Question about Respironics REMstar Pro w/C-Flex CPAP
Humidifier not working
Water in container never goes down, squiggly lines no longer appear as they used to
Humidifier spits out water rather than steam.
Descale the boiler. You do that by putting vinegar in as you would water, start the machine until is starts spitting water then turn off for 30 or so minutes. Turn it back on and let it run. If it stops spitting, dump out the vinegar and flush the boiler with water until you no longer smell vinegar.
Nov 28, 2016 | Humidifiers
Water drains into air return & onto floor
Hello, usually this is a sign of a drain problem or the water is entering the humidifier too fast. If the water is not draining at the end of the drain line something is preventing the water from flowing. I would also make sure that there is no heavy mineral buildup on the water panel pad this can cause water to leak out of the humidifier. Lastly check to make sure there is a orifice inside the supply water tubing leaving the solenoid, if not this causes the water to enter the humidifier too fast.
Jan 07, 2012 | Aprilaire 550 Humidifier
Solenoid on Aprilaire whole house humidifier
the solenoid allows water to flow to jet that then runs down the pad the solenoid is control by the stat
Feb 23, 2010 | Aprilaire 700 Humidifier
Water not flowing into HE360A
If you used the plastic tubing to the humidifier(I recomend copper) there should have been a little brass tube with a flare on it. This goes in the plastic tubing to grip the the sleeve better. See if this helps
Tinner
Sunsetmech
Dec 14, 2009 | Honeywell HE360A1027 Whole House...
Water is getting to my solenoid valve and the valve is activated as it is warm to the touch. No water on the back side of the valve to the humidifier. It is on sometimes and other times is doesn't work....
Valves do go bad, but I had the same issue and it was the inlet orifice that was plugged.
To fix: Turn off the water supply. Disconnect the water inlet line to the solenoid. The water inlet line connect to ~ 1" long piece that goes into the solenoid. Unscrew the water inlet piece and remove it from the solenoid. Check it for water flow - water should slowly drip out the small orifice at the soleniod side. There is a pin-hole sized orifice on the solenoid side and it doesn't take much to plug it. There is also a narrow cone-shaped filter inside the inlet piece. You can use tweezers to remove the filter and & use a safety pin or sewing needle to clear the orifice. Check the filter, clean it if necessary, and reinstall the filter. Now check for water flow thru the part before reinstalling. Reconnect the water inlet line and turn on the water supply. Turn your humidistat to trigger the humidifier. You should see water flowing through the drain tube.
Dec 13, 2009 | Honeywell HE220A1019 Whole House...
Not getting water into the unit. Water is upto the valve. Is it more likely the solenoid valve or the reostat ?
It's more likely to be the valve. Turn the humidistat (rheostat) up and down and listen for a click at the humidifier valve. If it clicks and no water goes through, it's the valve or something in the water supply. The best way to test is to use a meter and check for power at the valve. They sometimes fail even if they appear to be operating. Scale (lime buildup) is usually the cause.
Dec 08, 2009 | General Filters 1042-LH Humidifier
Aprilaire 700 using too much water-------
There is a small oriface that is installed next to the solenoid valve. It sounds like this oriface is missing. It reduces the water flow through the humidifier when it is working properly. You should be able to disassemble the solenoid fittings to check and see if the oriface is in the water line. For a "temporary" fix regulate the water pressure down by closing down on the saddle valve.
Good luck
HVAC Teacher
Feb 25, 2009 | Aprilaire 700 Humidifier
Humidifier leaves a crusty dark substance in water
SPECIAL NOTES
Discoloration/Black Particles
After use, the water residue in the bottom of the container may contain black particles, and, in
some areas the water and the bottom of container may discolor. These conditions are normal and
do not effect the purity of the steam or medicine. The container is easily cleaned with soap and
water. Rinse and dry the container after cleaning.
This was taken from the manual that comes with the humidifier...
Dec 12, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Water leak
Sounds like the air flow is too great and it is blowing the water in the bottom of the tray around before it gets a chance to drain. Try placing your summer, winter damper at half closed to slow the airflow down a little.
Nov 19, 2008 | Honeywell HE220A1019 Whole House...
Water not running through humidifier
Sounds as if you feel the problem is the saddle valve. Check to see if water is available at the humidifier. Close the saddle valve, disconnect the water line at the humidifier side, then slowly turn the saddle valve back on. If you never see water, then correct the saddle valve. You can get details here: http://www.naturalhandyman.com/iip/infxtra/infsad.html#1
If you are getting water, but dont think that the unit is operating try sending 24VAC directly to the hunidifier and see if it operates, bypass the humidistat etc.
Dec 08, 2007 | Honeywell HE220A1019 Whole House...
Respironics REMstar Pro w/C-Flex CPAP Logo
110 people viewed this question
Top Respironics Medical Experts
Electro Med Services...
Are you a Respironics Medical Expert? Answer questions, earn points and help others
