Question about Fellowes Jupiter JL 125 Laminating Machine 12-1/2" x 7 mil
Laminator jammed cannot get rollers to roll
Someone fed our office lamintor the incorrect way and didn't follow the instruction manual to immediately remedy the problem. The paper/plastic is super jammed and we cannot get the rollers to move to unjam it. Any suggestions?
4 Suggested Answers
SOURCE: Fellowes PS-70 Shredder jam
I used needle-nose pliers and regular pliers to pull out all of the jammed paper -- it took an hour but I finally got it. I never did find a release mechanism even after I took the top apart. Thanks anyway!
Posted on Jun 14, 2008
JayBlair
  • 328 Answers
SOURCE: Unjamed, but jammed light remains on and won't shred
Most likely the PC board has gone bad. It will cost over 100.00 from fellowes.
Posted on Jan 12, 2009
  • 19 Answers
SOURCE: Fellowes C220 Shredder Jam
First unplug shredder. You can remove the top and start removing paper. It can be quite time consuming. I can't remember if this model uses plastic paper strippers or not. If it does, they may have broken when the shredder jammed. They strip the paper from the cutters.
Posted on Jul 19, 2009
How do I unjam it?
first, remove both rollers with the film on them, then I usually cut the film between the red/orange rollers and the rear gray rollers, this allows you to run the laminator in either forward or reverse to unwrap the laminator, there is not exact science here, just use common sense and don't use anything sharp up against the rollers. West Laminating Svcs 405-324-6092
Aug 05, 2015 | Gbc HeatSeal Ultima 65 Laminating System
I jammed the laminating machine, so I unscrewed and opened the machine...but now I don't know how to roll out the paper? Please help me find a way to take this out without breaking the machine!
Carefully try to turn the roller one direction and then the next. If they move, you will see the feed direction the paper loaded from. Carefully move the rollers in the opposite direction letting the paper unwind. Do not force the gears. Hopefully the paper is not fused to the rollers.
Mar 03, 2015 | Scotch 9" Tl901 Hot Laminating Machine /...
How do I feed New laminating film through straight? Top roll of new film is wrapping around bottom heat roller
go to youtube and watch the video on GBC ultima65 film loading. sounds like you are not using a threading card to load laminator. Manila File folders work great to load laminators Westco Laminating Svcs 405-324-6092
Aug 30, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Rollers will not turn
Read page 8 of your manual (http://accoblobstorageus.blob.core.windows.net/literature/5edb3f90-058f-49a6-a41d-ccfd96850992.pdf).
Are C, D and E in place(page 14 of the manual)? Interlocks prevent anything from operating if these parts are not properly in position.
Are you sure the screwed up film is all out and new film installed correctly(page 34 of the manual)? Use a flashlight to peek in the corners!
Are the rollers sticky or sticking to each other? If so, you're done.
Are the supply rolls (page 22) turning freely? If not, replace them.
Do the rollers run in reverse when you hold down that button (page 12)? If not, something is really out of whack.
If still in trouble, call for service.
This is one of the most complicated laminators I've ever seen ... must be a good one ... but personally I wouldn't let any one touch it until they've read the manual cover to cover and promise on pain of separation from service to follow ALL the rules in regard to setup, operation and maintenance. ^_^
Mar 28, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Laminate Film Disconnected
Un-coil the lower roll and feed it through by hand.
Dec 06, 2013 | Gbc HeatSeal H425 Laminator
Laminator squeals
The paper is fed into the laminator by rollers usually a top and bottom, one of them is usually made of silicone(rubber) check to see if tose rollers are turning, you may have to pull some covers off to see the rollers, but usually you can look in the throat where the paper is fed in and see these rollers with a flashlite. Not sure of the brand, big or small laminator, good luck. If rollers are not turning, some are belt driven, some are motor driven, could even be a control board or switch.
Sep 24, 2013 | ACCO HeatSeal Ultima 65 Roll Laminator...
The front rollers on the laminator will manually move but will not roll when motor is turned on.
look at the transmission chain between the motor and the rollers maybe it is broken.
Sep 10, 2013 | Ledco Compass 27" Roll Laminator
Paper rolled on heater roller. How do I remove?
I fix roll laminators for a living. Its best with GBC machines to remove wraps where the film is stuck to the roller hot. trying to remove ilm adhered to the roller cold can not jusst remove the film but the rubber roller surface. Do note GBC heat rollers espically the red ones are over 500 bucks each:( Its easy to damage those rollers making the machine junk....
This question is old but I answered it for the benefit f others coming here bob haller service and sales 412 366 4906 pittsburgh pa. I answer all phone questions for FREE, and in the pittsburgh area offer free no cost no obligation estimates
Oct 04, 2011 | Gbc HeatSeal Ultima 65 Laminating System
I have an office roll laminator GMP 650HRP. I
the increasing and lowering heat on the rollers and increasing and lowering pressure on the pressure stick depend on the thickness of the laminating pouch 120 mic need less heat then the 240 mic.
Mar 21, 2010 | Office Equipment & Supplies
Ibico 2700 laminator
I need to replace the rollers on my IBICO 2700 laminator. I will need to order the new rollers can you help?
Apr 24, 2008 | Office Equipment & Supplies
Fellowes Jupiter JL 125 Laminating Machine 12-1/2" x 7 mil Logo
Top Fellowes Computers & Internet Experts
Gary Paul
Level 1 Expert
ray gallant
Are you a Fellowes Computer and Internet Expert? Answer questions, earn points and help others
