to confirm this. The other possible mode is repeater, which would be used if this were a secondary readout.
Dec 13, 2007 | Raymarine ST60 A22012-P GPS Receiver
Thermor Bios Digital Home Weather Station Logo
59 people viewed this question
Top Thermor Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Thermor Measuring Tool and Sensor Expert? Answer questions, earn points and help others
