Billion 400g How can I extend the wifi range. I have tried a wifi repeater what a waste of money
  • 3,320 Answers
Your repeater probably worked as it was supposed to but because you don't really understand the technology, users like yourself plug gadgets in, push the limits to the maximum and then wonder why it fails.
The best way to extend your network is to run an ethernet cable to a repeater.
Trying to extend a weak wireless signal via wireless will almost always be doomed to failure.
Posted on Mar 23, 2014
3 Suggested Answers
yboyandrei
  • 828 Answers
SOURCE: connection from billion 400g wireless adsl router to Fujitsu
please check your fujistu if there is wireless lan built-in...
Posted on Jun 16, 2009
  • 96 Answers
SOURCE: Change the local IP address of Billion 400G
You need to login to the router page with the IP 10.0.0.2 and the on that and you can change the IP from that page
On login it will ask for username and password it is admin and password is "password" by default if you have any issue in getting user name and password you can reset the router as below
To restore the factory default configuration settings without knowing the administration password or IP address, you must use the Default Reset button on the rear panel of the router. 1. Press and hold the Default Reset button until the Test LED turns on (about 10 seconds). 2. Release the Default Reset button and wait for the router to reboot.
it will come back to factory settings of 192.168.1.1 and then you need to configure the router as per your internet service provider
you can check the manual at the below link
http://kbserver.netgear.com/pdf/dg834g_dg834gb_ref_manual_03Jun05.pdf
Posted on Nov 27, 2009
My Netgear WN3000RP Wi-Fi Range Extender is not working since last night . please help
Try unplugging BOTH the repeater and the router, Then, plug the router back in and let it establish a connection. Then, plug the repeater in and let it reestablish the connection.
Feb 03, 2015 | NetGear Universal WiFi Range Extender...
Why doesn't my netgear extender ask for name and password when I try to use it to connect to internet. It tells me that there is an authentication problem
Hi there! smile.gif Please note that the Tenda 150mbps Wireless Range Extender A3 uses a default IP address of 192.168.0.254 - you must set your IP address to the 192.168.0.* range (* = any number between 2 and 253) to login.
The default access username / password (if required) are admin and admin.
Once you've logged in, you can configure the access point to route through your existing wireless router as the default gateway (eg. if your wifi router is 192.168.1.1, then you would route through that, and set your Repeater (Extender) IP to 192.168.1.2 so that you can connect to it and then "relay" your connection through the repeater. It doesn't mirror the connection details for the existing wifi router, it simply creates an "additional" access point to connect through to your existing wifi router - creating a bridge, essentially.
The extender can be linked to the existing wifi router via LAN cable or WDS. For WDS, you will need to set the IP's 1 digit apart in the last segment (see above IP difference), and switch them both in the Wireless menu to ""Wireless Networking Mode: Network Bridge (WDS), but the SSID must remain the same (eg. "Tenda1") for both of them (it doesn't cause a network loopback), and any wireless security authentication must be identical (password / pass phrase / key + encryption algorithm) on both devices. Again, as with the above point, remember to set the gateway of the extender / repeater to that of the primary WiFi router.
For extra information and disambiguation (if required), see the following page, and scroll down: http://www.enjoypad.com/wireless-access-point/96-tenda-...
Oct 26, 2014 | NetGear N300 Essentials Edition Wi-Fi...
How extend in built wifi
You can purchase a wifi repeater fairly inexpensively now if you are trying to extend the WIFI range of your existing network. They are pretty easy to setup. They mirror your existing network and you then place them on the outer most area that your network is able to reach. It then extends your primary network further out in that direction. You can add multiple WIFI extenders to a network to cover large areas like a motel or apartment complex.
Sep 24, 2014 | HP Computers & Internet
How to connect two wifi routers using modem....In home on one network???
while two WiFi connections can work, if youdo it that way you will need to disconnect from one and reconnect to other everytime you move from one extreme to the other. also you only extend your range by the distance from one to the other.
what you need (for a weak signal) is a repeater. it is a box designed to listen on one WiFi channel and repeat it on another. bin turn it also listens on the repeated channel for communication from your remote device and repeats it onto the original channel so it is as if the new channel is the original channel... place this repeater at half strength distance (power source will be needed but wires to base computer not needed) and you have extended your range by about half the distance...
to go further out just add another repeater (or more)
I googled "WiFi repeater" and was presented with a wide range of options (see photo for partial screenie)... generally the more expensive the further or wider the range... without even looking further i would suspect that the more expensive ones likely could even cover more range than two of that modem you showed combined
a few shown might be the kind with two units that you plug one near base computer and plug other farthest away from base... they not only use house wiring to power the units but also use the electric wire as an antenna for comunicating as if there were an ethernet connection between them.
fd91a783-bc64-463b-8de7-62ed56adbb31.pngMy
Jul 02, 2014 | Computers & Internet
Netgear extender not connecting
There's quite a bit to know about using WIFI network extenders / repeaters. Have a look here;
Simple Wireless WIFI range extender expander repeater
Apr 07, 2014 | NetGear Computers & Internet
My repeater does not find the wifi network
It is possible that the repeater isn't in the range of the wifi. Watch out for the range of wifi router and then place the repeater in that range.
Jul 30, 2013 | Uspeed WIFI Repeater Access Point...
Nov 27, 2009 | NetGear DG834G 802.11G Wireless ADSL...
Connection from billion 400g wireless adsl router to Fujitsu
Jun 16, 2009 | NetGear DG834G 802.11G Wireless ADSL...
Dwl-2100ap set up propblem
There's quite a bit to know about extending / repeating WIFI signals.
Read about extending a WIFI signal with a Sitecom WL-130 repeater here.
Sep 05, 2008 | D-Link AirPlus G Wireless Range Extender...
Computers & Internet Logo
111 people viewed this question
David Payne
David Payne
