Question about Frigidaire 24 in. FDB635RF Built-in Dishwasher
Door latch assembly
No power , used to start if i hit handle , now nothing
  • Official Brand Answer
  • 2,267 Answers
Good Morning Paula,
I see that you are having trouble with your Frigidaire dishwasher, model # FDB635RF, not starting after you close the door. Might I suggest trying to give the appliance a hard reset. You will do this by shutting the power off at the circuit for at least 2-3 minutes. When the power is restored, if you are still having trouble with the dishwasher starting up, I would suggest contacting either the manufacturer, or your local authorized technician for further assistance.
-Best Regards-
WP
Posted on Apr 04, 2014
Rear door latch will not open handle seems to have insufficient travel to free mechanism
Try pressing your left hand against the tailgate opening handle assembly (black plastic around the pull handle) while at the same time pulling on the handle to open it. I believe the entire assembly is being pulled out and you have to press on it, to hold it in place, while pulling on the handle. Make sure to hit open on the power lock a few times before trying this. Good luck.
Oct 23, 2010 | 1994 Jeep Grand Cherokee
Will not start after closing door, can select but does nothing when you push start. Acts if it is a sensor in the handle/latch assembly.
Here is a post I just sent to someone having similar issues. I copied just part of my solution. Hope it is helpful.
That was not to total solution in our case. I ended up ordering and replacing the door switch (a black plastic piece that is what the metal latch on the machine is supposed to "hook" into.
Replacing it is fairly simple. I did shut the power off for this. This part is replaced by taking off your face plate which is secured bu screws inside of your DW door around the edge. You will see 4 screws to remove and it "snaps" out. At this point you can see the working relationship with the latch, the switch and the contacts on the switch that the door latch (metal part coming out of the top of the DW) after replacing this...try the process again and hopefully your issue will be solved. I had to remove my latch and bend it back to the original shape and mess around with a slight bend to make it latch and hit the contacts in the door latch.
Apr 12, 2010 | Dishwashers
Unable to unlock the driver side door on a 1991 Honda Accord
You likely have a "link rod" that has either broken it's clip, or come unclipped from the lock and handle assembly. It could also be a broken door handle itself. It's very difficult to tell untill you have the door panel off to inspect. First, pull the door panel. Should be one screw in the inside door handle (#2 phillips), and 1 or 2 (can't remember) in the inside of the hand grab (also #2 phillips). To get the door latch and lock assembly off the door panel, after removing the screw push the assembly forward (towards the front of the car) and pull outward lightly on the back of the latch assembly. Once off, you will see two metal link rods with plastic clips on them, one for the door release and one for the lock. To remove the rods from the clips, look for the "open end" of the clip and push it. This will swivel the clip out of the way and the rod will lift out of the hole. About 90 degrees of rotatiojn should be enough, and from what I remember, they will rotate (looking down) counter-clockwide to release the clips After that, it's just door panel trees. If I remember correctly, there are between 8 and 10 of them. Start at the door catch/latch and work your way around. If you have a door panel removal tool, use it. If not, a single, or even better a pair of thin (1 inch wide) putty knives can be used. Flat blade screwdriver is the last resort. Once the door panel is off, check the other ends oif the link rods you just took off. If one isn't connected, bingo. If it is, then remove the door latch from the door frame using a 10mm socket and an extention. I believe there are 3 bolts holding the latch to the door. Check the opperation of the latch off the car using a screwdriver to act as the door striker, and opperate the levers the link rods move by hand. If the latch is bad, replace! the Stick
Dec 10, 2009 | 1991 Honda Accord
Machine not starting , door not closing well, no click from locking mechanism
The door latch and or door handle assembly which also holds the door switch may have brocken.
If the door latch does not shut properly, this will not close your door micro switch. And if the switch is not closed then the machine will not operate.
Turn off machine at the power source. Open the dishwasher door. You may want to put some weight on the door to stop it from springing back up.
If you have a star allen key or a star shaped tool, you can open the screws around the stainless steel plate of the dishwasher door. Start with the ones on top, which secure the control panel and door lock. See if you can remove the control panel gently without having to open the screws for the front door panel. Sometimes you may need to loosen the front panel screws to free the top control panel.
Once you remove the panel, you will notice a door handle assembly which also holds the micor switch. Take note of how it is set up. Also examie to see if any plastic parts are broken. You may need to order the complete door latch or door handle assembly and replace.
While doing this make sure the machine is turned off at the power source.
Good luck.
Ash
Nov 17, 2009 | Asko 24 in. D3121XL Free-standing...
Power door lock, driver side only, does not work in my '95 Sable
if you here a noise that should mean the little motor (door lock actuator) thar works the door lock is getting power to it and it should be ok. sounds like when you changed the inside latch you must have disturbrd/disconnected the linkage or the clip that connects the lock actuator to the latch assembly(the female V-SHAPED mechanism that engages the POST/STRIKER (male part) its a little hard to name these parts so i am describing them to you. look insidethe door and see if you see any threaded RODS OR LINKAGES that are not connected at both ends.the noise youre hearing is most likely the door lock actuator "spinning"up and down but its unable to lock or unlock the door latch mechanism.
