Question about Boston Acoustics BA7900 Computer Speakers
Where does the black and orange wires connect to?
I don't know where the black and orange wire connect
  • Boston Acous... Master
  • 3,320 Answers
Gateway computer is the only retailer of these speakers as of June 2003.
You need to provide more info about what connectors are available and how mant orange black wires you have.
Posted on Apr 01, 2014
Need to know how the two yellow and two orange wires hook to
The yellow and yellow/black wire (left) and orange and orange/black (right) are high input speaker feeds to power the amplifier. You either connect high input feeds or the low level phono inputs! Not both!
Sep 05, 2015 | Car Audio & Video
Phone Jack Wiring Problem
Your apartment is wired for two lines but you are using only one of the two. Your phone jack has red and green terminals for one line and yellow and black terminals for the other (old color codes). The four wires coming in to your apartment are actually two lines: orange/white and white/orange plus blue/white and white/blue (new color codes). One of those lines is active. Connect the orange/white wire to the red terminal and the white/orange wire to the green terminal. Plug in your phone and listen for a dial tone. If no tone, disconnect the first line and connect the second pair of wires. Listen again. DO NOT CONNECT ANY WIRES TOGETHER. Just follow the steps above. If you still don't get results, the phone company may not have activated your connection
Dec 30, 2012 | Lands Phones
Colour code for Shine active bass guitar wiring
Blue / Black wires to Ground (back of Pot) leaving the red to the outside and Orange to Middle
In return could you let me know the grey yellow white wires on the Tone pot.
Cheers
Mar 05, 2012 | Cell Phones
Need help installing a Hunter 44277 thermostat. Instruction manual here: http://www.hunterfan.com/Support/Manuals-and-Parts-Guides/ Wires I have are as follows: Blue: C Black: E White: W2 Yellow:...
Your wires Hunter thermostat
Blue C
White E
Black E
Yellow Y
Orange O
Red R
Green G
Since i don't know what brand heat pump you have, i am assuming you have a cool active reversing valve, therefore the orange wire will connect to the "O" terminal. If you have a heat active reversing valve the orange wire would be connected to the "B" terminal. You will know it is wrong when you turn on the system in cooling mode and it blows hot or warm air. Another way to know quickly is to go out to your outside unit when you turn it on in the cooling mode and feel of the suction line(the large copper line coming out of your condensing unit) and see if it is cool. If it is, great. If it is hot then you would have to switch the orange wire to the "B" terminal.
Hope this helps.
Sep 04, 2011 | Heating & Cooling
Wiring diagram for BOSS AVA 1209 equalizer. It was given to me dont know where the 4 wires connect red,black,white,last wire is orange or pink.
Your wiring is as follow's :
The Red wire is your (+) Positive that connect's to the power source
The Black wire is your (-) Negative that connect's to the ground
The Orange wire is your Auxillary (+) that turn's on Amplifier's or Power Ant.
You should have a Green wire, a Green wire with a White stripe,a Gray wire, and a Gray wire with White stripe
The Green wire is the LEFT channel input (+)
The Green/White wire is the LEFT channel input (-)
The Gray wire is the RIGHT channel input (+)
The Gray/White wire is the RIGHT channe (-)
(BE SURE THAT YOU CONNECT THE RED (+) AND BLACK(-) WIRES BEFORE YOU CONNECT THE ORANGE WIRE TO AN AUX SOURCE OR YOU WILL BLOW THE INTERNAL FUSE !!!)
PS. I have no idea where that White wire you mentioned goes.
Feb 03, 2011 | Boss AVA1209 7-Band Car Equalizer
1993 dodge shadow radio wire diagram i have a problem with my instrument lights on the dash board speed,gas,temp,gages lights will not come on the radio light is on and it plays and works good but i have...
Hello! I will assume you are connecting a factory radio for your 1993 Shadow.
Remove the Orange wire from ground...Listed below is wiring from car to radio; You may need this one day...You are correct; There isn't a dimmer wire...The Orange wire, from the radio, connects to the Orange/White of the vehicle...Grounding the Orange wire is causing your problem...
1993 Shadow...Orange/ White=Illumination...Red=Hot at all times...Red/White=Switched 12volts...Black=Ground
Factory radio...Orange=Illumination...Pink=Hot at all times... Red/White=Switched 12volts...Black=Gnd.
Car; Orange/White to Orange of radio
Red To Pink
Red/White To Red/White
Black To Black
Let me know how you make out..
Guru...............saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Feb 04, 2010 | Car Audio & Video
I have a westinghouse three speed fan. there are 4 wires a black, purple orange and yellow . the new switch has four connectors L 1,2,3 does any one know witch goes where? thanks , i bought the new switch...
ok. hope this helps, use a switch from FANTEC. it'll be called a 3 speed fan switch. CAM #5 No. 21105. this will also say Single Layer 3 or 4 wire application SPLIT continuity function.. THE SPLIT PART IS VITAL. now when wire it. the BLACK wire goes in SLOT 3. ORANGE wire goes in L. PURPLE wire goes in slot 2, ORANGE wire goes in slot 1. IF, and i repeat IF this does not work for you ensure you have a SPLIT CONTINUITY FUNCTION switch. NO MATTER WHAT the BLACK wire WILL go into slot 3. the ORANGE wire WILL go in slot L. switch the orange and purple wires only. ENSURE POWER IS OFF WHEN CONNECTING OR DISCONNECTING WIRES. YOU WILL GET THE SNOT ZAPPED OUTTA YOU IF YOU DON'T. please post if this helps.
May 02, 2009 | Westinghouse Electric Westinghouse...
CDA-9815
dont connect the pink/black wire just trouble these are signal interupt lead wires cap and tape off and the orange wire is the dimmer wire for when you turn your lights on and off
May 06, 2008 | Alpine CDA-9815 CD Player
172 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
