Question about Singer 1725
Boobin winder isn't working correctly
The bobbin winder isn't working correctly. the thread bunches at the bottom and is loose and messy
  • Singer Master
  • 1,388 Answers
Needs to be in the tensioner as it winds on or will be loose
Posted on Apr 22, 2014
SOURCE: thread on bottom, bobbin thread loose
Sounds as though you've misthreaded the upper tension. The best way to verify this would be to thread your machine, lower the presser foot on to the material. Now try pulling the thread through the needle. (Assuming your upper tension dial is set to a number greater than one). You should feel resistance. Should you not feel resistance, rethread your upper tension.
Posted on Feb 01, 2008
  • 323 Answers
SOURCE: Thread looping on bottom of fabric, and bunching up around bobbin
Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle.
If it passes this test you need to remove the bobbin case and check for burrs or rough spots. If you find any ,use an emery stick to remove them and then buff the area with fine steel wool.Put the bobbin case back in ,check your bobbin(change it ) and try again by turning the handwheel slowly and watching to see where thr thread is snagging
sewman7
Posted on Jun 18, 2008
textile
  • 10 Answers
SOURCE: Problem with winding thread onto
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
Posted on Aug 19, 2008
  • 97 Answers
SOURCE: Bobbin problems
Any time you have looping on the bottom, it is almost always related to the upper tension and not anything in the bobbin area.
A good way to troubleshoot this is to turn the machine off, blow out the upper tension disk assemblies with canned air, (the machine needs to be off because most canned air uses butane as a propellant. Butane + electricity = bad;) replace your needle, and rethread your machine. Once you've threaded it to the point where you're about to put the thread through the needle, "floss" the thread forward and backward to ensure that the thread seats correctly into the tension assemblies.
Set your tension to around 4.5 for most applications, and drop your presser foot. Give the thread a gentle tug to see if the tensions have engaged the thread, then thread the needle.
If doing this does not address the problem, you probably need to have your tensions professionally calibrated. This is also true if the needle is in fact hitting something in the bobbin area. This is usually caused by the machine's timing being out of alignment, which is not something that can be fixed at home.
Good luck,
-R
Posted on Sep 10, 2008
  • 155 Answers
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
 thanks.
Posted on Oct 26, 2008
When I rewind my boobin, the thread is too loose. How do I adjust it on a JUKI DNU 1541-S?
You're saying the thread on the bobbin is loose/sloppy? That would be a result of the tension placed on the bobbin during winding. Make sure you are using the correct threadpath to wind the bobbin, or the winding tension needs to be adjusted.
https://www.sewingpartsonline.com/juki-dnu-1541-parts.aspx
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwiikseM2J3XAhUE72MKHSV2Bg8QFggmMAA&url=http%3A%2F%2Fdanreetz.com%2Fjuki%2FJUKI_DNU-1541-S-7EM01_SERVICE_MANUAL.pdf&usg=AOvVaw250Npk5Blb-ZBGHGIFqwyy
https://www.manualslib.com/products/Juki-Dnu-1541s-3329212.html
Nov 01, 2017 | Juki Sewing Machines
Bobbin winder on singer 1725
Hai, Please change the new bobbin winder. Because bobbin winder and winding is very important.
Mar 20, 2014 | Singer 1725
Cant get the boobin to wind the thread
Please try to would put the some very very small cloth piece onto bobbin. Otherwise you bought the separate bobbin machine.
Jan 07, 2014 | Brother XL-2230 Mechanical Sewing Machine
Thread bunching and bobbin winder quit
This sounds a lot like you've forgotten to lower the presser foot. (this leaves the tension discs open and causes serious issues below the material.) Double check that and if still having issues post again.
Nov 03, 2012 | Brother SE-270D Computerized Sewing...
Bobbin not winding tightly
BRAND new Janome 1420qdc. New needle, doesn’t need oil. Will NOT wind a bobbin. Used almost an entire spook of thread doing this. At my wits end. HELP!
Mar 28, 2012 | Janome Memorycraft 9700 Computerized...
My White 5500 sews perfectly on the top, but the bottom thread is tangled and messy. I have tried to adjust the tension according to the manual but nothing seems to work. Help!
This is a really common problem especially on side bobbin machines, and the manual will tell you it's a tension problem but it's often a more general thread feeding problem. First make sure you have a good quality thread that isn't old or sticking as it comes off the spool. And more important it can't be too heavy, especially in certain fabrics and with a fine needle. A too heavy thread will cause all the problems you describe.
If your machine uses a bobbin holder and it has a tensioner in it make sure it's clean and well adjusted and has no gummy residue on it. And finally look at the bobbins themselves, I understand older machines work better with metal bobbins vs plastic.
These are very generic solutions but I had similar befuddling problems with a newer Brother side bobbin machine and was tearing my hair out over the thread bunching and Brother support kept insisting it was a tension problem or improper thread routing.
Turned out I was using too heavy a thread.
Since then I picked up an older (1990?) Singer Meritt 4530 from Goodwill for $20, but it's a more expensive top bobbin machine and NEVER bunches or malfunctions. I'm sold on the top bobbin design now, the mechanism inside is more complex but the thread feed from the bobbin is more direct and simple leading to less sewing issues. So you pay more for less headaches.
Jun 01, 2011 | White Sewing Sewing Machines
The thread is loose on the bobbin end when sewing...the top is fine, but the bottom is so loose and bunches up into a mess.
Make certain the bobbin is inserted correctly into the bobbin case. If it is, be certain the bobbin is wound tight. A bad wind will cause the loose threads you mentioned. If both of those options are all right, check your upper tension. Generally, it should be set at 3. Also, make sure the needle is inserted correctly...the groove on the face of the needle should be facing the front of the machine (it is actually a thread guide). And last, has the bobbin case been removed and cleaned? If not, this could lead to "messy bobbin threads." I hope one of these suggestions is THE one for your problem. Good luck!
Nov 14, 2010 | Bernina Sewing Machines
Thread bunces up on the bottom causing machine to
I would start by looking for a problem with the bobbin tension. Do you have the bobbin threaded through the case correctly? Is the the bobbin tension set to loose? Another thing that can cause it to spool up on the bottom is if it sews a bunch of stitches all in the same spot or real close, do you have the presser foot tension to loose?
May 23, 2010 | Singer 2263 Mechanical Sewing Machine
Elna supermatic bobbin and threading instructions
Check out these instructions and diagram. Good luck. Paste this link to your Address bar... http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Elna_Sewing_machine_threading/Elna_Supermatic_threading_diagram.htm
Sep 09, 2007 | Sewing Machines
Singer 1725 Logo
70 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
