Question about Dometic Refrigerators
Nda1402 drain heater
Heat tape does not work how to install a new one
    Top Expert:
  • Dometic Master
  • 6,465 Answers
Remove all to freezer heat tape runs on plastic side panel on right side of freezer probably error 13
Posted on May 27, 2016
Dometic frig. model #nda1402 not defrosting. Where do I fined a book on heater part number? Thank Don
THE INTERNET TYPE IN DOMETC FRIG THE MODEL NUMBER & SEE WHAT YOU GET. OR YOU MAY HAVE TO TYPE IN WHERE TO FIND MANUAL FOR DOMETIC FRIG MODEL #NDA1402
Oct 13, 2014 | camperpartsworld.com Dometic NDA1402...
What do I have to do to drain and disconnect GG40T6A model
1) Copy following link for installing new gas water heater, and use steps to move water heater, and then re-install.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#install
http://waterheatertimer.org/Water-heater-will-not-drain.html
2) Don't forget to tape plastic bag over disconnected gas connections to keep from getting dirty.
Dirt in the gas line, or on the threads can cause gas control valve to malfunction.
Mar 08, 2013 | Water Heaters
On demand hot water heater leaking
is this an area w/a threaded fitting?if so ,you turn off waterheater,drain,disconnect existing fitting,clean and rewrap with new teflon tape ,and retighten down.i only say to drain,because i am not sure if it is hanging and would not want to fall on you.teflon tape and rewrenching down should fix,unless soldered.then call your plumber.also if under warr.from installer ,less than 1 yr.,call them and tell them to fix it for free.i have over 13yrs in sheetmetal install,both in hvy.industrial down to many other types of home install of furnaces,a/c units,retrofits in /new and existing homes,waterheaters,garbage disp,refrig.water lines,gas etc
May 21, 2012 | Bosch Water Heaters
How do I Remove Magnesium Anode ?
The following page has instructions and a link to a video:
http://waterheatertimer.org/Replace-anode-rod.html
How to:
Rods are installed in top of tank.
Most are located under a 2" round plastic cover located on top of tank.
Some anode rods are connected to hot water nipple
Read owner's manual to see location of anode rod
See list of water heater manufacturers and brands to find product manual.
Before starting, turn off heater source: electric water heater: turn off circuit breaker; gas water heater move control knob to pilot.
Close shutoff valve on cold water side of water heater
Open bathtub faucet to relieve pressure and let air into water line.
Open drain valve near bottom of tank,, and drain 2 gallons of water.
Use 1-1/16" socket for hex head rod
Rod will be rusted in place, use generous amount WD-40
WD-40 spray is flammable and will burn so be careful around heat source.
Loosening rod: go slow and check that water does not seep up when loosening rod because hot water can spew out hole if tank is very hot ... it is important to drain enough water out of tank to avoid accidental scalding.
Install new anode rod: One source says/ use pipe compound on thread instead of teflon tape. Other sources say use teflon tape. Either way, tank metal and anode metal must meet, so rod will work.
Dec 23, 2010 | Water Heaters
I need to replace the drain valve at the bottom of the tank,can I buy a replacement valve? Are they all the same size?
There are 2 sizes; 1/2 inch and 3/4 inch. Remove the old one after draining the water heater and shutting off the water supply then take your old one to a plumbing supply outfit like George Morlan's. Make sure you wrap the new threads with teflon tape at least 3 wraps while holding the spigot in your left hand so the tape won't come off as you install the spigot. Good luck!!
Dec 15, 2010 | RELIANCE ELECTRIC WATER HEATER
This water heater has two elements, correct?? Well how do you get them out?
The first thing to do is shut off power supply to the heater. Then while water is still on hook up garden hose to drain valve on bottom of heater. Place hose to floor drain or some other location for safe drainage. Open drain valve and if it starts draining at a good rate then shut water supply valve off to heater. You will want to open hot side of closest faucet to prevent vacumn which will slow or stop draining. After heater is done draining shut off drain valve and faucet . Remove the cover plates on top and bottpm of heater. Usually four small screws. Locate heating elements and disconnect wiring,label if you need to for reinstallation. There are two kinds of heating elements,one is held in place with 4 hex head bolts,and the other is screwed in. If yours has the bolts carefully remove to avoid breaking bolts.Then just pull out to remove To reinstall there will be a new rubber gasket with element, fit it in place and insert element back in heater. Reconnect wires. If there are no bolts apparent then the element screws into heater. You will need a pipe wrench or large wrench to remove the element. The same thing with this element is that it should have a new rubber gasket. Put gasket in place and wrap threads with 5 to 6 wraps of teflon tape. Install element and tighten snugly. Connect wires,refill with water and check for leaks. If no leaks then turn power back on. Put cover plates back on and you're done. I hope this helps you. Thanks
Nov 19, 2010 | Audiovox Richmond 6EM30-2 30-Gallon 6-Year...
My brand new, recently installed gas furnace is smoking a little out of the supply lines on the first trial run. Now I applied flex duct tape to all the openings to seal up the duct work for leaks, but I...
yes tape would burn there i would remove what you have put inside most when new will give off some smoke as the heat exchanger has some grease coatings on it just burn it off , if this does not stop call back person who fitted it
Nov 04, 2010 | Heating & Cooling
Heater in Cabin in Colorado
Not a good idea, because if one malfunctions your whole log cabin will go up in smoke. Not sure if your homeowners insurance would compensate you for it either.
