Question about HP DeskJet 9800 InkJet Printer
Hp 9800 service manual
Printing errors
Hello, I get error code 10037 on my epson 9800 machine. It is 00010037 Print Head thermistor error. I would appreciate if you can tell me what is the reason of the problem and how can I solve it? T
Yes, the error code indicates it is a thermistor problem and it means the problem is with the printhead of the printer, the solution for this problem is replacing the printhead, but before that, you can try to remove the printhead from the printer and then clean the contacts with a cotton swab and distilled water, after that dry them up and reseat the printhead very carefully.
You can take help from the service manual, which you can download from the link below.
http://www.americaninkjetsystems.com/epson_mimaki_roland_printer_rep/9800svc_manual.pdf
Feb 24, 2015 | Epson Stylus Pro 9800 InkJet Printer
Service manual hp 9800
I have an HP 9800 Deskjet that I print heavier self stick vinyl paper. The print comes out wavy. Lines aren't strait and images get blurred. Seems like the rollers might be worn causing it not to pull paper in right and centered.
Mar 25, 2014 | HP DeskJet 9800 InkJet Printer
EPSON 9800 foutmelding SERVICE CALL ERROR 0001001B
did you used a non-original ink cartridge? if you did your printer says"ERROR 0001001B" is print head error. need to be replaced, send to repair.
Aug 08, 2010 | Epson Stylus Pro 9800 InkJet Printer
Black is printing gray
Has your printer defaulted to 'draft' printing? That's where grey printing seems to come from.
Feb 20, 2010 | HP DeskJet 9800 InkJet Printer
My Deskjet 9800 has both cartridge lights flashing. I've put in new cartridges and ensured that they are properly seated. I cannot print a test page.
you will need to replace the carriage assembly because the cartridge has punched a small hole in the circuit contact board, which broke the circuit
Feb 06, 2010 | HP DeskJet 9800 InkJet Printer
Hp 9800 prints only quarter page
Try sending less pages to print and see what happens.
Try one to test and if it workks then send 24 of the 48 pages and finally the rest.
Aug 28, 2009 | HP DeskJet 9800 InkJet Printer
Service Call Error 0001001D
Hi poulin,
Click here to access your printer's manual
http://support.epson.ru/products/manuals/000909/spro798400rg_e.pdf
Page 327 on that manual will contain information on how to troubleshoot service errors. On page 115, it talks about adjusting parameters for better print quality.
Hope you may use the manual to troubleshoot your printing errors on your own.
Apr 09, 2009 | Epson Stylus Pro 9800 InkJet Printer
DeskJet 9800 Streaks in Color Print
That is the problem, you need to expost the track wheels and clean them with a paper towel soaked in rubbing alcohol.
Jun 27, 2008 | HP DeskJet 9800 InkJet Printer
HP DeskJet 9800 InkJet Printer Logo
127 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
