Question about sonya Portable Compact Laundry Dryer Apartment Size 110V 13lbs/3.75 cu.ft.-larger size
Squeaky sonya Portable Compact Laundry Dryer Apartment Size 110V 13lbs/3.75 cu.ft.-larger size ,whats wrong?
Squeaking drum and belts grinding
Drum size for whirlpool wed55005Q0
This dryer is probably the WED5500SQ0. It's listed as a 6.5 cu. ft. capacity.
I hope this helps.
Sep 01, 2016 | Whirlpool Dryers
The belt will not stay on the pulley can someone help me
I put a thin spacer behind the tension pulley , just enough to correct the alignment.
Jan 19, 2016 | sonya Portable Compact Laundry Dryer...
How to thread the belt on the idle wheel and pulley without it coming off
Sheryl
should be doable as long as it does not have welded belt retainers,
if it has removable bolts or guards which help keep belt from falling off, remove these first. good luck
press the helpful button
the link below shows how to do it, but is not your model, hope it helps Dryer Not Spinning Whirlpool Kenmore Electric Dryer Repair Part 341241
Jan 18, 2016 | sonya Portable Compact Small Laundry Dryer...
What does the code nd mean on an apartment size front loading stackable kenmore washing machine mean
ND, I would suggest means no drain. If the machine is full of water, it wont let you open the door. Put the drain hose into a bucket to drain the water out and turn off the machine, after a few minutes, the door should unlock. Check the pump or the pump inlet hose for blockages.
Dec 23, 2014 | Kenmore 3.4 cu. ft. Capacity Compact...
Dryer is squeeking
Hi
The motor bearings may be worn. Remove the drum drive belt and then start the dryer. If it squeals with the belt off then the motor bearings are likely worn.
There is a small roller that tightens the drive belt for the drum. They can squeak. Remove the lower front panel and you should see the small roller near the motor and belt.
Another is the two larger rollers that support the drum. You will see this if you remove the front lower panel. Another is where the drum rides on the upper round part of the door/opening and it has a plastic guide that separates the metal drum from the metal door/opening. Over time this wears out and the two metal pieces will squeak.
Please check the bellow links to know detailed idea related to your query:-
http://www.ehow.com/how_5062711_fix-squeaky-dryer.html
http://www.mademan.com/mm/how-fix-clothes-dryer-squeaking.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Feb 02, 2011 | Maytag Neptune MDE5500AY Electric Dryer
GE Profile Performance dryer drum is clunking and making a noise.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Dec 27, 2010 | GE Profile Performance 25.2 cu. ft....
SQUEAKY DRUM!
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Jun 07, 2010 | Fisher and Paykel DE08 Gas Dryer
Nextra7 condenser dryer making squeaky noises
heatman101
tukuymhg
Feb 14, 2009 | Hoover Nextra 160 HNWF 3137 Front Load...
Need to know the exact way to put belt on ge dryer model number DDE7200RALWH cant figure it out around the pulleys , ge assures its the right size belt for the dryer , but belt seems loose and drum wont...
with belt around drum, pull idler back with tension on it and put belt over pulley of motor and let idler up against belt and it should be right ,,,, larryyb
Dec 10, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
NEED LARGER DRYER
Generally, manufacturers will rate the unit in terms of pounds of wash.  That goes for washers and dryers.  Most retailers can tell you what those ratings are.
Nov 14, 2008 | Dryers
sonya Portable Compact Laundry Dryer Apartment Size 110V 13lbs/3.75 cu.ft.-larger size Logo
50 people viewed this question
Top sonya Dryers Experts
Are you a sonya Dryer Expert? Answer questions, earn points and help others