Get your HVAC system installed first so that you can set the thermostat temps to 60 F. Go down to Home Depot and buy heat tape to wrap around the pipes and plug them into an outlet. The heat tape has a thermometer on it that turns on the heat tape whenever the pipes get too cold. Also, leave the cabinet doors open underneath sinks so the room temperature can equalize.
Feb 24, 2010 | Heating & Cooling
Need instruction on installing heater core for 2000 jeep cherokee
The heater-A/C housing assembly must be removed from the vehicle and the two halves of the housing separated for service access of the heater core, evaporator coil, blend-air door, and each of the various mode control doors.
WARNING: On vehicles equipped with airbags, refer to Airbag Systems Safety Information and Procedures. Before attempting any steering wheel, steering column, or instrument panel component diagnosis or service. Failure to take the proper precautions could result in accidental airbag deployment and possible personal injury. See: Restraint Systems\Air Bag Systems\Service Precautions
REMOVAL
  1. Disconnect and isolate the battery negative cable.
  2. Remove the instrument panel from the vehicle. Refer to: Body and Frame, Interior Trim, Dashboard / Instrument Panel, Service and Repair, Instrument Panel Service Procedures, Instrument Panel Assembly Replacement, See: Body and Frame\Interior Moulding / Trim\Dashboard / Instrument Panel\Service and Repair\Instrument Panel Assembly
  3. If the vehicle is not equipped with air conditioning, go to Step 6. If the vehicle is equipped with air conditioning, recover the refrigerant from the refrigerant system. Refer to: Heating and Air Conditioning, Service and Repair, Procedures, Refrigerant System Recovery, See: Service and Repair\Refrigerant System Recovery
  4. Disconnect the liquid line refrigerant line fitting from the evaporator inlet tube.
    • Install plugs in, or tape over all of the opened refrigerant line fittings.
  1. Disconnect the accumulator inlet tube refrigerant line fitting from the evaporator outlet tube. See Refrigerant Line Coupler for the procedures.
  1. Drain the engine cooling system.
  2. Disconnect the heater hoses from the heater core tubes. Install plugs in, or tape over the opened heater core tubes.
  3. Unplug the heater-A/C system vacuum supply line connector from the tee fitting near the heater core tubes.
  4. Unplug the heater-A/C unit wire harness connector, which is fastened to the heater-A/C housing next to the blower motor relay.
    1. Remove the five nuts from the heater-A/C housing mounting studs on the engine compartment side of the dash panel. Remove or reposition the evaporation canister for additional access, if required.
    2. Pull the heater-A/C housing rearward far enough for the mounting studs and the evaporator condensate drain tube to clear the dash panel holes.
    3. Remove the heater-A/C housing from the vehicle.
    INSTALLATION
    1. Position the heater-A/C housing to the dash panel. Be certain that the evaporator condensate drain tube and the housing mounting studs are inserted into their correct mounting holes.
    2. Install and tighten the five nuts onto the heater-A/C housing mounting studs on the engine compartment side of the dash panel. Tighten the nuts to 6.2 Nm (55 in. lbs.) .
    3. If the evaporation canister was repositioned during the removal procedure, reinstall it to its proper position.
    4. Connect the Heater-A/C system vacuum supply line connector to the tee fitting near the heater core tubes.
    5. Unplug or remove the tape from the heater core tubes. Connect the heater hoses to the heater core tubes and fill the engine cooling system.
    6. If the vehicle is not equipped with air conditioning, go to Step 10. If the vehicle is equipped with air conditioning, unplug or remove the tape from the accumulator inlet tube and the evaporator outlet tube fittings. Connect the accumulator inlet tube coupler to the evaporator outlet tube.
    7. Unplug or remove the tape from the liquid line and the evaporator inlet tube fittings. Connect the liquid line coupler to the evaporator inlet tube.
    8. Evacuate the refrigerant system. Refer to: Heating and Air Conditioning, Service and Repair, Procedures, Refrigerant System Evacuate, See: Service and Repair\Refrigerant System Evacuate
    9. Charge the refrigerant system. Refer to: Heating and Air Conditioning, Service and Repair, Procedures, Refrigerant System Charge, See: Service and Repair\Refrigerant System Charge
    10. Install the instrument panel in the vehicle. Refer to: Body and Frame, Interior Trim, Dashboard / Instrument Panel, Service and Repair, Instrument Panel Service Procedures, Instrument Panel Assembly Replacement, See: Body and Frame\Interior Moulding / Trim\Dashboard / Instrument Panel\Service and Repair\Instrument Panel Assembly
    11. Connect the battery negative cable.
    12. Start the engine and check for proper operation of the heating and air conditioning systems.
REMOVAL AND INSTALLATION
  1. Remove and disassemble the heater-A/C housing. Refer to: Heating and Air Conditioning, Housing Assembly HVAC, Service and Repair, See: Heating and Air Conditioning\Housing Assembly HVAC\Service and Repair
  2. Lift the heater core out of the lower half of the heater-A/C housing.
  3. Reverse the removal procedures to install. Be certain that the heater core foam insulator is reinstalled
Jan 18, 2009 | 2000 Jeep Grand Cherokee
Refrigerators Logo
48 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
