Question about Sirius Kitchen Ranges
Hood range fan makes noise like it might need new fan motor brushes. # on fan motor housing LN2 Gs50DT000
Low speeds fan makes noise like a paper caught if fan
Noggin
  • 944 Answers
SOURCE: Airking Granada 36" Range Hood - fan doesn't work
often these motors have a condensor on the side - a bit like a cross between the little white cylinder in a flourescent light housing and a starter motor - they are a bit vulnerable but are pretty cheap and easy to replace. Sounds like that is the problem - little click is it trying to start but not getting the extra help from the condensor. any good electrician should be able to fix it quickly, unless a part needs to be ordered in. he should also check if there is a fuse inside, and if the main part of the motor is ok. If the motor has died completely (which is rare) then it is still probably worth replacing, but might be a but costly. also there could be a relay connected to the switch (a way for a small switch to transfer heavier current to something) - and sometimes these can also fail. Also easy for an electrician to check and fairly cheap to replace. some motors also have a thermal protection device, which may be able to be reset by pressing a small button on the side somewhere, also possibly faulty and cheap and easy to check/replace. if you can look at the motor easily, just see if there is a small plastic push button switch (almost certainly connected to the body of the motor somewhere) if so, make sure the power is off, push it in and it should click to an "in" position. Might solve the problem. If you get a guy in to look at it and he is struggling to find the parts, please post again and we can try and source them online for you. If you fancy trying it yourself then post again and we can try and talk you through it, not TOO hard but you would need a bit of electrical knowledge and tools. Hope this helps :)
Posted on Mar 29, 2007
shaggyrat
  • 1224 Answers
SOURCE: Zephyr typhoon AK2100 Kitchen Range Hood
its the relay inside that controls which speeds the hood works at this connects to the switch speed control
Posted on Jun 01, 2008
SOURCE: Ventline Range Hood Fan broken
In my RV, which should be similar, I removed the filter from the hood. With power off, I removed the fan, which was held on with a clip. Removed two screws holding the motor in and took it to a camper supply store. Mobile home supply would have had it, too. You might find the motor on line if you go to the website of the manufacturer or search for parts for that brand.
Posted on Sep 02, 2009
localwonder
  • 6784 Answers
SOURCE: noisy fan or motor?
HI. The most common issue here will be with a loose motor shaft. This is the part that the fan blades are mounted on. When this occurs, the looseness will cause the motor, and shaft to wobble, thus, causing this noise you here at high speeds. The wobble is less violent during the slower speeds, so it is not loud, in this case.
The second issue will be a warped fan blade. This will cause the fan to rub against the shroud, thus, creating the noise, as well.
If the shaft is loose, or bent, the entire motor will need to be replaced. Now, if the fan blade is warped, you can, simply, unscrew the blade from the shaft, and replace it(on most model)
Posted on Dec 11, 2009
SOURCE: Nutone WA6500 range hood fan motor noisy
We have the same product, 18 months in use and the very noisy motor has finally seized up. I contacted the manufacturer and was advised that I need a new motor, motor mounting bracket and fan rotor. The agent was not able to quote me a price for the parts but stated that even though my 1-year warranty had expired, if I faxed them a copy of the original sales reciept they could possibly send me the parts for free under the original warranty agreement. I've done as they asked but haven't received a reply as yet. After reading about all the problems with this product I'm tempted to dump the whole unit and try to find another manufacturer that has a reliable and QUIET range hood.
Posted on Jan 06, 2010
My Dremel 3000 makes a grinding noise and fluctuates speed while in the low speed range. Why is this?
I have one that I must keep pressing ******* the speed control with my thumb during use otherwise it is hopeless except at or near maximum. The potentiometer is of poor quality.
Jan 02, 2017 | Speed Washing Machines
Fan is not working but makes a humming noise at lower speeds and clanking noise at highest speed. When last working there was the clanking noise when I turned off the fan. Please help.
Then turn it off immediately just to be safe that nothing will be broken, can you see the interior? Is there anything broken or loose that might cause the noize? If yes remove.
If not try to clean it with a little cloth or anything, maybe it is too dusty.
Mar 10, 2016 | Electrolux RH36WC60GS Designer Glass...
Qasair CM900 Rangehood Motor not working properly
I have a twin motor Qasair Heritage 1200mm wide canopy and recently noticed (after 8 years of great service) that one of the motors was having a difficult time getting to high speed compared to the other. Turns out that it is indeed a faulty capacitor. I had the service tech out from Condari, and both capacitors replaced, restoring the high speed function to both fans. Call out fee was $99, each capacitor $15 and labour amounted to $25 for a grand total of $154. Very happy to hear the full force of the fans again! Here is a picture of the old capacitor, which is housed inside the metal box on the side of the fan unit.
May 20, 2012 | Kitchen Ranges
KitchenAid KHTU160KSS Kitchen Hood makes noise
Remove the fan and motor assembly from the hood (the fan motor will plug into the hood housing) and using an electrical motor cleaner (such as CRC electrical motor cleaner available from your local auto parts store) wash the motor and fan as completely as possible, lubricate the end bearings (sparingly) with a very light oil such as sewing machine oil, gun oil or as a last resort 3 in 1 oil. Hope this helps.
Dec 14, 2011 | KitchenAid KHTU160KSS Kitchen Hood
Noisy fan or motor?
Dec 11, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Wobbly Fan----Nutone Whispaire WA6500
Definetly need a new blade
#K7458-000 Boan/nutone part number
Dec 09, 2008 | Broan-NuTone Intermediate Whispaire ...
BABT83.2AL Canopy Rangehood The fan/suction is not working. A slight straining noise is heard. The light is working as is the display panel.
These units have a history of fan failure due to inferior 220 volt Italian fan.
I have just had fan fail and retrofitted a ebmpapst blower fan model D2E146HT6702 which is readily available in Aus for around $120.
The fan speed control is by inverter variable output so you don't use all the speed select wires that this fan has. Connect the Red wire on the range hood to the Black on the motor (High speed winding) and the Black on the range hood to the Blue on the motor (Neutral) and the earth to the earth (Green).
Disconnect and toss the cap in the white enclosure under the PC board enclosure (the new fan has the cap on board). Don't know how easy to fit in the range hood as mine is in an acoustic fan housing in the roof (makes it wisper quiet when running)
Apr 07, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
Dec 16, 2007 | Broan-NuTone Intermediate Whispaire ...
Noisy fan
MOTOR HOUSING IS CRACKED MADE OF PLASTIC
Nov 26, 2006 | Zephyr Pyramid ZPY-E30 Kitchen Hood
Kitchen Ranges Logo
115 people viewed this question
Top Sirius Kitchen Ranges Experts
Thomas Perkins
Thomas Perkins
Zeagle
Level 1 Expert
ray gallant
Are you a Sirius Kitchen Range Expert? Answer questions, earn points and help others