Sep 01, 2009 | 1994 Mercury Sable
ELECTRIC DOOR LOCKS ONLY LOCK SOME TIMES
if you hit the lock button a couple times, will it finally lock?
If so, then you will need to take door cover off and lube up the connectors as they probably got corroded.
Aug 14, 2009 | 2000 Ford F350 Super Duty Super Cab
Door locked shut
usually wind down window using torch and sturdy piece of wire or long flat blade scewdriver bend anti theft plate out of way of lock assembly (if still there) and using wire or screw driver move latch on release catch centre bottom area of lock assembly while holding door handle (outer) up to pull door open when you hit the right catch
Jun 29, 2009 | Mitsubishi Sigma Cars & Trucks
Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
Apr 09, 2009 | Whirlpool WFC7500VW Washer
Rear door on driver side won't open,have taken the panel off the inside of car,seems like the lock won,t travelas far as it does on the other door.is there any way to open this door,thanks[1997 lincoln...
Rear
Removal
  1. Using a small screwdriver, remove the screw cover from the armrest of rear door trim panel (27406).
  1. Remove the two retaining screws.
  1. Using Trim Pad Removing Tool from Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent, pry rear door trim panel from door inner panel.
  1. Disconnect electrical connectors.
Installation
  1. Position rear door trim panel on door inner panel, aligning two locators on rear door trim panel. Reverse Removal procedure.
------------------------------------------------------------------------------------ Rear
Removal
  1. Remove door trim panel and watershield. Refer to Section 01-05 .
  1. Check all connections of remote control links and cables. Service as necessary.
  1. Remove remote control assembly.
  1. Remove door latch remote control assembly from latch assembly.
  1. Drill out rivet at bellcrank and link (264B14).
  1. Remove three screws attaching latch assembly to door.
  1. Drill out rivet that attaches actuator motor to door.
  1. Remove latch assembly with actuator motor and door latch control rod lever link assembly.
Installation
  1. Install new bushings and clip onto latch assembly.
  1. Install latch with links and power lock actuator into door cavity.
  1. Position latch assembly to door, aligning screw holes in latch and door. Install three screws. Tighten to 10-13 Nm (89-115 lb-in).
  1. Attach door latch actuator motor to door with a new rivet.
  1. Install bellcrank and link to door using a new rivet.
  1. Install inside door handle and remote control assembly to door.
  1. Open and close door to check latch assembly operation.
  1. Install watershield and door trim panel. Refer to Section 01-05 .
Item Part Number Description 1 221A00 Door Handle to Door Latch Actuating Cable 2 26446 Rear Door Control Rod Retainer 3 377901 Plug Button 4 26412 Rear Door Latch 5 W623451-S2 Push Nut 6 224A32 Counter Balance 7 22450 Door Outside Handle Tension Spring 8 W701210-S309 Screw 9 224A20 Outside Door Handle Anti Rattle Pivot (2 Req'd) 10 22404 Door Handle 11 224A24 Front Door Outside Handle Spacer (2 Req'd) 12 264A64 Rear Door Actuating Rod 13 22408 Outside Door Handle Anti-Rattle Bumper 14 22428 Outside Door Handle Large Pad 15 N621906-S2 Nut (2 Req'd) 16 N807329 Screw (3 Req'd) 17 26595 Rear Door Electric Latch Actuator (RH) 18 W701566-S47 Rivet 19 431C04-A Rear Door Latch Striker Assembly 20 — Door Lock Striker Plate (Part of Door Shell Assy) 21 W525172-S Rivet (2 Req'd) 22 264B14 Bellcrank and Link (RH) 23 264A50 Bushing 24 N802034-SG Rivet 25 26420 Rear Door Latch Control Rod Link 26 W525172-S Rivet (2 Req'd) 27 21818 RR Door Latch (Inside) 28 A26460 RR Door Latch Push Button Rod 29 21982 Door Latch Rear Striker Assembly 30 N808377-S101 Screw (2 Req'd) 31 250A04 Rear Door Catch 32 N801010-S100 Truss Head Bolt (2 Req'd) 33 N804234-S2 Screw 34 266A74 Rear Door Latch Actuator Retainer 35 24630 Rear Door 36 26552 Rear Door Latch Control Escutcheon A — Tighten to 21-29 Nm (16-21 Lb-Ft) B — Tighten to 10-13 Nm (89-115 Lb-In) C — Tighten to 7-8 Nm (62-70 Lb-In) D — Tighten to 26-34 Nm (20-25 Lb-Ft) E — Tighten to 3-4 Nm (27-35 Lb-In)
Mar 24, 2009 | 1997 Lincoln Continental
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Frigidaire 24 in. FDB635RF Built-in Dishwasher Logo
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
