Question about Fleck 165,000 Grain Series 2850 Commercial Water Softener 1700 Brine System w/Brine Valve
Water Softener full of water, not draining, or using salt
Tank of softener is about 75% full of water. Doesnt seem to want to go anywhere. I can press the cycle button, and it runs, but nothing is happening with the water in the tank or the salt. The salt is just dissolving on its own in the tank with time. It doesnt seem to be filtering any water through the salt pellets. Any suggestions? Serious hard water going on. All appliances are being affected.
  • 25 Answers
How old is the system ? Where does the system drain to ? If this is the softener you have (seems awful large for a household) it is probably the injector/nozzle assembly. I have attached a manual to help you. A restriction in the drain line could also be the problem. Fleck 2850s
Posted on Mar 28, 2014
Softener not filtering water through the salt and not draining water from tank
What model of water softener do you have ? The one you have on here is for a chemical, not a water softener. Usually it is the brine injector or commonly called the nozzle/venture that gets clogged and will not create a vacuum to draw out the brine water. If you can put a picture of your water softener on here. I'd be more than happy to help you out.
Mar 20, 2014 | Seachem Discus Buffer 4 Kilogram Softens...
Tip
Water softener salt bridging
One of the most frequent problems with water softening systems is salt bridging in the salt/brine tank. There are several reasons for salt bridging to occur. This generally occurs when pellet type salts or potassium chloride is used to regenerate the water softening system. Pellet type salts contain binding agents that in turn give the salt a very starchy consistency when wet. As water evaporates in the brine tank the pellet salts partially dissolve, bind together and form a "salt bridge" in the tank. Potassium chloride (Kcl) acts in the same way. Excess water in the salt tank, with high salt levels, can also cause salt bridging. Improper softener brining and lack of proper brine refill will cause bridging to occur as well.
What is the best way to alleviate these problems?
1. When using pellet type salts or potassium chloride only keep the salt tank about 1/2 full. This prevents too much compaction of the salts and helps to prevent bridging. When using potassium chloride get the salt tank off the floor on a wooden platform to prevent wicking of moisture from concrete floors.
2. Use a high grade of salt. Most water treatment dealers use either
DuraCube or HardiCube water softener salts produced by Cargill Corp.
Cargill has a link to find dealers in your area.
https://saltapps.cargill.com/cargillsalt/product_locator_new.asp
Solar Salt is another option as the crystal structure is very hard and virtually impossible to bridge. This is also available from many Cargill salt dealers and in stores.
3. Let the salt tank run down to 80-100lbs of salt or potassium a couple times per year to help prevent buildup of dissolved salts in brine tank.
4. Yearly maintenance of the water treatment system helps also. Restrictions in the brining system (injector/eductor assembly) caused by sediment and oxidized iron buildup cause improper brining and too much water in salt tank during refill. Have this assembly cleaned yearly. Have the water tested to see if the water chemistry or usage have changed and adjustments to the system are necessary.
5. Avoid using rock salts to prevent buildup of sediment in brine tank (which causes service problems).
Practice these tips and you will have fewer water softener problems and more consistent quality softened water.
I wish you good water!
H2O Services
on May 17, 2011 | Water Dispensing & Filtration
Kenmore Water Softener does not advance through cycles
You can send to the company for repair too ! If it sill under warrenty to fix it and aslo don't try the step anymore it might cause some parts damage that the service provider my charge you more.
Dec 09, 2013 | Washing Machines
Sestem is not using up salt and will not flush the lines when it is set up to .
Hi Joey,
There could be several reasons why your softener is not using salt. If it has a Demand Control the turbine that meters the water may be blocked and stuck so the softener doesn't realize that you are using any water, so it won't try to regenerate.
Your injector may be plugged, although this would cause the salt tank to become more full with each regeneration.
If you initiate a manual regeneration and regeneration does not happen you may need to replace the softener.
Knowing what make, model and age of your softener would help greatly in assessing. The best quality softeners last 15 to 18 years unless you have an Autotrol Turbulator in your softener, in which case add 25% more time; 19 to 23 years. There are a few brands that don't seem to last longer than 10 years...
Steve Scott CWS, CI
Sep 03, 2013 | Pentair Water Dispensing & Filtration
Water in salt tank looked bad so i drained it should i put a couple of gallons of water in the salt tank after draining it to get circulation back again ?
The main problem in water softening units is that people continually use pool salt because it is cheaper. Most find eventually that it is not as it blocks the medium in the tank with sediment and rubbish. You may have to replace the medium in the system and restart the regeneration process Best policy is to use only kiln dried water softener salt It IS different.
Feb 10, 2013 | Tools & Hardware - Others
Waterside water softener model MC250 Dear Sir, Salt level did not go down during regeneration. I poured 2 pints of warm water to break solidified tablet salt, I found moist salt, but very little water in...
the salt in use should water softener salt and nothing else
there is water added to the salt crystals up to the overflow hole
during regeneration that salty water (Brime) is drawn into the unit and upon finishing the process that reserve is refilled for the next time
there is little salt actually used during the regeneration process ( around 4 regenerations to a 25 kg bad )
Apr 13, 2017 | Dishwashers
My miele g680 dishwasher did have a flashing intake/drain I cleaned it seemed to be working fine, then everytime I try to start it the softener light comes on with no further washing activity.
that is just an indicator that your salt is low. it will stay on until you refill the water softener with softener salt. it will not affect the dishwasher to run it without the salt. the water for your final rinse will not be softened.
Apr 06, 2012 | Miele Dishwashers
What is Salt Bridging in a Culligan Water Softener
Salt bridging can occur in any water softener "salt tank". A salt bridge occurs when a hard crust of salt develops across the salt tank when the salt wicks up moisture. The salt does not fall down in the salt tank in between regenerations and a "bridge" occurs. It may look like the salt tank is full but there will be a hollow area at the bottom of the salt tank and not enough salt to develop the proper brine for regeneration of softener. This generally happens when the salt tank is a least 1/2 full of salt. If the system has a separate salt tank, shaking the tank will break the bridge usually. Gently poking a stick at the bridge can break it up also but can damage the salt grid if you poke the stick too far down in the salt tank. Certain salts, such as pellet salt are highly prone to this problem. Using Dura Cube, Hardi Cube or Solar salt will greatly reduce the chance of bridging. Any time a salt bridge occurs it will take 3 regenerations of the water softener (in 24 hrs), after fixing it, to regain the reserve capacity and totally soft water.
RJ
Oct 27, 2011 | Culligan Sediment Water Filter
Fleck 165,000 Grain Series 2850 Commercial Water Softener 1700 Brine System w/Brine Valve Logo
353 people viewed this question
Top Fleck Water Dispensing & Filtration Experts
ray gallant
Bill Boyd
Tom Chichester
Are you a Fleck Water Dispensing and Filtration Expert? Answer questions, earn points and help others
