Question about OfficeMax 0M96431 Shredder
Driven helical gear damaged
Sole part failure when shredder jammed and drive gear on motor continued to spin; chewed up the driven nylon gear teeth.
    Scholar:
  • 136 Answers
You are probably out of luck as the manufacturers usually don't sell any parts for lower-cost shredders. I would see if Office Max has a repair or trade-in program.
Posted on May 01, 2014
3 Suggested Answers
SOURCE: Office Max Shredder #OM96146
Don't open it, check on product warranty policy and take it back or send it in.
Posted on Jun 22, 2008
  • 8404 Answers
SOURCE: Officemax OM96580 has a stripped gear tooth on the
If you expect to repair this, expect to spend weeks waiting for parts if you can get them at all, at least an hour to do the work and expect to spend 2/3 the price of a new one for the parts.
My advice, my friend, save the collection can, discard the shredder. On your new shredder, dont over feed it.
Thanks
Posted on Oct 14, 2009
Indicates jam. Why won't it move forward or reverse?
Some material that can't be shredded is lodged in the mechanism. The drive motor may have sensed thermal overload and stopped working either permanently or until the shredder is unclogged. Obviously, you will have to get access to the grinding mechanism and (with power disconnected) remove the jamming material bit by bit.
Sep 29, 2015 | Office Equipment & Supplies
Paper jam
Does it sound like the motor is spinning? or does it sound like the motor is bound up? I ask because if it sounds like the motor is spinning, then chances are good you stripped a plastic gear somewhere in the drive system that feeds the steel shredder. I just pulled apart one of these and saw that the motor has a steel gear on it. that steel motor gear meets with a plastic gear, and then the plastic gear meets with steel gears attached to, and which spin the shredder. So if you ever bind the shredder with too much paper, the steel motor gear will grind the teeth right off the plastic gear and it won't spin anymore. If your motor sounds like it's bound, then the good news is that the gears aren't stripped. You'll have to take the shredder apart so you can remove the paper causing the problem. Of course unplug it first before opening it up. They are not overly complex but just remember where the screws goes so you put them back in the right holes.
Sep 01, 2014 | Office Equipment & Supplies
Shredder making a squelling noise
Royal shredders have a nylon worm drive gear that is designed to loose teeth rather than allow an overload to damage the whole gearbox. When the motor's worm drive hits an area where teeth have been removed it screams because it is no longer loaded!
This part can be replaced if you are handy with fixing mechanical devices and know how to safely do so. Spare internal parts can easily and quickly be ordered from Royal by calling 1-800-222-2310. I find their support people to be outstanding.
Oct 02, 2012 | Royal Office Equipment & Supplies
Is there a gear kit for the Fellowes MS-450CS Micro Shredder?
Hello Jay
I have the same problem. I found a place that sells nylon gears. They are not to good in responding back though.
This is the email address and the lady's name is Delores
sdp-sisupport@sdp-si.com
The cog below is shattered on the spindle and the bottom one, the skew spindle has chewed a hole in the cog in one place. I would like them all replaced with bronze.
Here are all the Cogs, tantalisingly close. Tell her I sent you!
http://www.sdp-si.com/eStore/CoverPg/Gears.htm
SDP SI ON LINE eStore offers Spur Gears Helical Gears Miter Gears Worm...
Dec 19, 2011 | Fellowes Manufacturing Powershred ...
Tried to feed to much (thickness) through ... I have done this in the past but was able to remove jammed paper by going forward and back until jam was cleared ... this time however it seems the motor just...
This is the most common problem...people put TOO MUCH paper in shredders... the VF880 has plastic gears inside...having done this a number of times you may have broken the gears or stripped the "teeth" off the gears...open it up to see what damage has been done; once you know what is broken you can contact Royal for pricing and parts at 1-800-524-0799.
Dec 11, 2010 | Royal VF880 Shredder
Nylon gear has several of its teeth. 2 gears are
For parts advice call Royal at 1-800-524-0799.
Dec 10, 2009 | Royal 150MX Cross-Cut Shredder
Od700c shredder: motor spinds, blades don't move
Inside the motor assembly there are a series of nylon cogs , a large one of which interacts with a metal one.  This is the most likely place you have one or two teeth missing from the large nylon cog that drives the shredder blades.
Sep 22, 2009 | Fellowes OD700C Shredder
Royal shreader pcua-29053u Damaged Gear
call royal spare parts department at 1800-222-2310 they will ship you a gear for about $6 + shipping
Apr 16, 2008 | Royal 10X Shredder
Grinding Sound
Only solution - Don't buy a FELLOWES shredder.
It is ludicrous that they cannot (will not) supply a spare gear wheel when there are thousands of instances of them failing. Or even think outside the box - fit metal ones?
Jul 07, 2006 | Fellowes PS80C-2 Shredder
OfficeMax 0M96431 Shredder Logo
177 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
ROCKIT957
Randy Schumann
Randy Schumann
Colin Stickland
Colin Stickland
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
