Question about Ricoh Aficio CL2000N Laser Printer
Error message for Ricoh C410DN
The message is "Standard tray is full. Remove the paper."  There is no paper in the tray.  I tried to take the tray out and put it back in.  Tried shutting the printer off and then turning it back on.  Still get the same message.  Called the place where we bought it and they don't know. They are looking into it but so far have no answer.
  • Villagegirl Oct 30, 2007
    Finally heard back from the business machine place.  As it turns out, there is a  black plastic sensor on top of the machine where the paper comes out after printing.  It was stuck and that is why the error message came on.  I jiggled it and that fixed the problem.
  • Omar El Gabry
    Omar El Gabry Sep 17, 2014
    colud u show where i can found it ?
  • 903 Answers
When that message is displayed, the printer thinks the output tray is full of paper and it won't print any more because there is no room left to spit pages out. If the output tray isn't full of paper, the sensor that detects paper there might just be dirty or dusty.
That sensor is a black sensor that should be located just at the point where the paper exits the machine, above where the paper comes out. Blow some compressed air on the sensor to try to clean it off and see if that clears your error message.
Posted on Jun 05, 2010
The Ricoh Alicio SP C410dn says to open the A tabs and remove the paper jam. There is no paper jammed into the machine. The issue only arises when printing from the manual feeder and not from the paper...
You must first try to clean the paper feed roller which you will inside of the printer (bottom) when you pull out the paper tray. If this not works, then I am 100 % sure that the magnetic clutch which operates this feed roller must be replaced. I can tell you the part number for ricoh part catalog:
GX20-0014. If you don't have tech skills please don't do it by yourself because it's a hard and precision work. Call for help tech support
pifonski
Feb 25, 2011 | Ricoh Envelope Feeder Type 610 Feeder Tray...
I get the same message coming up "remove paper standard tray"
Sounds like it is misfeeding from the Default tray (just not getting the paper into the machine). try removing the paper from the default tray, and use another one. If it works, then the paper feed rollers are the likely cause.
Jul 20, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh SP C410dn Paper only prints 11cm and stops in the Bypass T
do not use ohp film in this device as it will jam due to the use of optical paper sensors unless your ohp has a paper backing. you can set up the bypass tray for thick paper type to increase fuser temp to get better fusing etc
Jul 08, 2009 | Ricoh Aficio SP C410DN Laser Printer
I get remove paper standard tray on a AFICIO AP3800C and it locks up the software. Then does not allow clearing the message. I have removed paper. Tried Aux feed. Always does same thing
On the face down exit tray (one on top) there should be a 3 or 4 inch long plastic part sticking straight out and pointed down. That is the tray full sensor arm. It could be knocked out of the holder and now working right.
Jun 09, 2009 | Ricoh Aficio AP3800C Laser Printer
Paper Jam
There is a small clear plastic sheet that is suppose to be in front of the black friction pad in the paper tray. if that sheet is under the pad instead of in front of it you will get this error.
Mar 24, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh/Aficio SP C410DN Tray priority switches on its own
It is pulling paper from the tray specified within the application you are printing from or the driver. For example, from Microsoft word, you would have to go into page setup and select the tray you would like it to pull from. You will also want to check which tray it is pulling from in the driver, however the application generally overrides the driver settings. Both of which override anything you program at the machine.
Mar 12, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh AP3800C "Output tray full"
Check the little black piece of plastic that senses the printed page exiting the machine. Our sensor was stuck and I was getting the same message (an similar Ricoh product). When I gently reset the black piece to center, moving freely, printing worked again. I think the sensor got jammed up when we were trying to remove a bad paper misfeed.
Ricoh manuals very confusing on this error message. They refer to standard tray, tray one, etc. without being clear whether it's a paper feed tray or the so-called "standard OUTPUT tray." The output is not really a tray, it's just the depression where your sheet lands after printing. I wrenched on the paper feed trays and their settings for an hour before I figured out they meant OUTPUT.
Feb 27, 2009 | Ricoh Aficio AP3800C Laser Printer
Paper tray default issues
you need to go into the print menu on the printer and change the paper tray size back to letter, when you have it right there will be an asterik next to letter confirming that it was programmed
http://www.websitetoolbox.com/mb/copierquestions
Dec 23, 2008 | Ricoh Aficio SP C410DN Laser Printer
Standard Try Full
'Standard tray full, remove paper' is the output tray where the prints exit.
Check also the exit sensor/feeler condition.
Good luck and please rate me, thanks.
Sep 05, 2008 | Ricoh Aficio SP C811DN-DL Printer
Ricoh Aficio CL2000N Laser Printer Logo
713 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
